Heating and cooling of wat? Compressor ? - Heating & Cooling
Compressor no start in heat or cool mode
is this HEAT PUMP , SPLIT SYSTEM ? COULD BE LOW FREON PRESSURE SWITCH, LOW VOLTAGE SHORT OR BAD COMPRESSOR, RECOMMEND YOU GET A SERVICE COMPANY OUT FOR THIS ONE
Feb 24, 2017 | Heating & Cooling
1996 amana top freezer refrigerator not cooling
Check power to and from thermostat and to compressor relay. If compressor powered but not running, compressor fault. If compressor running but no heat in condenser, short of gas. If compressor running and heat only in first rungs of condenser, compressor poor pumper and needs replacing.
Apr 28, 2014 | Refrigerators
Honeywell thermostat does not trigger heat pump compressor
Sounds like a bad board outside.
If you need further help, reach me via phone at https://www.6ya.com/expert/thomas_092728000e6acb79
Sep 10, 2017 | Heating & Cooling
I have a Rheem heat pump/air handler; it draws 2.9amps with only the fan running, 13amps when the heat pump is running and 38amps with the heat strips on. My question is why the unit draws that many amps...
Sounds like it must be about a 2.5- 3 ton system. The 13amps has to be the compressor draw -normal. and 38 on the strips- normal. 2.9 fan -normal.
You may want to check your wiring to see where the outside unit gets its power. Theres nothing inside that can draw 13 amps. That almost has to be the compressor power wire.
Jan 27, 2011 | Heating & Cooling
Cools but no heat compressor or fan doesn't come on but on cool cycle
generally compressor will not come on in heat mode is this a heat pump or combo heat ac unit if outdoor unit look for overload button on unit itself
Oct 06, 2009 | Heating & Cooling
Fan runs, cooling and heating do not.
sounds like capasitor blew, or bug or snake or someyhing got into compressor area if outdoor heatpump or unit, could be snails also. if so might have killed compressor or something else electrical
Jun 14, 2009 | Heating & Cooling
Will not switch to cool mode. heat and fan work fine
hi,
regarding on switch mode theres a common line between heating and cooling although fan is always connect on them.,also with the thermostat,the sequence on this when you switch to cooling and your connection is on heater,the contactor will shift to compressor source,so if there is no cooling, the contactor supplying the compressor is not functioning when you switch on cool mode.try to tighten screw on compressor relay maybe only loose.on control panel,or check continuity of compressor if the compressor still good,check also the freon charge using clamp ammeter,this should be done by ac technician.have a nice day
rate me up,thank's
Apr 26, 2009 | Heating & Cooling
AC Compressor
Does not sound right to me.My guess after doing what every he was doing he probably installed a start capacitor or repaired a burnt wrie, got the compressor running and charged for a lot of guess work. Just guessing.
Jan 04, 2008 | LG Heat cool Window Air Conditioner
Heating & Cooling Logo
Top Heating & Cooling Experts
Paul Carew
Tim Whalen
