Question about Briggs Garden
I have a woods R2048 mower with a 20hp Briggs tunes over but won't start
    Loyalty:
    Visited the website for 30 consecutive days.
  • Briggs Master
  • 1,103 Answers
First check for spark pull the spark plug spray some gas in the opening put plug back try to start if it runs a second you have spark then chrck fuel feed rremove carb. spray all parts with carb. cleaner put back on see if it will start be sure to check fuel filter before doing any work on carb.
Posted on Dec 01, 2017
  • 10865 Answers
SOURCE: murray belt manual for a 20hp 46" rider lawn mower
here is a link to all of the murray manuals, for free. pick out your model and enjoy your manual.
Posted on Jun 02, 2009
  • 7 Answers
SOURCE: New Craftsman 20hp Briggs & Stratton 42
first make sure the air intake screen on top of engine is not clogged with debris if thats not a concern you could have a faulty ignition coil etc your engine should have a two year warranty and can be serviced at no charge to you at your local briggs service dealer make sure and check your manual for the fine print though. Briggs makes a great engine and very rarely have I ever seen a problem allthough if you were to have an engine issue it will accur during the first few hours of opperation good luck
Posted on Jan 25, 2010
  • 10 Answers
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Posted on Apr 12, 2010
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
  • 370 Answers
SOURCE: I blew my connecting rod on my Briggs 20hp and replaced
yes it is possible to put them in backwards, there are triangles on the rod and crank that have to be on the same side in order for it to be correct. If it is missfiring you also need to check you timing key on the crank. since you broke a connecting rod I would only have to assume that you sheered the timing key as well.
Posted on May 05, 2010
ftw1952
  • 10319 Answers
SOURCE: Briggs 20HP Intek sputters under load
reset the valves to specifications by gaping them all to .008 thousands The vibration will continuely make the gap wider causing this problem to get worst. Gap the valves is recommeded every other year
Posted on Jun 14, 2010
Testimonial: "Put me on the right track. Machine runs great!"
Wont go when warm
If you mean it won't start after the mower gets hot, that is usually a fire or coil issue, maybe even coil adjustment. You have to check for fire and adequate fuel as soon as it happens.
Aug 02, 2014 | Simplicity Broadmoor 20hp Briggs &...
Why is my 20hp B n G Keep flooding?
check that the float valve is closing fully may have dirt under seat.
Aug 27, 2012 | Briggs & Stratton Starter Scott's Equip...
Why won'y my 20hp Craftsman Yard Machine riding mower start?
when changing the belt you might have knocked off a wire to a safety switch
Apr 17, 2012 | Yard Machines Garden
20hp Briggs head torque specs
The following site details te Torque Specs for the 20hp Briggs.http://www.ehow.com/info_7929485_briggs-hp-twin-torque-specifications.html
Oct 02, 2011 | Yard Machines 155 Torque Briggs Stratton...
B&S 20hp craftsman 46" dls3500
When you cleaned the carb did you clean out the metering jet with a needle and blow out. It only takes a tiny spec of dirt to raise hell with these small carbs.
May 29, 2011 | Craftsman 42" Briggs Stratton 20 hp Gas...
Lt1000 20hp. briggs electrics on carb it will run when you pour i
Check fuel lines for clogging.Thanks for asking and I hope this helps out.Please leave me 4 thumbs up.
Jul 13, 2010 | Craftsman 20 hp 42 in. Deck Lawn Tractor -...
Jun 14, 2010 | Briggs & Stratton Briggs Stratton Intek V...
Garden Logo
21 people viewed this question
Top Briggs Garden Experts
Mike
Renee Knafel-Bullock
Are you a Briggs Garden Expert? Answer questions, earn points and help others
