Question about Kenmore Elite 45986 Front Load Washer
Kenmore front load washer drain problem
My washer seems to have a clogged drain hose. It seems awfully long-would I be shooting myself in the foot if I cut the hose to make it only as long as necessary, so that I may have easier access?
  • 298 Answers
Why not use a piece of scrap
hose cut it a little longer than
you want then experiment its
easier to shorten than lengthen.
That way you start out with a
clean hose,and you can kill to
birds with one stone
Posted on Nov 21, 2007
Kenmore HE 3t won't drain
check pump filter for debris
Feb 27, 2014 | Kenmore Washing Machines
Clothes are sopping wet even after doing the spin cycle 3 and 4 times, water is going through hose fine it seems, it a front loader
This issue usually occurs due to kinked drain pipe, clogged drain filter or drain pump. First make sure that the drain is not clogged and remove clogs if present. If no visible lint is present then remove the lower front access panel to check the drain filter and drain pump for any clogs, you'll need to clean the drain filter and drain pump completely. Hope this helps... Please post back for any further assistance.
Aug 27, 2011 | Kenmore Energy Star 44092 Front Load...
Kenmore HE2Plus White Front Loader. Drain pump seems weak, wet clothes, and f-21 flashing..???
Hello & Welcome to FixYa
F21 error code is displayed when the washer is unable to drain, press PAUSE/CANCEL button twice to clear the display. After this please check the drain hose and drain pump filter for any blockages and make sure it is not clogged with foreign particles. You can also check the drain pump to verify that its working. Please get back to me if you have any other questions.
Mar 07, 2011 | Kenmore HE2 Plus Front Load Washer
Washer not draining
Possible fault in your drain pump/drain valve. remove the drain hose to check and confirm.clena if clogged. If the test on the drain pump/valve seems fine then the program controller is not giving the required voltage in the said cycle.
Use a multimeter to confirm.
Oct 29, 2010 | Kenmore HE2 Plus Front Load Washer
I have a Kenmore HE5t/ front loading auto. washer. I keep getting a problem of F21 frequently. Each time proper procedures are taken care of in your problem shooting guide. This doesnt seem to help...
Thanks for using FixYa. Error F21 indicates long drain, this error occurs when the drain time exceeds 8 minutes. To resolve this check the drain hose and make sure it is not kinked with any foreign particles; also clean the drain pump filter for any clogs. Also check if the pump is running fine. If still the issue is not resolved after all this then you might have to replace the pump. Please rate the solution if the issue is resolved or post a comment for further assistance.
Oct 06, 2010 | Kenmore Washing Machines
Our front loading kenmore washer is not draining properly
1. check the filter at the pump
2. check to see if you have any restrictions at the drain hose ( that is the hose that set in the hole in the drain)
3. clogged filters at the outlet pump will cause improper drainage.
I hope this helps.
Jun 14, 2010 | Kenmore Elite 45986 Front Load Washer
I have Kenmore front load washer(don't have the model # yet)...during the normal wash the end of it it does not spin, the diplay show E20. What seems like the problem??
2 Beeps/E20--Error: Water dosen't drain. Cause: Drain is kinked or household clog. Correct.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Jan 25, 2010 | Kenmore Elite 45986 Front Load Washer
Washer will not drain and spin. Have checked the
If you have room and empty 5 gal bucket try to lower your drain hose to see if there is any water coming from. Other should be points on programer or small motor that spins programer.
Dec 29, 2009 | Kenmore 3.8 cu. ft. HE3 Front Load Washer
Kenmore Elite Washer
Try this first.
Washer won't drain or spin
Is the drain hose clogged, or the end of the drain hose
more than 96" (2.4
m) above the floor?
Is your voltage low?
Check electrical source or call electrician. Do not use an
extension cord.
Is the "SUD" routine active?
Cycle will complete once extra suds are removed.
Is the load balanced?
A single or bulky item may cause imbalance. Add more items
or redistribute the load.
Dec 16, 2008 | Kenmore Elite 45986 Front Load Washer
Kenmore Front loader clogged up
open the back panel to access the hoses. look for the largest-diameter round hose and disconnect it. this should be the drain hose. it also should lead to a vertical-rising pipe or hose that then dumps downward (U-tube at top) into your house piping outside the washer. My hunch is the clog is somewhere before the area where you disconnected and may need to remove all hoses from the pump and also clean pump's impeller.
May 30, 2007 | Kenmore 46462 Front Load Washer
Kenmore Elite 45986 Front Load Washer Logo
Sal De
 Brian Main
Brian Main
