Question about Garden
I have a Rover Mini Rider mower and I need to know how much oil is needed for an oil change please?
  • 10865 Answers
SOURCE: murray belt manual for a 20hp 46" rider lawn mower
here is a link to all of the murray manuals, for free. pick out your model and enjoy your manual.
Posted on Jun 02, 2009
  • 149 Answers
SOURCE: transfer case oil change- 1999 Land Rover Discovery II
No need for a diagram, to drain the oil, there's a drain plug on the bottom of the transfer box, under the handbrake drum. To fill, the fill plug is about in line with the centre of the handbrake drum and to the left. I think both plugs are 1/2" square. Fill to overflow with Texaco Multi-Gear 75W/90R. Takes about 2L or so.
Posted on Feb 25, 2010
  • 10 Answers
SOURCE: we have 42'' Yard Man riding lawn mower need to how to change oil
it's a square head pipe plug @ base of eng. either right or left side of machine may also have a quik change fitting instead its black plastic w/ yellow cap
Posted on Apr 12, 2010
Testimonial: "Thanks for the info, you where right on the money.. I finally found it, its on the right side if you were sitting on mower. Thanks again!"
  • 21 Answers
SOURCE: oil change?
The Filter is on the front, bottom of the engine. It will be tight to get off and must be screwed back on tightly or it will leak.
Oil drain plug is at the rear of the engine, facing backwards.
Oil filling is under the RHS rear chrome cover, two hex socket screws to undo.
C90 takes about 4.5 litres to fill with an oil filter change, 4 litres if you dont cange the filter.
After refilling make sure to hold your bike upright and check the sightglass under the filler. Oil level should be between the markings on the housing.
Posted on Jun 12, 2010
wd4ity
  • 4565 Answers
SOURCE: need to know how to
There are two plugs on the bottom of the transmission, one for the engine oil, one for the tranny lube. The engine oil drain is the one that is closest to the left front corner of the oil pan. The other plug is the transmission.
The engine requires three quarts of oil, the tranny takes 20-24 ounces of oil.. Check the engine oil with the bike on the side stand. There are two marks on the dipstick. The upper mark is the "FULL HOT", the lower mark is the 'FULL COLD" mark. Keep the oil level between these two marks and do not overfill.
On the transmission, on the right side of the transmission, you'll see a chrome clutch release cover. It's behind the exhaust system. There is a plug that takes a 3/8" Allen or Hex key to remove. Check the oil level with the bike standing straight up.
As for what lubricants to use, I always use nothing but Harley-Davidson oil. 20W50 Syn 3 oil in the engine, transmission, and primary on 2000 and later model bikes. However, you can use other oils such as Amsoil, Royal Purple, Mobil, Motor Factory, and many others. Synthetic or petroleum based, your choice. Check the website of the manufacturer that you wish to use.
Good Luck
Steve
Posted on Sep 03, 2010
Where is drain plug to change oil 875 Briggs's and Stratton on my scottbonner mini rider
Most B & S engines have a drain plug at the bottom of the engine underneath . It is usually a square looking nut different from the rest. Check on the side of engine as well for a square looking nut as well.
Dec 02, 2016 | Garden
I have a mini rider where do I drain oil on 875 Briggs and Stratton
it should be on the bottom of the engine on the left or right side. be a square plug
My toro fh 580v smokes when i start it what is causing it to smoke?
hi.. your inlet valve stem seals are worn out, so oil will be drawn into the inlet with vacuum , as well as fuel...this is why it smokes on start up...quick fix , do an oil change but use a car oil like 15W40 weight oil
im sure you would be using a 10w30 oil now ,using a thicker oil might stop the smoke on start up, or it just wont smoke as much, regardless of using a thicker oil...the valve stems will still need to be replace.....good luck
May 16, 2014 | Toro Zero Turn Rider 74833 Lawn Mower...
Craftsman riding lawn tractor shuts off when coming off the brake
There is a safety switch in the seat that shuts the mower off if there is no rider. The mower stays running when the rider gets up ONLY if the brake is set. The switch under your seat is broken and cannot sense that a rider is on the seat. Therefore, the engine can only run when the brake is set. Depending on the mower, the two wires need to be connected (or disconnected) when a rider is in place. I do't know what mode your mower needs but it shouldn't take long for you to figure it out.. The safest thing is to confirm the seat switch is the issue then change the seat if replacements are available. Good luck Please rate me Mark
Jun 04, 2011 | Craftsman 42 in. Deck 19.5hp Lawn Tractor
I have a hydro gear transmission i have changed oil and when it gets hot it will not move it is a simplicity rider 2000 mod.i need help please my email is wunrau@mymts.net thank you kindy
Your transmission is shot. You need to buy a new or used one and install it. Or there may be a rebuild facility which will rebuild yours. Either way it will not be cheap.
Aug 12, 2010 | Garden
I have a Husqvarna Rider 155. Does the transmission oil ever need to be replaced? Is there a filter ? If so how do I change it? Where can I get a SERVICE manual?
Not an expert but have a rider 155. After looking at diagram on partstree.com, it does not appear to have a filter. Just a magnetic drain plug. This is the only site I have found for info and parts.
Apr 21, 2010 | Husqvarna Garden
We have 42'' Yard Man riding lawn mower need to how to change oil
Apr 12, 2010 | Mtd LAWN MOWER PART # 683-04163B FRAME...
Can I print out the maintenace manual for Cub Cadet Mower
I need the serial number so that I can locate the manual
Jun 16, 2009 | Garden
Change hydrostatic transmission oil
we have tractors and, yes any of those drain bolts will work (for best results do both) then after its drained, put the drain bolts back in and top up the level
Oct 27, 2008 | Husqvarna Garden
Garden Logo
Top Garden Experts
Dennis Key
Dennis Key
roeb
john h
