Question about Fisher Washing Machines
Fisher & paykel Washsmart washing machine will not start when I press Power button. It is plugged in to power but nothing happens. Ann Kerley
  • 1294 Answers
SOURCE: washing machine
Plug off the wall. Open up behind to see if all connections a fitted securely. Especially from the control unit to the motor................
Posted on Dec 01, 2007
  • 351 Answers
SOURCE: Fisher and paykel smart drive... Water does not go in
check the reed switch under the lid (magnet) and the cold water may be just a cold valve they get slow flow common problem
Posted on Mar 02, 2008
SOURCE: fisher and paykel 7.5 smartdrive washing machine, no power
If there is power and all your lights are lighting up but you get no responce from the machiene eg no spin, water filling, wash cycle or drain then it will be the sensor for the lid it will have coroded but this is an easy fix , I hope this helps
Posted on May 17, 2009
  • 712 Answers
SOURCE: fisher & paykel 501 smart drive washing machine
It does not seem like a problem of the unit. It might be a loose connection of supply code. Keep the supply code pressed to the unit in different directions and see if the unit takes power. If so, replace the supply code. It's not that expensive.
Posted on Jul 05, 2010
  • 713 Answers
SOURCE: MW512AU Fisher and Paykel top load smart touch
Hi Des, just read your posting.Now when you turn on the machine you say that some lights light up and it starts to beep.These lights will be in a row of 8 lights.Starting from left to right which lights are lit when the machine is beeping?Is it he 3rd and 5th or the 2nd and 7th ---etc---?Please reply with additional information on the question and I can help you rectify the fault.Looking forward to your reply.
Posted on Aug 18, 2010
Fisher & Paykel washsmart washing machine model wa1068g1 was displaying error PUE-F and now will not switch on there appears to be no power to the unit
Pump Impeller is jammed cannot turn
has over-current power supply.
Small black chip near the small transformer has blown.
May 23, 2017 | Fisher Washing Machines
Is it possible to reduce the washing time on Fisher & Paykel 10kg washsmart machine? The quickest wash is 35 mins.
the wash time is set in the program board and that time is what the manufacturers consider necessary for a clean wash
Sep 19, 2016 | Fisher and Paykel Washing Machines
Fisher and paykel washing machine GW603 (14 years old) will not power up. When the power is turned on from the power point all the LEDs light up, the machine beeps and then all the LEDs turn off within 1...
What you describe is normal for the power on cycle. If if will not work after this, then you have a problem. If it will not turn on by pressing the power button, try one of the wash type buttons. If it responds to the power button or the wash type buttons and beeps with the start/pause button and the lid is closed, then the lid switch is faulty, if it does not beep and the lid is closed, then the button is faulty and can be replaced on it's own by anyone with some soldering ability.
Aug 19, 2010 | Fisher and Paykel Fisher & Paykel Washer
Fisher and paykel intuitive washing machine not spinning
the pump could have overheated nd burnt out or u could have damaged the controller
Jan 28, 2010 | Fisher and Paykel Fisher Paykel Intuitive...
How do i put intuitive eco on to just spin clothes not a whole wash cycle
press power button press up button 2 times on option button to "wash advance" press adjust button to which ever rinse cycle youd like to use. press start.
Jun 05, 2009 | Fisher and Paykel Fisher Paykel Intuitive...
Fisher & Paykel washer press power button but nothing happens.
you have a blown main power module I can talk you through testing this machine for a secondary fault and replacing the module in live chat
Mar 17, 2009 | Fisher and Paykel GWL11 Top Load Washer
Washing Machines Logo
Top Fisher Washing Machines Experts
Dan Webster
Dan Webster
Are you a Fisher Washing Machine Expert? Answer questions, earn points and help others
