Question about Paintball Sport & Outdoor - Others
What should I consider before buying paintball gun?
  •  DaveAnyc
    DaveAnyc Dec 30, 2017
    The MAIN thing to consider is your budget. Playing PB is expensive if you're paying for it yourself. Paintball is also a lot more fun when you're playing with friends. If you can play once a month, then your budget just to play may be as much as $100 a month. This includes paintballs (2000), airfills, and field fee. It does not necessarily include rentals.If you will play 2x a month, you may have to double that number.
    Your budget for gear is offset by the rental costs, but even if you only rent for a while, you'll want a good set of personal goggles (so you can see and sweat in your own mask) and an upgrade barrel (for the rental gun) and a squeegee (to clean your barrel). This can cost you $85 (V-force profiler, great relatively cheap goggles,) $35 (Gog barrel for whatever rental style gun they rent, $5-13 (swab/squeegee from Exalt or simpler pull through from psychoballistics. Both work well, the cheaper one you can stow around your neck while playing...)
    So that's $135 and you haven't even looked at the three other things you need, The Gun, the Hopper, and the Air supply. But you can play rental games and have a good time until you determine if you're really rich enough to play. When you decide you MUST get a gun, again, think about your budget. Too many players plop down 1000+ and play once or twice then we don't see them again...
    If you have the money haha, then you can definitely get the two accessory items- the HPA bottle (airsupply) and Hopper. The HPA bottle can be any brand, really, but the size should be 68ci/4500 meaning 68 cubic inches and with 4500 psi capacity. This is a good solid playing size. You can find them for around 125-150 and up. The hopper should be a Rotor, it can be any version and be good. They're not cheap, but they are great. $100. So now you've added 250 to your total (385) and now you can buy a gun. Forget about military looking guns. They look pretty if you're into fantasy island, but if you're there to play and shoot other players out of the game, then get a players gun. The least expensive good gun is the Mini $250+ the most expensive is the CS1.5 (etc) $1400. In between are RSX shockers- 700, Luxes-1200 Gteks/Eteks (cheaper versions of the top of the line Planet Ecliopse guns)-600
    And many many many more. I recommend that aside from budget, you get the gun that you believe will make you a better player. Yes I said that. Because you will psyche yourself into playing better or worse, so psyche yourself properly with the gun you believe will work best!
    New Friend:
Most paintball markers have either a center feed or a balance sustain. The benefits of a center feed are that the marker is able to use both hands, more adjusted and you can tilt it somewhat so your container remains behind cover. Paintball Gun Buying Guide is the best for you to get the full information.
Posted on May 13, 2017
Paintball gun
Paintball guns that are semi-automatic are generally more reliable and rugged than their electronic counterparts as they have a smaller number of moving parts. They are particularly preferred by beginner and intermediate level players who are discovering how to play the game, relying on a reliable gun rather than player skills. To get the guidance you may look on to Paintball Gun Buying Guide.
Jan 18, 2014 | Sport & Outdoor - Others
This a genesis lethal threat paintball gun I just got it and I am new to paintball what size paintball do I get for my gun please get back to me as soon as possible thank you
First off do you have a hopper and an air tank or co2 tank with air or co2 in it. If no get those things and fill your tank at a local paintball field. If yes your gun takes a .68 caliber paintball. That's really any paintball that you can buy at Walmart or sports authority.
Dec 01, 2012 | Toys
I have a used custom 98 ACT platinum. When i fire it , it goes full auto. My speed is at 270 fps.What do i do?
Buy a oil for a few dollars made specifically for paintball. Put a few drops in the ASA(where the tank screws in) screw the tank in and try to fire it about 10 times. If the gun still goes FA or sputters, I highly recommend having it serviced by a local pro shop or Tippmann.
Mar 29, 2011 | Tippmann 98 Custom Act Paintball Gun
Inconsistent velocity, and my velocity adjuster doesn't seem to be working
This is caused when a gun needs cleaning and-or O-rings are worn.
Tear down the gun and clean the lube with the special paintball gun oils
and reassemble. See if it is better. CO2 is terrible for paintball guns.
Go with HPA (High Pressure Air, aka Nitrogen) and this will help.
Feb 16, 2011 | Tippmann 98 Custom Act Paintball Gun
When i put my paintballs in the gun and i aim down they fall out the top where they shoot from
Sound like your ball detent is gone or broken.
The detent is a tiny piece of rubber that keeps the paintballs in the chamber and from rolling out the barrel. It's a cheap part, but you will need basic knowledge of disassembling a Tippmann 98 to replace it.
You can find ball detents here!
Feb 12, 2011 | Tippmann 98 Custom Act Paintball Gun
Paintballs fall out of tippmann 98
Go to ebay and buy a new ball detent for the 98 they are cheap and well worth it because how many times have you got shot for double balling :)
Sep 20, 2010 | Tippmann 98 Custom Act Paintball Gun
Bruizer outlaw paintball gun
There are many things to take care of the paintball gun. The good thing is that with paintball gun so much choice available, you should always be able to find a marker that meets your requirements perfectly. To get the details about each and everything you can refer to Best Paintball Guns.
Aug 26, 2010 | Sport & Outdoor - Others
98 Custom Act Paintball Gun: i want it to go fasteer...
I can take that a couple of ways. Do you mean you want to fire more balls per second or you want the paintballs themselves to fly faster?
If you want to fire faster, make sure it's clean and properly lubed with a quality oil that made for paintball. Practice makes perfect and fire that ****** as often as you can, even without paint (that's cheaper!) so you can get your trigger finger in shape.
There are custom mods to the trigger, or you can buy a trigger that's smoother or a shorter pull. There are electronic trigger assemblies that make firing faster even easier.
If you're talking about making the balls fly out of the gun faster, that would be the "velocity adjustment". Your user guide shows you how to make that adjustment and which direction is up, and which is down.
A good suggestion is to check out a local field or paintball store, or an airsmith and they can give you some definite ideas you will want to pursue.
Play hard, play safe, play with honor!
8^)
May 17, 2010 | Tippmann 98 Custom Act Paintball Gun
Paintball gun is rapid firing when trigger is pressed. CO2bottle is full and i have tried other bottles but stillth same.
Tippmanns are known for their reliability and are very simple markers making them very easy to repair. you need oil from a local paintball shop or regular sewing machine oil will do.
On one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns, if not..
Sometimes paintballs can break inside your gun. Look and feel inside your breech (where the paintballs go into the gun) and check for paint. If its dirty this can be causing your problem, strip it down and clean it (refer to your manual if you have difficulty)
on one side of the marker there is a little "handle" for cocking the gun, pull that handle as far back as you can and you will see 1 o-ring. put 2 drops of oil on it and fire it a couple times without paintballs to test it. This solves the problem 9/10 for tippmanns
Jan 08, 2010 | Tippmann 98 Custom Act Paintball Gun
More then one ball coming out
Your "ball detent" has worn out. This is a little rubber nipple inside the breech of your gun (where the balls go into the gun from your hopper) that has torn. This is a normal wear and tear item and will cost you only a few dollars to repair. You have to buy this part from your local paintball pro shop they will have it.
Nov 16, 2009 | Tippmann 98 Custom Act Paintball Gun
Sport & Outdoor - Others Logo
69 people viewed this question
Top Paintball Sport & Outdoor - Others Experts
Bill Eager
Are you a Paintball Sport and Outdoor - Other Expert? Answer questions, earn points and help others
