Question about Samsung Cell Phones
Samsung galaxy 4 charges extremely slowly - Samsung Cell Phones
I bought a used Samsung Galaxy Tab 4 (8.0) running on AAA Automobile Club towing system on it, I want its original android system back into it, where can I find that specific download? A link please!
Try a Hard Reset which clears everything off it and installs Android new. There are no Android download links.
  • Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8 ... > Samsung Galaxy Tab 4 (8.0) Before performing a hard reset, ... Home > Support > Samsung > Samsung Galaxy Tab 4 (8.0) > Factory Data Reset (Powered On) - Samsung Galaxy Tab 4 (8.0) Ask Verizon:
  • How to Factory Reset the Galaxy Tab 4 - YouTube
    • 3 MIN
    2014-05-19 · Video embedded · How to Factory Reset the Galaxy Tab 4 Check Out Our New Website: Like us on Facebook: ...
  • SAMSUNG T330 Galaxy Tab 4 8.0" - How to Hard Reset my ... Hard Reset SAMSUNG T330 Galaxy Tab 4 8.0" First method: In order to switch off the tablet hold down the Power key for a short while. After that, press and hold ...
  • Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset ... Samsung Galaxy Tab 4 8.0: Hard Reset Factory Reset. From ... How to make a Hard Reset (Factory Reset & Data Wipe) on Samsung Galaxy Tab 4 8.0"? Samsung ...
  • Samsung Galaxy Tab 4: Steps For Hard Reset - Technipages How to perform a factory hard reset on the Samsung Galaxy Tab 4 tablet. Technipages Smart phone, gadget and computer tips. ... Samsung Galaxy Tab 4: Steps For Hard Reset.
    May 23, 2016 | Samsung Tablets & eReaders
    I can not open emails with attachments camera flash will not work cannot answer text messages that i receive
    Samsung Galaxy S4 Troubleshooting - The Droid Guy
    Galaxy S4 won't charge, won't turn on; Galaxy S4 camera flash not working ..... S4Can't Receive Calls; S4 Can't Open Emails; S4 Headphone Does Not work ..... Galaxy S4 won't download any email attachment; Samsung Galaxy S4 stuck at ...
    Samsung Galaxy Note 4 Troubleshooting - The Droid Guy
    Samsung Galaxy Note 4 Battery Is Not Working Issue & Other Related Problems ...Galaxy Note 4 Stuck In Boot Screen, Does Not Start, Other Related Problems .....Data After Lollipop; Galaxy Note 4 LED Indicator Not Working After Lollipop ..... When Iopen an attachment from any e-mail (pdf, excel, word, note), I can not ... Customer Discussions: Kindle Fire and email attachments, Inc.Dec 26, 2011 - Electronics. TV & Video Home Audio & Theater Camera, Photo & Video Cell Phones & Accessories .... why can't I open or view email attachments on my Kindle Fire? ... Please scroll down and tell me if the box beside Enable Flash is checked. ... Me:I can read the emails and does not work either
    Problems After Updating to iOS 9.0.1? - iPhone Topics
    Jan 20, 2016 | Cell Phones
    My Galaxy 4 will not turn on today
    The battery may be flat let it charge up .Or the battery be at fault.
    Sep 28, 2014 | Samsung Galaxy Player 4 8GB Android Tablet...
    My Samsung s5 is not charging their is nothing wrong with my charger
    check this
    1. First of all make sure that you are using an approved wall charger of Samsung Company. Because charging accessories of other brands may have different voltage parameters and may cause Samsung Galaxy S5 not charging issue.
    2. Plugged in your Samsung Galaxy S5 with an original Samsung Mobile charger, but do not turn on your phone. Sometimes it may take little longer to charge the phone. After you phone starts charging, a charging icon should appear on screen. But if you see nothing is appearing on screen, then Samsung Galaxy S5 not charging issue is occurring either for damaged charging cable or there is some problem on your phone such as the charging port is damaged or bent, or the charging contacts on your phone is not cleaned.
    3. To check the charger, charge another Samsung phone using the same charger and see if it is charging. If the other phone is charging well, then the charger is fine. Now you should check your phone.
    3. Check the charging port on your Galaxy S5. To check the charging port, take a light, magnifying glass and a pointed wooden toothpick. Then see if the charging port is in the center and not bent. If you find the port is bent, then straight it using the wooden toothpick carefully.
    3. Also verify the charging contacts are clean. Sometimes dirt gets stored into the charging port and occurs Samsung Galaxy S5 not charging issue. So Insert a small needle in the charging port and clean carefully so that the port does not get bent or damaged.
    4 Download Galaxy Charging Current, to see if your phone is charging at it's maximum potential
    How to fix Samsung Galaxy S5 not charging issue
    • Try a different charger with Samsung mobile origin.
    • Try a different USB Cable and charge by Kies.
    • Try charging it off via PC/Laptop.
    • Try removing the battery for 3 minutes, let it cool down and then charging again.
    • Blow inside the USB port and fix the contacts if it's bent.
    • Reboot your phone several times.
    • Download the battery charging electrical current app to monitor charging
    (Note:Samsung Logo/images/Pictures has a respective copyright. I used it for demonstration purpose only.
    If something in your mind to comment or suggest, please let us know. In our efforts to provide detailed information, there is possibility of inaccurate contents. If you see any mistake or incomplete in our information, please don't hesitate to tell us. We will fix it immediately as soon as possible.
    Jul 04, 2014 | Cell Phones
    Why is my Samsung Galaxy Note 10.1" charging very slow.
    There are a several reasons why the Galaxy Note 10.1 is not charging as much.
    1. Too many application are turned on (check the task manager)
    2. Too many notifications icon are turned on ( bluetooth, gps, wifi, etc.)
    3. Plugging your charger using a computer
    Are you using the original charger and plugging it into a wall charger?
    How long did you use the Note 10.1 previous to noticing the damage? and was it extremely hot at the back?
    If so, then maybe the battery isn't picking up from the charger. I've watched back to back movies while still using the charger but this can prove very devastating on the charger's outlet which became extremely hot after 4-5 hours or so of charging continuously. It turns out, the galaxy note 10.1 can withstand 8+ hours of ongoing movies but the charger outlet cannot. *If I didn't unplug it after 4-5 hours, the plug what have fried.
    In this case, i believe the charger is more likely damaged than the Galaxy Note 10.1, which is more of a better scenario. Especially, since you charged it for over 24 hours, meaning it's charging something, but very slowly. Operating Galaxy Note while charging can prove detrimental in the charger's outlet and can in fact burn out.
    I hope this info is helful,
    Jason Chan
    Jul 01, 2014 | Samsung Galaxy Note 10.1"
    Why will my samsung galaxy s4 not connect to the charger - the socket seems to have dropped
    The main reason of Samsung Galaxy S4 not charging- grey battery problem is a shorted charging port. There may be several reasons for it such as sometimes dust entered into the charging port and causes this problem. Sometimes the bar across the center of the charging port gets bent.
    Method 1
    If your Galaxy S4 falls and you start to face Samsung Galaxy S4 not charging- grey battery problem, then take a pointed wooden toothpick, a magnifying glass and a strong light and see carefully if any bar across the center of the charging port is in the center and not bent to touch one of the sides of the shell. If you find that it is bent then straight it using the toothpick point carefully.
    Method 2
    Look for the dirt into the charging port that it may pick up from anywhere. Take a thin needle and gently insert it in the charging port to take out the large piece of dirt from it. But you have to be very careful so that you do not make any damages of the charging port. You can do this by using a can of compressed air or dust/hair blower that will blow out the small dust particles from your phone's charging port.
    Method 3
    Some users reported that they have found solution of the Samsung Galaxy S4 not charging- grey battery problem by taking out the battery from the phone , insert it into another Samsung Galaxy S4 ,and then again put it in back.
    So follow these steps to get rid of Samsung Galaxy S4 not charging- grey battery issue.
    Apr 25, 2014 | Samsung Cell Phones
    Charging Samsung E1207T
    Hi Ikbal
    Not sure what you are asking, but If you are looking for a charger, you can pick one up at any mobile shop that sells these types of handsets. If your question is , how to charge, then same answer applies. Visit a cell phone dealer that sells accessories and they will have these chargers.
    Sep 03, 2013 | Samsung Cell Phones
    How do I replace charging port on a samsung galaxy prevail
    i have the galaxy prevail and it had been to where it wouldn't charge at all then i thought i had fixed the problem because it charged last night but tonight its not wanting to charge at all and im using the same cord and i have tried 4 different cords and none of them charged it
    can anyone suggest something that'll help?
    Dec 29, 2012 | Samsung Galaxy Prevail M820 - black Boost...
    Cell Phones Logo
    29 people viewed this question
    Top Samsung Cell Phones Experts
    Computer Repairing
    Computer Repairing
    Ronny Bennett Sr.
    Ronny Bennett Sr.
    Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
