To build a butterfly and facts for project urgently please been sitting for hour no site will give me info free i will have to go to liabrary with my grandchild
I want to print free general information about butterflies help please
go google and type in ---butterflies-- most information will have pdf versions that you can download
May 13, 2017 | General Computers & Internet
Please some body tell me what github. is and why is it on phone. also doubleclick. data.twitter.icon 72?
What is Github? GitHub - a social repository for open source code projects that use Git for source code versions control. This host site is a distributed file version management systems. Linus Torvalds created this project for Linux kernel development control. Such projects like Chromium, jQuery, PHP, MediaWiki etc. use Git. Good news - this free software is released under GNU GPL license version 2! Read also more about other good source code repositories: GitHub vs BitBucket vs GitLab Developers Research
May 27, 2016 | Computers & Internet
What interesting facts are there on Alex Morgan?
Well, if you need info on Alex Morgan, here's how you can a bunch of info. Do a web search : "Alex Morgan", and you'll get many sites with a lot of information.
May 29, 2014 | Health & Beauty
How do you figure what glass and how thick for building an aquarium
Google for "how to build............." as this question is posted in the TV area.
May 02, 2012 | Toshiba 65HM167 65" Projection Television
When A/C is on, car will take off on it's own if brake is not held down firmly when putting car in drive or taking off from a stop.
Hello! Ford Five Hundred's have a surge problem that is not being addressed by Ford...The butterfly in the throttle body is sticking due to carbon build-up. Purchase a can of 3M Throttle body cleaner and lubricant...Pull off the air intake hose and spray in and around the butterfly inside the throttle body...Give it a good soaking....Let it sit for 30 minutes then wipe it clean with a lint free rag...Have someone push the gas pedal to the floor and see that the butterfly moves freely...Engine may need to be cranked awhile to restart but this should solve the surge fault...Guru.....Saailer
Aug 25, 2011 | 2006 Ford Five Hundred
Big yellow spot in middle of screen of sony model kdf-50we655
Most probably it is an issue with the optical block of the TV. Sony aware of the issue and giving free service for few models. It would be good if you contact Sony directly to check for the available options to get the free service. If you wish to know the contact information and timings, please message me www.fixya.com/users/shajanrs
Jan 10, 2011 | Sony Grand WEGA KDF-50WE655 50" Rear...
Wont start when warm without pumpin gas, and engine revving to high
A high rev problem is due to either carbon build up in the iac passage's not letting the iac close to normal idle or the iac is just bad and stuck in that position.
iac= idle air control solenoid
Inside the throttle body intake is a butterfly and just above that is a small opening that the iac uses to move air past the butterfly and this sometimes gets plugged with carbon build up so spray some carb cleaner down through the passage,and sometimes you have to remove the 4 bolts and take the throttle body off to clean them out.
Saturns are known for carbon problems,and they are hard on egr systems,I recommend using sea foam a couple times a year to help fight the carbon build up,just follow the direction and use it in the fuel and vaccum lines as directed but do it on a warm engine and let sit for a couple hours so the sea foam has time to loosen the carbon
May 31, 2010 | 2005 Saturn SC1
Turn TV on. Turns self off. After many times, if picture comes on, Tv seems OK. All ready paid $350 to fix once 14 months ago.
Having in mind that a generic lamp will give you 4500 to 6500 lamp hours and the Phillips will give you 6000 to 8000 lamp hours, For what you discribe above the could be your problem, I did some research and you can find the best price for lamps http://www.discount-merchant.com/?click=52978 and they have free troubleshoooting
Regards
Nov 18, 2009 | Sony KP-51WS500 51" Rear Projection...
Convergence in home repair cost ?
about 450.00 or more compared to about 50 if you do the repair yourself. Which takes about an hour from start to finish. I can post a link that sells the new ICs and gives free installation instructions and on line tech support so you can easially do it yourself. If you would like the link to the site, please let me know
Apr 10, 2008 | Hitachi 53UWX10B 53" Rear Projection...
Philips 9P6034C103 - Urgent Response Appreciated
Was the hour glass upright or sideways? From what you described I would say you have a pin-cushion problem. Let me know if you need any additional info.
Feb 03, 2008 | Philips Magnavox 9P6034C 60" Rear...
Televison & Video Logo
26 people viewed this question
Top Televison & Video Experts
