Question about Boating
I have a minkota edrive the motor stop runing in the counsule it shows prop and neutral sign what is the problem with my minkota
3 Suggested Answers
finish line
  • 207 Answers
SOURCE: 60 hp Manier running great when losted all power ,motor runing
take your prop off and look at the hub you have a spun hub or the wrong size prop and it is cavitating or prop washing
Posted on Jul 02, 2009
  • 8 Answers
SOURCE: my brother inlaw got a minkota 40ta all terraine
I would check the battery. If you're using an old or under charged battery you will loose power for sure. Make sure you're also using a 12v deep cycle marine battery as this will ensure proper operation and a longer battery life.
Posted on Sep 07, 2009
2015 mercury 4 stroke 6hp won't shift out of forward gear
Remove the top cover and turn the flywheel back and forth and move the lever to Neutral. Sounds like a tight mesh of the gears holding the selector.
Apr 14, 2018 | Mercury Boating
Why would my 8 horse 4stroke honda outboard motor run fine in neutral but will not move in forward or reverse?
If it stalls out when putting it forward or reverse, then the problem could be a jammed gear train. If it still runs when shifted into gear but doesn't spin the prop, then the prop shear pin may have broken. This is done to prevent engine damage if the prop hits something hard such as an underwater log or such.
Sep 28, 2015 | Boating
Why does the engine stop runing when i do a change down and sometimes at a robot or stop sign (this happen sometimes but at othertimes it does not happen)?
It would help to know what you are working on. Bad EGR (dirty) or IAC motor could cause this, as could bad plug wires or any other tune up item.
Dec 17, 2014 | Cars & Trucks
After taking the lower end off, the prop moved out of neutral. Is there an easy way to get the prop gear lined up back into neutral or is it lust trial and error? This is a Mercury 110 9.8 motor. Thank...
GET YOURSELF A HIGH QUALITY SHOP MANUAL! EVERY MOTOR HAS DIFFERENT SPECS. SPECIAL TOOLS, PROCEDURES....ETC! DO IT RIGHT...OR YOU WILL DO IT AGAIN..GUARANTEED!
Aug 18, 2013 | Boating
The washer door lock light and lock does not work on my Neptune Model # MAH3000AWW. also the cloths don't spin dry they are very wet after the spin cycle.
NEPTUNES HAD A PROBLEM WITH THE WAX MOTOR THAT LATCHES THE DOOR, DISCONECT THE POWER, REMOVE THE SCREWS ON THE TOP OF THE COUNSULE. TIP THE COUNSULE TWARD YOU AND DOWN. YOU WILL SEE THE MAIN BOARD LOOK FOR THE R-11 RESISTOR AND SEE IF ITS BURNT.IF IT IS YOU NEED A NEW BOARD AND DOOR LATCH WAX MOTOR. IF NOT YOU HAVE A PROBLEM WITH THE LATCH ***. GOOD LUCK!
If you need further help, I’m available over the phone at https://www.6ya.com/expert/dude_653d05454b389bba
Jan 16, 2010 | Maytag Washing Machines
Frigidaire dishwasher model GLD2445RFCO is making noise
I have the same problem with my dishwasher. If you remove the kick plate while it is running, There is an electric motor underneath. If you push up and pull forward on the electric motor, the noise will stop. I used a block to prop it up and the noise stopped. You may want to try it.
Jan 08, 2010 | Frigidaire GLD2445RFC Stainless Steel...
Why does my 65lbs minn kota maxxum not run quite?
Fishing string on shaft, runing while out of water(will burn up seals so fast), bent shaft, off balance prop, bad rotor in the electric motor. lots of variables. I bought one that was noisy out of the box, vibrated very bad from the get go
Oct 22, 2009 | Minn Kota Maxxum 70 Freshwater Bow Mount...
Jun 28, 2009 | Light Outboard Motor Boat Bass Fishing...
My brother inlaw got a minkota 40ta all terraine trolling motor that is supposed to produce 40 pounds of thrust. it does not seem to produce even close to that. is it possible that the motor is turning the...
Apr 18, 2009 | Minn Kota Edge 40 Freshwater Bow Mount...
Boating Logo
Top Boating Experts
Steve
Steve
ray gallant
Fabrice Wolters
Are you a Boating Expert? Answer questions, earn points and help others
