Question about Samsung Cell Phones
Samsung Galaxy 4 takes an extremely long time to charge
How to screenshot
How do I take screenshots on my Samsung Galaxy Avant ™ ?
www.samsung.com > ... > Cell Phones > T-Mobile
Samsung Electronics... of the screen. The screenshot will be copied to the clipboard and saved to the Screenshots folder in the Gallery. ... Print: Print the screenshot to an available printer via a wireless network, Wi-Fi Direct, or USB cable. Settings: ... Cell Phones.
How to take a screenshot on Samsung Galaxy - PC Advisor
www.pcadvisor.co.uk > ... > How to take a screenshot on Samsung Galaxy
May 15, 2015 - Taking a screenshot on a Samsung Galaxy smartphone is a simple task, but it's a ... Whether you've got a Samsung Galaxy S3, Samsung Galaxy S4 orSamsung ... How to take a screenshot on Samsung Galaxy. PC Advisor · Phones ....Once my Galaxy S3 get fully charged on wireless charging pad , I will ...
How to take a screenshot on Android phones, tablets - PC ...
www.pcadvisor.co.uk/.../how-take-screenshot-on-android-phones-tablets...
Aug 20, 2015 - In the early days of Android taking a screenshot on a phone or tablet ... on an Android smartphone or tablet, including the Samsung Galaxy S6, ...
Dec 21, 2015 | Samsung Cell Phones
My Samsung s5 is not charging their is nothing wrong with my charger
check this
1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
How to fix Samsung Galaxy S5 not charging issue
Summary
  • Try a different charger with Samsung mobile origin.
  • Try a different USB Cable and charge by Kies.
  • Try charging it off via PC/Laptop.
  • Try removing the battery for 3 minutes, let it cool down and then charging again.
  • Blow inside the USB port and fix the contacts if it's bent.
  • Reboot your phone several times.
  • Download the battery charging electrical current app to monitor charging
(Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
goodluck
Jul 04, 2014 | Cell Phones
Why is my Samsung Galaxy Note 10.1" charging very slow.
There are a several reasons why the Galaxy Note 10.1 is not charging as much.
1. Too many application are turned on (check the task manager)
2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
3. Plugging your charger using a computer
Are you using the original charger and plugging it into a wall charger?
How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
I hope this info is helful,
Jason Chan
Jul 01, 2014 | Samsung Galaxy Note 10.1"
A samsung galaxy player 3.6 that wont turn on
The charger has a function that restores the battery operation parameters by discharging then charging the battery a number of times. Refer to charging instructions in the pack but I think the cycle is a 3 hourly one, time to charge from a full discharge. If the charger thinks the battery is dead then it will try to recover the battery using this process. You may have left the charger on long enough to charge then also discharge the battery.
Start again and charge for the time in the instructions ONLY, if you are not sure of the time try it for an hour, then without disconnecting the charger turn the unit on and take particular note of any screen messages, if any.
You should be able to continue as normal now, but still be aware of the time you are leaving the charger connected for, as it may take some time before it returns to normal operation and stops trying to recover what it thinks is a dead battery.
May 04, 2014 | Samsung Galaxy Tab Tablet PC
Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
REASONS OF SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
SOLUTIONS TO FIX SAMSUNG GALAXY S4 NOT CHARGING- GREY BATTERY PROBLEM
Method 1
If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
Method 2
Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
Method 3
Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
Apr 25, 2014 | Samsung Cell Phones
Tablet running slow
try to reset it factory defaults
Feb 24, 2014 | Samsung Galaxy Tab Tablet PC
How do I replace charging port on a samsung galaxy prevail
i have the galaxy prevail and it had been to where it wouldn't charge at all then i thought i had fixed the problem because it charged last night but tonight its not wanting to charge at all and im using the same cord and i have tried 4 different cords and none of them charged it
can anyone suggest something that'll help?
Dec 29, 2012 | Samsung Galaxy Prevail M820 - black Boost...
How long do i need to charge my new samsung galaxy 2 before its ready for use
After purchasing every new phone, 24 hrs continuously charging is required to use the phone first time. Please charge Samsung Galaxy 2 before use.
Jan 26, 2012 | Samsung Cell Phones
I just want to ask how long will I charge my new phone for the first time. Thanks.
it does not matter...The new hi-tech units have smart charger feature and it stops when fully charged...and this unit has another feature that it gives a message "fully charged ,unplug now".
Take care..Thanks for rating me ..
Jun 18, 2011 | Samsung Galaxy S GTI9000 Smartphone
Cell Phones Logo
27 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
