Question about The Office Equipment & Supplies
Paslod does not fire new gas cartridges,cleaned . My son dropped it off a ladder landed on the nose. What would keep it from foreign.
2 Suggested Answers
SOURCE: pasload cordless finishing gun - still won't fire
barrel and fan cover 'o' rings may be leaking/ need replacing. item no 17 on the parts diagram.
Do you have a spark, you should just be able to hear the spark firing when the gun is applied to the work surface and the trigger pulled, it sounds like a click.if no spark heard it could be the switch on the fan head not working , a bad ignitor , or the spark is not sparking in the correct place, chaffed ignition wires.
is the gas you are using in date, there should be a date stamp on the gas bottle. if its out of date it can give problems.
Posted on Jul 19, 2009
I have a regency E33 gas fireplace. after 6-7mins with fire on, fire and pilot both go out. any suggestions?
thermopile should show 600mv clean thermopile . clean pilot so its strong and blue . see how that goes, may need new thermopile .
Oct 20, 2017 | Heating & Cooling
Why concord planes have tilted nose.?
the Concord nose drops down for take off and landing since the aircraft has a high nose up attitude at slow speeds. the tilt allows the pilots to see the runway.
Jan 04, 2017 | Aircrafts
Why does my canon mg5250 not copy black and white
Go to the setup, then maintenance menu on the printer and select "print nozzle check pattern"
You should see a complete black ladder pattern (for the fat black cartridge) and a set of coloured bars for each colour cartridge (including the thin black cartridge). If the black ladder pattern is missing then this indicates the black printhead is blocked or cartridge is empty. If you are SURE the cartridge is not dry, then:
select clean to clean the print head for the black only. You may have to do this several times. If the check pattern does not improve, you may have to remove the printhead and clean it manually. Instructions to do this I will give separately if needed.
Mar 04, 2015 | Canon MG5250 Printer
Nail gun will not fire green light on gas ok after drop on congrete floor
A quick diagnostic check. First remove gas cell press nose against solid surface to dispose of any gas that may be in chamber.
1. Insert battery - LED should flash.
2. Press nose against solid surface - LED should be lit permanently (if still flashing possible fault moulded circuit board or fan motor micro switch lever, if flashing red green high possibility motor fault). Listen to hear fan running if not heard fan blade may have fallen off motor.
3. While still pressed against solid surface press trigger and watch LED - LED should blink off then light again (may flash red on guns newer than 2006) If does not blink fault either Spark unit (controller) or moulded circuit board trigger micro switch. To test for LED blink again release pressure on nose then press again. The blink indicates that a spark has been sent to the spark plug.
4. If 1 to 3 are OK problem most likely gas related or leak in seals. Ensure driver blade not still forward a possible fault of sticking forward after being dropped is nose slightly bent this traps the driver blade when first fired and does not return. (jammed nail gives a similar fault.) If nose is the fault it will require a new sleeve.
The moulded circuit board is normally cheapest then spark unit and sleeve roughly about same price the motor is most expensive.
Hope this has been some help to you.
Jan 13, 2015 | RTO PasLode 900420 Impulse Framing Nailer
Hi i have a land rover discovery v8 lpg, its keeps miss fireing on lpg no nothing about it could do with some help?
need a tune up. the propain doesnt ignight as easy as gas so u need to keep it tuned up good, new wires cap rotor and plugs
Mar 09, 2013 | Cars & Trucks
The firing pin in my paslode gas framer keeps getting stuck after firing one nail, i cleaned the **** out of it and changed the nails and the gas !!!! any pointers ????
There are a few possibilities for your problem.
1. Check the upper and mid oring (if applicable) for damage. If damaged or worn then the chamber will not seal and the pin will not retract.
2. The 4 finger valve located on the cylinder must be SPOTLESS, i change the valve plate on every service.
3. I assume you removed the piston and cleaned the bottom of the cylinder and cleaned the rings on the piston.
check these 3 items and if it does not work follow up and i will do my best to help
Oct 27, 2009 | Tools & Hardware - Others
Nail gun- double feed
Nail guns either have a switch or a seperate trigger assembly for two options - automatic, or 'bump' fire, and sequential fire. Sequential firing may be best for you since the nose must be fully depressed and the trigger pulled for each nail.
If you're stuck with bump firing, practice your technique. Double fires often occur when the workpiece bounces back into the nose of the gun; learn to 'bounce' the gun off the material to avoid this second contact.
If you're getting double fires in sequential mode, the problem could be more serious. I keep a can of aerosol silicone lubricant on hand to clean and lubricate the feed mechanism and magazine. Make sure your tool is clean and lubricated before each use, including the 3-5 drops on the air coupling.
Check that your air pressure is not set too high. Overdriving nails reduces their effectiveness and can cause tool malfunction.
This problem could also be caused by worn out O-rings or other parts within the tool. If you're not comfortable servicing the tool yourself, take it in for repair/maintenance work.
Another important thing to remember: With tools like this, you get what you pay for. A cheap nailgun will never function as well as a quality nailgun.
Oct 14, 2009 | Tools & Hardware - Others
Pasload cordless finishing gun - still won't fire
Jul 19, 2009 | RTO Paslode 902000 IM250 Ii Cordless 16...
I keep getting an error message- unable to clean....I just bought and installed new ink cartridges, and the machine is still having trouble - I cannot print at all now. There seems to be no way to clear...
The waistinktank has to be replaced. DO NOT only reset the code but change the waistinktank! Otherwise ink will flow into the machine and will cause serious damages!!!!!!!! See link how to do that: http://www.fixya.com/support/t202485-cleaning
Oct 05, 2007 | Brother MFC 420CN All-In-One InkJet...
32 people viewed this question
Top The Office Equipment & Supplies Experts
James Cagle
James Cagle
Gareth Cockram
Gareth Cockram
Peter March
Peter March
Level 1 Expert
Are you a The Office Equipment and Supply Expert? Answer questions, earn points and help others
