Question about Sears Garden
I am looking for a diagram for a sears roebuck 1/2 horsepower 6.7 amps 1750 rpm motor model#1106962
rowdy45176
  • 2176 Answers
SOURCE: Motor has started t0 smoke and trips circuit breaker
On the motors I deal with there is a series of numbers that identify the shaft size, hp and all other requirements. I would try and contact a local Grainger and see if they can help, if not try in the yellow pages for a motor repair shop in your area and sometimes they can get you one. Good luck
Posted on Jul 18, 2009
efs_perpends
  • 1996 Answers
SOURCE: Looking for blades for a 6 inch craftsman
Most reliable sharpening services will be able to grind knives for your jointer that will work just fine. The key is to match the existing knives as far as thickness (guage) and height of the new knives. You want them to give you maximum life but not extend too far past the cutterhead when adjusted all the way down. I don't know about your machine, but on an 8" powermatic the tip of the knife shouldn't extend more than about .0012" above the circumference of the cutterhead. You can check this with a set of calipers and give the height to the sharpener, then just choose high speed steel or carbide and you're on your way.
If you check the overall length of the knives, sometimes they are slightly under the nominal length, and a 6" long knife could bump into the housing as the cutterhead rotates, so this is one other thing to check before you go ahead and order them 6" long.
But the short answer is, no problem. Just get a reliable sharpener to make them for you, buy a quality steel blank, and have him put a fine grit polish or hone on the knives when he sharpens them...
I hope this information allows you to resolve this issue. If you need further assistance, please post back with a comment to this thread.
If I've managed to answer your question or solve a problem, please take just a moment to rate this post....thanks!
Posted on Jul 23, 2009
smartr10U
  • 1305 Answers
SOURCE: I'm looking for a owner's manual for a Sears,
Found you a copy that you can download
It's a pdf type file... adobe reader will allow you to read and print a copy..
Click HERE
Posted on Sep 17, 2009
john224
  • 1378 Answers
SOURCE: Looking for a wiring diagram for an A.O. Smith
Thank you for posting your question here on Fixya.com.
That actually appears to be part of the serial number, not the part number at the end of your post. What are you trying to accomplish? With a description of your terminal board and the current wire arrangement I should be able to tell you what you need to know. Another option would be to contact us through our site at www.arrowmotor.net and send a picture of the board.
If this answer does not fix your problem, please comment with additional details prior to rating the answer. Positive feedback is appreciated once your problem is solved!
John
Posted on Mar 17, 2010
  • 979 Answers
SOURCE: Fuse - 2amp for a Silvertone 1472 Amplifier
Hello endaya try www.digikey.com if you are using a 2amp buss fuse, its available, 117V is applicable to 220V, just follow the amp rating.
Posted on Apr 22, 2010
Testimonial: "Thanks! Information provided was very helpful. Much appreciated!"
Minnnesota model E : threading the machine?
Try Sears. A lot of brands were similar back in those days (because they copied or re-badged other brands), so finding a threading diagram for an old Singer would probably be helpful.
Sears Roebuck and their Sewing Machines
Minnesota Model given to sister in law
Instructions For Operating the Minnesota Model Sewing Machine Sears...
Apr 18, 2017 | Sewing Machines
I need information on a Sears and Roebuck outboard
sorry but you need to contact sears and roebuck.
Sep 28, 2014 | Boating
Need a manual for sears and Roebuck sewing machine model 158.15150
I've also looked for a manual, I suggest going to the sites listed
below & emailing them or calling them & ask them about a manual
sewvacdoctor.com
a1sewingmachines.com
Sep 24, 2012 | Sewing Machines
Im looking for a spark plug wirng diagram for a 1966 corette 427
1966 - 1969 with 4 Barrel Carb (L36)
(Low Compression Model)
Max Brake Horsepower - 390 @ 5200 rpm
Max Torque - 470 @ 3600 rpm
Stroke - 3.76
Bore - 4.251
Compression - 10.25
Firing Order - 18436572
1966 with 4 Barrel Carb (L72)
(High Compression Model)
Max Brake Horsepower - 425 @ 5600 rpm
Max Torque - 460 @ 4000 rpm
Stroke - 3.76
Bore - 4.251
Compression - 11.0
283, 327, 396, 409 and 427 CID Engine 1965-1966
Firing Order 1-8-4-3-6-5-7-2
350 CID Engine 1969-1974 Corvette, 427 CID Engine 1969 Corvette
Hope this helps (remember to rate this answer)
Jun 15, 2011 | Chevrolet Corvette Cars & Trucks
Replacement Motor for Bathroom Exhaust Fan Need motor and blower assembly or just the motor for a Sears Roebuck Model 864.892 Motor is Universal Electric Co Model 118JF5 S/N 1T26714
Not sure what you are asking, but you can get a replacement directly from Sears. It is okay to replace just the motor, but be sure the fan blades are completely cleaned. When you are all done, verify good air flow outside of the building.
Sep 19, 2010 | Home
Jul 18, 2009 | Craftsman 10" Table Saw
Craftsman 1/2 horsepower not working
Five flashes indicates possible RPM sensor failure. First try unplugging opener for five minutes and plug back in. If it still does not work replace RPM sensor.
Jan 25, 2009 | Sears Craftsman LiftMaster Chamberlain...
Garden Logo
Top Sears Garden Experts
Tim Whalen
Matt Olenzek
Matt Olenzek
Dennis Key
Dennis Key
Are you a Sears Garden Expert? Answer questions, earn points and help others
