Wat is H3 error in bluestar split Ac? - Heating & Cooling
  • Heating & Co... Master
  • 2,994 Answers
Hello Yogesh...
Unless you are familiar with the BASICS of REFRIGERATION...
"H3" ERROR CODE means it is "Out of ORDER"...
Broken: Needs repair.
By searching the internet "split A/C " It defines a
COMPRESSOR overload protection is trying to
SAVE your equipment FROM SELF DESTRUCTION.
See second detail sheet (below)
"COMPRESSER"
Is the heart of MOST modern refrigeration systems.
In a SPLIT system it is the outside unit with the FAN
that should be running when the COMPRESSER is
in action. Typically then compressed & COOLED
REFRIGERANT is then piped into a cooling element
EXACTLY LIKE MOST REFRIGERATORS where the
cooling takes place (expansion valve and evaporator).
Treated AIR (indoor) is then blown through the
evaporator... cooling the room and warming the
refrigerant (which continues to cycle back to the
outside unit where the compressing cycle
continues until the INSIDE temperature is
achieved... (thermostat on the wall)
"COMBINED"
pretty much means EVERYTHING but those combined refrigeration units seen WORLD-WIDE HANGING OUT OF WINDOWS... or on roof-tops with DUCTING for
"treated AIR" to be pumped where needed.
Similarly heat pumps simply have reversible valves...
which turn the coils around (functionally).
There too are split-system (inside/outside) & combined units.
Excellent refrigeration primer (below)
https://camec.com/cameccatalogue/documents/000948_IbisTechManual1.pdf
Alarm Codes
Gree Air Conditioners Error Codes
Hope this helps.
Carnac the Magnificent
Posted on May 13, 2017
4 Suggested Answers
hvac1960
  • 2133 Answers
SOURCE: Bluestar split ac indoor unit making abnormal
From your details i can observe the blower motor bearing worn out. or its side bushes in which there is small bearing that may be worn out. Replace it. Finally check for correct voltage too.
Posted on May 07, 2014
  • 47682 Answers
SOURCE: My bluestar split ac 3.ton showing on display light blinking..what is problem
could be a control board either in the inside unit or the outside unit
could be a simple start/run capacitor for the out side unit
best get a technician out to check it out so that you get the correct diagnosis and quote for repair.
Posted on Sep 16, 2015
SOURCE: E6 error in bluestar s split AC how to rectify
your ac is warranty status , please change
Posted on Feb 19, 2016
Whatis ideal r22 gas pressure required in 1 ton split ac of BlueStar.
Doesn't matter how big the unit is, pressures remain the same. On a satisfied temperature, approximately 75 degrees, r22 should be around 65 psi. The hotter the house, the higher the pressure. Head pressure varies on outdoor temperature. 90 degrees outdoor temp, approximately 200 to 225 psi on high side.
Jun 05, 2017 | Heating & Cooling
H3 Error in bluestar... is it compressor problem?
Typically no... Yogesh,
It is a compressor overload...
(look outside... Is a dump truck parked on it...??
(perhaps the winter cover is still on top??)).
Over-charge of refrigerant, crushed plumbing,
clogged DRYER, defective expansion valve..
condenser cooling fan is slow (or no go).
If you were to disclose the recent history... A blind,
remote, poorly informed FIXER might be able to point
you in the right direction. ... or you could just continue
throwing "is it?" games... and get answers that are just
as valuable... (not much).
One possibility is the compressor... Many opportunities..!
An experienced refrigeration person could look directly at the system...
The only thing you keep repeating is
H3, Bluestar & compressor...
You could try helping... Pretty please?
May 13, 2017 | Cars & Trucks
Feb 19, 2016 | Heating & Cooling
Sep 16, 2015 | Heating & Cooling
Crafft. What is error code H3?
MY SPLIT AC IS SHOWING "C5" ERROR CODE. KINDLY HELP ME PLEASE.
THANKS
Aug 26, 2015 | Heating & Cooling
What have do in bluestar split ac when F2 error shown
Its a Copper tube Sensor which has gone faulty. Kindly get it replaced.
May 15, 2015 | Heating & Cooling
Bluestar split ac indoor unit making abnormal noises. I have a 5 star 1 ton bluestar ac model 5HW12ZBI. It makes noise (kit -kit) when the ac trips off. The noise is minor during day time but it Ibecomes...
May 07, 2014 | Heating & Cooling
F8 dispaly error in blue star split ac
hello,
i also find this problem in my bluestar ac then i callled authorized service man . then he did these steps :-
1> Replace the sensore ( you will find inside the ac wich will be red or brown in color)
2> then check wheather the wire is in good condition or not means
is it working or not.
3> then clean the outdoor unit filters and coils,
4> and check the proper supply of electricity..
Mar 15, 2013 | LG LS-L1210CL Mini Split Air Conditioner
Heating & Cooling Logo
644 people viewed this question
Top Heating & Cooling Experts
Paul Carew
Dan Webster
Dan Webster
Tim Whalen
