Question about SWANN Home Security
We have an jvc 42 in.genessa and hdmi input not working,reason? we have security system swann 4 cameras.trying to get cameras tro come up on hdmi ports and no camera or sound.
  • 103 Answers
SOURCE: HDMI Malfunction
You may have to activate that imput through your menu.Alot of plasmas have the ability to mute imputs.
Posted on Mar 03, 2008
SOURCE: HDMI no longer working
JVC AV-48P575 HDMI reset procedure:
1. Unplug HDMI cable from tv.
2. Unplug the tv.
3. Remove the rear (low) back cover.
4. Find the 6 pins on the board of the HDMI module and shortcut the pins no.1 and no.2 using a jumper(i use an old hard drive jumper).That's the higher to pins if you can't see the number.
5. Put back the rear cover.
6. Plug the tv.
7. Turn on the tv.
8. Unplug the tv(without tunrning it off).
9. Remove the back cover.
10. Remove the jumper on the pins 1 and 2.
11. Put back the rear cover.
12. Plug the tv and you're done.
Posted on Nov 07, 2008
  • 5 Answers
You have to use the scart connector for on screen menu settings. Go to the video option and enable HDMI and/or match resolution output to your set.
You did not mention the model of the TV so here is another scenario,
Just because the TV is 1 year old doesn't mean that it is a 1080p capable, you could have set the HDMI resolution settings to 1080p and you will not get any picture if your set cannot process the information.
Posted on Jul 03, 2009
SOURCE: Westinghouse 1080P 42" LCD TV - HDMI stopped working
Just reset the TV found out how here:
Hold the power button for 10 seconds.
Posted on Jul 26, 2009
I know this is late, but this happens frequently. If anyone else has the same problem try unplugging the TV for 60 seconds. Plug it back in and then hold the power button down for 30 seconds. That will reset the TV.
You should see the Westinghouse logo come up and the HDMI should work. This has happened twice with my TV in 1 year.
Posted on Sep 26, 2009
How do i connect swann cameras directly to tv
Ashley, I believe you can with a HDMI cable or VGA cable. Check the attached links,instruction and guides, Good luck
"I hope this helped you out, if so let me know by pressing the helpful button. Check out some of my other posts if you need more tips and info."
Video Instruction Guides
Home surveillance systems dvr camera system Swann
setting up swann
May 14, 2016 | SWANN Home Security
Hi is it possible to get a user guide for DVR4-4150 I have trawled the internet and swann but no joyu
No printed manual seems to be available, although Swann does have video instructions available here:
Apr 28, 2016 | SWANN Home Security
I have a swann view security system ,,and something not working cause it only says mode not supported ,,,,, how do you fix this
Have you tried a hammer? Kidding!!! Usually this is a conflict in resolution between the DVR and the TV. You may need to lower the resolution of the TV for the particular input you are using. You may have a 1080P TV and a 720P DVR. Once they match, the issue should be resolved.
Aug 30, 2015 | SWANN Pro-Series DVR-4200 4-Channel...
Replace camera on swann system
Yes it is not a complicated procedure, involves just disconnecting the power and video cables and remove the screws of the old cameras.
Jan 03, 2014 | SWANN Security Swa43-d1c2 - Swann Secu...
My Swann DVR8-3000 HDMI output on LGTV is red all over but the video is visible,I tried restoring the default setting and even tried adjusting the resolution but no luck.Could it be that the HDMI output is...
have you checked the system on another tv. or monitor. if is the same on these then the graphics on the dvr has gone wrong. if its is just on the tv hdmi then you have had the tv on the hdmi for a to longer period and blown the reader board for the hdmi.
Aug 12, 2013 | SWANN DVR8-3000 TruBlue 8 Channel D1...
Perfect sound but no picture on JVC 42" Genessa LCD HDTV
Ur LCD inverter board is dead.Replaced this inverter board,u will get the picture back.Tries Websites like, to buy a refurbish LCD inverter board for the replacement.It a long shape board.
Apr 20, 2010 | JVC LT-42X688 42 in. LCD HDTV
Cant hook up HDMi cabe from PS3 to JVC
1. check the input that the PS3 is connected to
2. select that input on the TV
3. Press and hold the [power] button on the PS3
4. perform the video setup for the PS3
My guess is that you don't have the HDMI setting correct on the PS3.
Apr 15, 2009 | JVC LT-42X688 42 in. LCD HDTV
PS3 not working on 42'' JVC via HDMI cable port
I have the PS3 and this TV and it works....Try this.
1. Turn ON TV
2. Connect HDMI from TV to PS3
3. Select the correct HDMI input on the TV for the PS3(important)
4.Turn OFF PS3 if it is ON.
5. hold [I/O] Power button on PS3
6. Wait about 5 second and you should get the "HDMI Detected" or some similar message.
7. Configure the HDMI output for the PS3
Also, If you set the PS3 to "auto" for hdmi, it may set the resolution to 1080i. You may want to deselect everthing but the 1080P.
Mar 24, 2009 | Sony Playstation 3 40GB System Console
JVC LCD TV (LT-42X688) input panel not working!
1. This TV has setting for the HDMI input that allows you to select the HDMI Audio or Analog(red/white wire) audio. Make sure this is correct
2. Most cable boxes are DVI not HDMI. If DVI then you actually do need to use those Red/white cables. If HDMI, refer back to #1.
3. The cable box has a setting to select the Audio output, HDMI (digital) or Analog(red/white cables). Just like #1, this has to be set.
4. Contact your cable company to help you set up the box correctly. JVC can probably help you check the TV
Mar 05, 2009 | JVC LT-42X688 42 in. LCD HDTV
Swann surveillance system at home
Try and take down the firewall. Then try remote access.
If that does not work . check the port forwarding settings on your router .
Dec 20, 2008 | Swann Communications DVR4-Pro-Net...
Home Security Logo
46 people viewed this question
Top SWANN Home Security Experts
Todd Arndt
Todd Arndt
Are you a SWANN Home Security Expert? Answer questions, earn points and help others
