What year was 'call the tune' australian tv program released and who were the stars
How do you tune a samsung tv that has come from New Zealand (tuned into NZ tv) to Australian free to air channels?
if no user guide ...look for one on internet
at first set up.. this TV it may not have country option
if it doesnt and only show Nz options
would suggest tuning that TV in with an australian digital desk top box
Mar 01, 2017 | Samsung Televison & Video
Programming radios
You must use a compatible programming cable and software (such as Chirp) to program the radio, and the frequencies must be within the radio operating range [400 - 471 MHz].
Feb 26, 2014 | Baofeng BF-888 S UHF 400-470 MHz Portable...
We're in Australia. When we scan for channels via PS3 Play TV we can't get any ABC channels (we do through our normal TV). How can we fix this please?
I am presuming you purchased it in Australia.
If it's under warranty, take it back.
If it's not under warranty, take it back anyway.
You could argue that as it is not able to tune all Australian stations it is of Unmerchantable Quality, use those specific words, meaning it was not good enough to be sold.
Alternatively you could locate your local Sony service center here;
www.sony.com.au/section/servicecentres
I would hope that you will be able to resolve it without politely inquiring if the media would be amused to hear about a TV tuner sold in Australia that couldn't tune Auntie. Er, i mean the ABC, mate
Feb 06, 2011 | Sony Play TV (PS3) (711719486152) TV Input
Hi, I have just shipped a SHARP LC-37AD1E tv over from the UK (where it worked fine!) It is one of the early models that has a separate media box. It has tuned in fine to the Australian channels BUT there...
No. The audio and video signal must be decoded first before you can connect it to the home theater system. Your Australian channels might be different from the UK's. Try a decoder box made for Australian stations.
Dec 04, 2010 | Sharp Aquos LC-37G4U 37 in. HD-Ready LCD...
Do you know how to program a dish remote control 3.1IR?
Hello huybug3309, my name is Michael Hurst with DISH Network. The link that will be in this post will show troubleshooting steps to program your 3.1IR remote to your receiver. http://www.dishnetwork.com/SupportSection/remote-control. If you need to program the remote to your TV you can use the remote code for the maker of the TV. You can also use a power scan. With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button: Press 0 for a TV. Press 1 for a VCR/DVD, Press 2 for any other device. Then Press STAR (*) Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times
Apr 01, 2010 | DISH Network IR Remote Control
How do i program dish network remote to tv ?
Hello sashamarin66, my name is Michael Hurst with DISH Network. I see that you need some assistance with programming your DISH remote to your TV. There are 2 ways to program your DISH remote to the TV. The 1st way would be to use a remote code for the make of your TV. To use the code would need more information on the Maker and the type of remote that you have. The 2nd way to program your remote is to use a Power Scan. Here are the steps for a Power Scan: With the desired equipment on, press and hold the correct Mode button until all mode button backlights illuminate, then release. Press and release the Power button. AUX Mode: Before pressing and releasing the Power button. Press 0 for a TV, Press 1 for a VCR/DVD and Press 2 for any other device. Then Press STAR (*). Press the Up button once a second while pointing the remote at the desired equipment. If the code for the equipment comes up, the equipment will power off. Press the POUND (#) button. If the code entered is valid for the remote, the mode light flashes three times.
Jan 15, 2010 | DISH Network IR Remote Control
We cannot tune our Wega TV
Here's the procedure:
  1. Press MENU.
  2. Press LEFT ARROW to highlight Channel Menu.
  3. Press DOWN ARROW to highlight Cable. Press CENTER BUTTON to select.
  4. Press DOWN or UP ARROW to highlight On or Off according to how you connected your TV. Press CENTER BUTTON to select.
  5. Press DOWN ARROW to highlight Auto Program. Press CENTER BUTTON to search for channels.
  6. After Auto Program finishes, press MENU to exit.
Nov 06, 2009 | Sony FD Trinitron WEGA KV-32FS120 32" TV
Need a remote for Symphonic tv
should be171,179 or 180 Turn on your TV.
On your Tune In remote, press TV and release.
Press and hold Set until the green light on Tune In blinks once, pauses and then blinks twice. Now release the Set key.
Enter the first three-digit TV code for your Symphonic from the list which follows:
171, 179, 180
These codes are listed in order of popularity, and the green light will blink twice if you perform this procedure correctly.
Aim Tune In at your TV and press Power. Your TV should turn off. If it does not, repeat steps 2-5, trying each code listed in step 4 until you find the one that operates your TV.
Now Test Your TV
Why test? Many times more than one code appears to work. Testing is desirable to be sure you have the correct code for your TV or the other devices you are setting up.
Press the Power key to turn on the TV, then press mute, channel scan ("CH") and volume ("VOL") keys. Tune channels 7 and 11 by entering the number followed by the Enter key.
If your TV does not pass the test, return to Step 2 at the top of this page. Enter the next three-digit code and repeat the process.
Apr 02, 2009 | One For All URC-4021 Remote Control
I can't Tune my V32XBR1 in Australia
Greetings...
Are you connecting to a digital signal from a cable box using an HDMI cable?
Ed
Apr 03, 2008 | Sony BRAVIA KDL-V32XBR1 32 in. LCD HDTV
AUSTRALIAN PARTS
the convergence board has nothing to do with tuning of tv, the convergence board put three colour gun (red, green, blue) to work with each other, else you get three image, of red , green,  blue or mixture of all as seperate image, the convergence board for american tv and Australian tv is possibly the same what you check to see the board  part number is the same you possibly need to see if the convergence board has got the memory i.c. if that is the case, you need to tune you t.v reset the channel etc good luck.
need more help let me know.
Oct 09, 2007 | Samsung HLR5067WX 50" Rear Projection HDTV
Televison & Video Logo
23 people viewed this question
Top Televison & Video Experts
