Question about Water Garden
How many gallon of water is 180 litres then what is a 1 oz in metric
    Top Expert:
  • Water Master
  • 42,546 Answers
18. liters =47.55 gallons
1 oz = 31.103 grams
Posted on May 13, 2017
How much is13 cups to gallons?
1 Cup = 8 oz.
1 Gallon = 128 oz. (16 cups)
13 x 8 = 104 oz
104 divided by 128
or
13 divided by 16
Jul 16, 2016 | Wine & Spirits
WHAT IS THE OIL TO GAS MIXTURE IN OIL TO GALLONS
Mixing
RatioGAS:OIL UNITED STATESOIL per 1 U.S. GALLON Gasoline
(128 oz.) *INTERNATIONALOIL per 1 IMPERIAL GALLON Gasoline
(160 oz.) *INTERNATIONALOIL per 1 LITER Gasoline
(metric) 32:1 4 oz. 5 oz. 31.25 mL 40:1 3.2 oz. 4 oz. 25 mL 50:1 2.6 oz. 3.2 oz. 20 mL
May 04, 2015 | Garden
Oil petrol mixture for Rockwell 26cc weedeater
Two cycle engines run on a mixture of gasoline and oil. Each engine type is designed to run on a specific gas-to-oil mix ratio.
IMPORTANT: Use only oil that is labeled for use in "Two-cycle" or "Two-stroke" engines. Home Depot and other stores now have "premixed fuel" of gas and 2 cycle oil.
To mix two-cycle fuel, start by putting correct amount of oil in gas can. Then slowly add correct amount of gasoline. Do not try to mix gas and oil directly in gas tank of equipment.
IMPORTANT: Do not use any fuel that is over 30 days old. Do not mix more fuel than you are likely to use in a month. Old fuel can gum carburetors and prevent starting. Always use fresh fuel.
The chart below shows correct amount of oil per gallon that each mixing ratio requires. Expect that yours will be between 32 gas to1 oil and 50 to 1. 32:1 and 50:1 are most popular.
Ratio GAS:OIL UNITED STATES OIL per 1 U.S. GALLON Gasoline
(128 oz.)
*INTERNATIONAL OIL per 1 IMPERIAL GALLON Gasoline
(160 oz.)
*INTERNATIONAL OIL per 1 LITER Gasoline
(metric)
Jan 01, 2015 | Weedeater Garden
How do I make the conversion from gallons of liquid to 1 liter ?
A simple Google search can tell you that answer:
1 gallon = 3.78541 litres
or,
1 litre = 0.264172 gallons!
Sep 16, 2014 | Wine & Spirits
What is 20:1 ratio of two cycle oil per gal
One part oil twenty parts petrol to a gallon 8fl oz per gallon it may be easier in litres 5 litre is one gallen nearly so add 250ml to the gallon it will run fine hope this helps
Jul 24, 2014 | Garden
What fuel mix for a JCB M25 Strimmer?
40:1. Which works out at 25mls of oil to every litre of petrol.
Found the above answer on another site, 40:1 in the U.S. is 2.6 oz. of 2 cycle oil to 1 gallon of gas.
Sep 04, 2011 | Garden
How do you refill roundup pump and go container with sprayer, cant work it out. IT WOULD BE A GOOD IDEA IF MANUFACTURES GAVE INSTRUCTIONS HEY.
Any Roundup Weed & Grass Killer RTU can be refilled with the new 1.25 gallon Roundup Weed & Grass RTU Refill bottle OR use Roundup Super Concentrate (purple cap).
Directions to Refill with Roundup Super Concentrate
  • 24oz RTU: 1 oz of RoundUp Super Concentrate, fill with water very slowly to avoid foaming.
  • 1/2 Gallon RTU: 2 1/2 fl. oz. of Roundup Super Concentrate and slowly add 1/2 gallon of water
  • 1 or 1.1 Gallon RTU: 5 oz RoundUp Super Concentrate, fill slowly with 1 gallon of water
  • 1.33 Gallon (PNS & PNG): Add 6.5 fl oz of the Super Concentrate to container and slowly fill with water
Apr 24, 2011 | Roundup "" Weed & Grass Killer
Calculate 40 metric tons of diesel oil to gallons
Hello, i did the math for you..
1000 KG = one metric ton.
1 litre = 0.264172052 Gallons.
1 litre of diesel = 0.832 kg/l (density)
You need 40,000 litres of diesel in gallons,
so 40,000 KG/0.832 kg/l (KG/L) = 48,076.9231 litres.
so total gallons is 12,700.5794 US gallons.
Hope it did not confuse you and it helped you.
Thanks please rate if you got your answer
Feb 22, 2011 | Computers & Internet
Fuel mix wrong, won't fire smokes once in a while
40:1 =40 parts of gas to 1 part oil. If you run 1/4 oz oil to 4 gallons of gas, you will fry a two cycle. That's like running straight gas.
May 26, 2009 | Poulan Featherlite Gas Blower, with Low...
Garden Logo
Top Water Garden Experts
Vernon Taylor
roeb
Are you a Water Garden Expert? Answer questions, earn points and help others
