Question about Cell Phones
Commonwealth login netbank
What if I don't know my PIN
or my card isn't activated?
If you have your card number and phone banking password handy, you can activate your card and set up your PIN right now by calling us on 13 2221.
May 26, 2014 | Computers & Internet
Have programmed a new pin, but the old pin still works. How do I get rid of the old pin? Have tried multiple times and the new pin works, but so does the old one.
If you hold the smart/learn button in for 6 seconds it will erase all the codes from memory and then program the keypad. Just remember before you start that none of your other remotes will work and you will have to program them.
Aug 14, 2011 | Sears Craftsman LiftMaster Chamberlain...
Im not able to charge my phone ! When plug in the charger it shows not charging stop! Wat should i do.... Please sugest me a way to get rid of this problem..please...!
There could be 2 reasons.
1- Charging pin of the charger is not working properly.
2- The point where you put the charging pin is faulty.
Apr 25, 2011 | Nokia 1112 Cellular Phone
What are the colors on the wire 1999 towncar mass air sensor
BK/WH - Ground (pin 3)
Red - to fuse 20 in power distribution box (maybe under hood) see owner manual (pin 2)
Tan/Lt Blue - signal return to PCM (computer) (pin 4)
Lt Blue/Red - signal (pin 5)
Don't know what your issue is but you should remove it and spray the 2 exposed wires inside with carb cleaner very good. Do not touch the heated wires. This will remove built up varnish and get rid of the lean mixture and P0174 lean codes.
Please rate if helpful.
Mar 18, 2011 | 1999 Lincoln Town Car
How do I get rid of Pin 1 Not Allowed message On a samsumg sgh-e250v Many Thanks Rob
hi i got my contract sim in a pay as you go phone and i tried going into my phone book and it said pin 1 not allowed
Nov 15, 2010 | Samsung Cell Phones
920-fan command 2 pin connector from power supply not connected
then connect the fan to a 2-pin connecter if you cant do it take it to a computer place to do it for you
Sep 22, 2009 | HP Compaq Business Desktop d330 Slim Tower
How do i get rid ov the pin
the sagem pin is 1234 / 0000 / 1111 as standard.
Sep 08, 2009 | Sagem PVR 6280 Freeview DTV Receiver /...
Can't delete pin number from 377LM wireless keypad
The way to do this is to hold the smart/learn button in for 6 seconds. This will erase the memory and none of your remotes or keypad will work. You will have to program them all but your extra PIN will be gone.
May 12, 2009 | Sears Craftsman LiftMaster Chamberlain...
Charging prob...
may be the charger is not correct... if it is correct also the pin hole which connect the cell may have became big.... or ur cell charging pin is damaged.... just try with the another charger... u will get rid of it...
if it doesnt works means surely the charging pin in cell is damaged... get replaced with the technician....
Jan 29, 2008 | Motorola Mobility V235 Cellular Phone
How do you get rid of the Pin Number?
Refer Page 6 of Garmin C550 Owner's Manual. If you forget your PIN number, drive to your security location where you set the PIN and this will unlock the unit. Richard New Zealand
Jun 16, 2007 | Garmin StreetPilot c550 GPS Receiver
Cell Phones Logo
35 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
