Thermal dynamics cutmaster - Computers & Internet
3 Suggested Answers
  • 9 Answers
SOURCE: plazma cutter/no arc
The Cutmaster 50 used two different CD "Capacitor Discharge" Boards. The only ones I have seen a lot of issues with were the smaller ones that are 3.5" X 4"
I have worked on several of the them over the last few months. Even though you might see a spark at the spark gap on the board it might not be sufficient to create a pilot arc.
If your air pressure and so forth are correct your issue is most likely the two white capacitors on the CD board.
Posted on Nov 07, 2009
luis_david
  • 407 Answers
SOURCE: Thermal Dynamics cutmaster 81.
Hi; Check the following troubleshoot and see if you can ID the problem:
Problem: Gas flows continuously when power is turned on, AC indicator flashes 1. Torch switch is activated (closed) before user turns power on. a. Release torch switch. 2. Faulty torch switch a. Check torch switch for continuity. Replace if necessary.
Problem: Gas flows continuously; Torch will not pilot when torch switch is activated; AC indicator ON 1. System is in SET mode a. Change to RUN / Rapid Auto Restart / SET switch to RUN (up).
Mostly of the problems found is that customer has the switch line on to SET instead of RUN.
Hope this help. Have a good afternoon.
Posted on Sep 16, 2011
Cigweld transtig 16 pi
hi saluka.
not sure if this link will have the manual but have a look.
do not go into anything thats says fixya.it will not help you much.
Cigweld transtig 16 pi User manual Google Search
Mar 23, 2014 | Thermal Dynamics Thermal Arc - W1003603 -...
Thermal Dynamics cutmaster 81. when turned on it cycles blowing air but no arc. two green lights are flashing. pulling the trigger doesn't do anything, air keeps cycling
Sep 16, 2011 | Welding Tools
My Thermal Dynamic Drag Gun Plasma Cutter runs but cant blow its arc. Bit of spark, Bit of air, then just refuses to blow its arc. Was working well and with new tips and electrodes but then just refused....
Hi:
There is no mention of the Thermal Dynamic's gun model, but i will suppose that it is a SL60 or a SL100 which are replacement guns for any model of plasma using the proper adaptor.
Your problem could be the start cartridge which go bad now and then when the gun is used as a replacement of a hammer to make the cut piece to fall.
The way to check if your start cartridge is in good condition is by checking the low part of the cartridge, push it up (or down depending on the way you handle it) it should freely slide inside and return out.
Good luck.
Jun 16, 2011 | Miller SPECTRUM 375 PLASMA CUTTER 903891...
The exclamation point, the red dot, keeps popping up and it is also red on 85-5.9 and only air is blowing out
Try and replace the swirl ring. We had the same problem and it fixed it. They cost around 35 bucks
Dec 10, 2010 | RTO THERMAL DYNAMICS CUTMASTER 52 PLASMA...
Plazma cutter/no arc
check pilot/output board
Sep 05, 2009 | Welding Tools
Plasma cutter problem - is cutting on beveled angle.
worked on units for several years,my first thought was torch consumables,then torch itself,so here we go.make sure all the consumables are exact for the torch,make sure all parts are brand new,(all parts,that way we can elimenate that part of trouble shooting).check that the ground is tight on the unit and work peice.When you bought the new torch head did you also buy the lead to the head?If not possible that could be the problem.
May 16, 2009 | Welding Tools
Thermal dynamics cutmaster 50 2004 yr.
Check contacts in tip and be sure it is all lubed correctly. If you have good air pressure and flow it should arc after pulling the trigger for about 2-3 seconds.
Sep 27, 2008 | Welding Tools
Computers & Internet Logo
100 people viewed this question
David Payne
David Payne
