Question about Ryobi Drills
On a ryobi 40 volt battery what does t1 and t2 stand for
  • Ryobi Master
  • 3,498 Answers
(+) (T2) (T1) (-)
Posted on Jun 26, 2017
  • 78 Answers
SOURCE: ryobi 18 volt battery wont charge
no its best just to replace them
Posted on Jan 05, 2009
  • 285 Answers
SOURCE: 18 volt batteries
Yes you can, as long as the batteries are the same style and fit the older Ryobi tools. The Ah rating is a capacity rating. The higher the Ah, the longer the battery will last so the 1.7Ah will just last a bit longer than the 1.5Ah batteries, but yes you can use them on older 18v Ryobi tools. I do it all the time.
Posted on Mar 01, 2009
  • 4 Answers
SOURCE: can't set columbia CL-5009. Display is on T2, want T1
Try holding the st/st button while on time display
Posted on Mar 19, 2009
  • 103 Answers
SOURCE: dead ryobi 9.6 volt battery recharge?
email me i will send you the instructions ,,its easy and it works ,,,to cheers peter
Posted on Apr 12, 2009
  • 233 Answers
SOURCE: a/c compressor runs, no fan
did you ohm the relays to verify a correct path? It sounds like the relay contacts are not "making" and providing a pth for flow.
Posted on Jul 12, 2009
Op 400 40 volt ryobi charger output voltage
IT most likely is not 40 volts! It can be 20 or less. Depends on the battery configuration. There can be 2 twenty volt batteries in series and the charger charges them in a split configuration.
Apr 01, 2017 | Ryobi Drills
Which is the right partner of T1? IS THE T7? OR THE T4/ OTHER T2.IS THE T8 OR THE T5?
One needs to know what the voltage and phase(1 or 3) the unit is and what the power supply is.
Apr 12, 2015 | Hobart H600 Stand Mixer
I need ang diagram for hobart mixer 9 out wire T1/T2/T3 AND T4/T5/T6, T7/T8/T9 which is the right partner of t1/t2/t3???
Having 9 wires means it is a 3 phase motor.
For 220 to 240 Volts - L1, T1 and T7 go together. L2, T2 and T8 go together. L3, T3 and T9 go together. T4, T5 and T6 go together.
For 440 to 480 Volts - L1 and T1 go together. L2 and T2 go together. L3 and T3 go together. T4 and T7 go together. T5 and T8 go together. T6 and T9 go together.
Apr 12, 2015 | Hobart Food Mixers
I can't set the time on my Adidas ADP6016 digital watch
There is two times possible in this watch ADP6016.
• Those times are named T1 and T2.
• IMPORTANT: When your displayed time is T2, you CAN NOT set the time but just set the offset of T2 relative to T1.
• You can see which time is displayed by looking for a very little T1 or T2 written just above the seconds
• To swap the displayed time from T2 to T1 (or contrary), you have to long press the start/stop button (top right white button)
• When your displayed time is T1, you CAN set the time with the solution given by soulgirljen
just before this one
Aug 29, 2012 | Adidas Digital Watch Adp6016
I bought a new universal ac contactor relay to replaced the o.e.m. the new has l1 l2 t1 t2 . the old relay don't say l1 l2 t1 t2 or any indicatio.
The contactor should look alike. Just make sure the same wires are on the same side as the old contactor. Don't worry so much of the l1/t1 and l2/t2
Apr 05, 2011 | Heating & Cooling
How to conect 3 phase motor 9 yellow wires from p1
Connect t4,t5,t6 together. Connect t1,t7 together for line 1. Connect t2,t8 together for line 2. Connect t3,t9 for line 3.
May 23, 2010 | Omega 5hp 1740RPM 184TC Frame 230 Volts...
Compressor won't switch on, have tried reset switch and circuit breaker, but though the wall unit comes on the compressor wont..anything I can do? This has three phase power Mitsubishi..Mr Slim
If you have any experience in working with electrical systems, you can, but if not you should call a service technician.
First being very careful, check to make sure contactor is engaging.
Then check to see if you have the same voltage across all three wires on the compressor side of the contactor, assuming this is 230 volts, check T1 to T2 should have 230 volts, then check T2 to T3 should have 230 volts then check T1 to T3 should have 230 volts. If you have 230 volts to all 3 wires then the compressor is bad probably an open winding and needs replaced. Before replacing the compressor you need to check the resistance (with an ohmmeter) between all 3 terminals at the compressor. In order to do this you need to disconnect all power to the unit and ohm the compressor terminals from T1 to T2, T2 to T3 and T1 to T3 they should all have the same resistance if they do then the windings are good and the compressor is locked up, if one of the the windings is different then the windings are bad, either way the compressor needs replaced.
Nov 08, 2009 | Mitsubishi Mr. Slim MXZ30TN Air...
Need wiring diagram for 3 phase electric motor
motor leads on a three phase are T1, T2, T3, T4, T5, T6, T7, T8, T9. for high voltage [480] L1 to T1, L2 to T2, L3 to T3, connect together and tape - T4-T7, T5-T8, T6-T9. For LOW voltage [240] L1 to T1 & T7 & tape, L2 to T2-T8 & tape, L3 to T3 & T9 & tape. T4-T5-T6 together and tape.
Oct 20, 2009 | Saws
Coleman evcon moblehome ac question
I would replace them to the exact terminals that they used to be on. Technically speaking L1 and L2 stand for Line one and Line two. This would be the incoming power from the breaker or disconnect switch. T1 and T2 are the power leaving the contactor relay.
Jun 17, 2008 | Heating & Cooling
Setting watch
Alright, so the actual solution probably revolves around the fact you are stuck on "T2" time mode. This is found by a symbol that reads either "T1" or "T2" directly above the seconds. So first make sure you are in "T1" by holding the ST/SP button first, then holding the SET button second and simultaneously. After holding both for a couple seconds, the mode will switch from either T1 to T2 or T2 to T1. Once you get the T1 to be selected, you can then press and hold the SET button. Once that is held long enough, a menu will pop up saying "Chime" as the first display. Press the Mode button to start displaying the other features, such as hour, minute, second, month, date, etc. To make changes within a selection use the ST/SP and RESET as up and down changes. When you are all done and back to the Chime feature, you can press SET to exit out of the menu.
As a side note, the T2 function is based off your T1 time, so if you are in a different time zone, you can offset the time by however many hours you off from the T1 time - but the key is to get the T1 time set first.
Hope this helps.
Nov 12, 2007 | Columbia All Sport Digital watch
Drills Logo
295 people viewed this question
Top Ryobi Drills Experts
Are you a Ryobi Drill Expert? Answer questions, earn points and help others
