Question about Ovens
Why is there water in my oven after I do a roast
How to defrost a roast lamb in a vario stream oven
Have a read of this. I am a chef and would advise the traditional way.
Cooking a Frozen Roast Without Thawing - Cooking - eGullet Forums
https://forums.egullet.org/topic/112634-cooking-a-frozen-roast-without-thawing/
Feb 5, 2008 - 25 posts - ‎15 authors
So now there's a 10 or 11 lb. beef shoulder in the oven. ..... roasts with additional water added as required were put into a large steam kettle to ... This works with any meat Pork, Lamb, Beef or even Frozen Turkeys especially at ...
defrost roast lamb in vario stream oven Google Search
Apr 30, 2017 | Ovens
Tip
Cleaning an oven
Put ammonia in your roasting dish and leave in your oven overnight. Make sure you use a mask. the next morning wipe out your oven with soapy water and rinse. grease will just wipe off your racks etc
on May 28, 2014 | Ovens
Beef tri tip roast in oven
Directions
  1. Rub roast all over with thyme, basil, marjoram, mustard, salt, and black pepper. Place meat in a sealable plastic bag, seal the bag, and refrigerate, 8 hours to overnight. ...
  2. Preheat oven to 450 degrees F (230 degrees C). ...
  3. Place meat in the prepared roasting pan.
  4. Roast in the preheated oven for 15 minutes.
Tri Tip Roast Recipe - Allrecipes.com
allrecipes.com/recipe/240779/tri-tip-roast/ Beef tri tip roast in oven Google Search
Dec 21, 2016 | Ovens
How long to roast 0.88kg pork leg?
1 hour at 350 deg or 175 c
Apr 29, 2016 | Ovens
How to oven roast pork shoulder roast and at what temperature
There are hundreds of internet recipes for pork shoulder (or porkbutt--which is just a couple pieces of pork shoulder that are butted together and tied with string).
roast pork shoulder Google Search
Apr 17, 2016 | Ovens
How long to I roast
What are you roasting and what temperature?
Nov 28, 2015 | Ovens
After about a hour roasting at 150 water leaks out of the oven
If I were a betting persn then it would be that your pot /bowl whatever it is was too full that its getting ready to BOIL over
Apr 15, 2015 | Ovens
Seams to be a lot of steam/ vapour in main oven. when you open door cluds of steam escape. This is the 4000 twinline all electric model.
I have an electric oven and the same problem: loads of steam when I open the door. Plus roasting is a problem, the pan fills up with water and needs to be drained so things are stewing and not roasting. Have spent ages trying to to find a solution so would also appreciate any advice.
Oct 17, 2010 | Ovens
How best to cook turkey. What setting?
hi friend,
step 1
Preheat oven to 325 degrees F.
  • Step 2 Remove turkey from its wrapping and remove neck and giblets from inside the cavity. Set aside to make gravy later (see Related eHows).
  • Step 3 Rinse turkey inside and out with cold water. Pat dry with paper towels.
  • Step 4 Put oven rack on lowest level of oven.
  • Step 5 Place turkey, breast side up, on a roasting rack in a roasting pan.
  • Step 6roast1s.jpg Rub the outside of the turkey with olive oil.
  • Step 7roast2s.jpg Salt and pepper the turkey's body and cavity.
  • Step 8roast3s.jpg Roast turkey about 3 hours, or until a meat thermometer inserted in the thickest part of the thigh registers 175 to 180 degrees F.
  • jQuery('.article ol .image').each(function(i,e){ var $this = jQuery(this); $this.find('img').error(function(){ jQuery(this).remove(); $this.remove(); }); }); Tips & Warnings
    • In general, a turkey should be roasted 10 to 12 minutes per pound if it is not stuffed and 12 to 15 minutes per pound if it is stuffed.
    • In general, you shouldn't cover a roasting turkey (or any roasting meat); you want the skin to get a nice, deep brown all over, and you don't want it to steam in its own juices. However, if the turkey begins to brown too quickly, well before it's likely to be done, you can cover the brown parts loosely with aluminum foil. (This is likely to happen with larger birds.) Try to cover as little of the turkey as possible so you don't create steam.
    • Be sure to check out other eHow turkey recipes - search the site for "turkey."
    Who Can Help Sponsored
    • How to Lose 30+lbs Guaranteed. Try it Free.
    hope this helps u
    please rate me..........................
    thank u for using fixya
    regards
    sivaranjini
    Nov 26, 2009 | Viking Ovens
    Nesco 18 qt. Roast-Air-Oven/ Manual
    You could contact the manufacturer they would have one. Nesco www.nesco.com 1-800-288-4545
    Sep 28, 2009 | Ovens
    Ovens Logo
    Top Ovens Experts
    Dan Webster
    Dan Webster
    ashburton
    Are you an Oven Expert? Answer questions, earn points and help others
