My extra care system plus whirlpool top loading washing machine makes a burned rubber smell when it is running.
  • 636 Answers
The drive belt is slipping
Posted on Jul 25, 2009
Washer seems to be stuck on spin. Has slight oil/rubber burning smell. Will only advance out of spin if you manually turn the knob to the next step.
The timer is bad and needs to be replaced. if you continue to run it this way you will need to replace the motor coupling real soon. That is where the burning rubber smell coming from.
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/charles_c2f37a3461344482
Jan 20, 2014 | Whirlpool Ultimate Care II LSQ9549L Top...
Whirlpool wash machine stopped spinning , motor stopped water did not leave- smelled of rubber
pump/or basket not spinning causing the belt not to turn thats the reason why is smells like rubber check pump and basket for free turning
Dec 09, 2009 | Whirlpool Ultimate Care II LSQ9549L Top...
Smells like motor is burning. during first wash cycle, washer stopped and there was an electrical burning smell??
YOUR WHIRLPOOL WASHER COULD HAVE A MOTOR PROBLEM, IT IS POSSIBLE THAT SOMETHING HAS GOT CAUGHT IN THE MOTORS WINDINGS AND SHORTED IT OUT. IT YOU CAN STILL HEAR THE MOTOR RUNNING BUT THERE IS NO AGITATION IT COULD BE THAT YOUR DIRECT DRIVE COUPLER NEEDS TO BE REPLACED, PART NUMBER IS 285753. THIS IS A COMMON PROBLEM, ESPECIALLY WHEN THE WASHER IS OVERLOADED AND CAN CAUSE A BURNING SMELL SINCE THIS PART IS RUBBER AND PLASTIC. IF YOUR WASHER IS MAKING ANY SORT OF BANGING NOISE THIS COULD BE THE PROBLEM. YOU CAN CHECK THIS BUT IT DOES INVOLVE REMOVING THE PUMP AND MOTOR. ANOTHER POSSIBLE PROBLEM IS THAT THERE IS SIMPLY A BURNED CONNECTION ON YOUR UNITS ELECTRICAL SYSTEM AND IF IT CANNOT BE REPAIRED IT WILL HAVE TO BE REPLACED.HOPE THIS HELPS
THANKS
Oct 12, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Agitating, ticking noise and then burning rubber smell
HI, the motor is failing slowly and, i recommend replacing this damaged motor asap before it starts to over heat and present a fire hazard.
Jun 04, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Burning rubber
hi! we have read your problem at Fixya! since you have specified that it smells like burning rubber, the belt connecting the motor and the tub accelerator might have been wearing out.this is a problem which occurs when you overload the motor frequently.if you get the smell continuosly, open the cabinet and get the replaced.hope your problem is tackled.have a nice day
May 25, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Slow agitating
Sounds like a failure in the gear case but the burning smell makes me wonder if you have a problem with the motor. You will need a appliance tech to verify
Feb 26, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Whirlpool top loader won't spin
If you are lucky you need a set of clutches about $45. If you are unlucky you would need a transmission.
Since it spins after you help it, I am guessing clutches.
Jan 31, 2009 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machine Smell and Stopped Working
thatss what it sounds like to me the motor simply turned off on overload( giving that electrical, almost burnt rubber smell.) either that or it was overloaded as well as overworked. i wouldnt see any reason for concern, unless was happenig on regular basis
Apr 05, 2008 | Whirlpool Ultimate Care II LSQ9564J Top...
Washing Machines Logo
183 people viewed this question
Top Washing Machines Experts
