Question about Cardiozone Exercise & Fitness
I have cardiozone fast track elite II treadmill.It shows E7 error massage and instant keys don't work either .Checked fuses and power cable.whatelse should I check and how?
2 Suggested Answers
ercupa190
  • 12223 Answers
SOURCE: i have an E1 error on my Cardiozone Light commercial fast track elite 2 treadmill
1) adjust the speed sensor, and clean it, and tight the connector very well.see the diagram
2) test the main board output , for input voltage motor, if there are NOT the board is faulty see the block.
3) test the motor for input voltage, if there are the motor is faulty
God blesss you
Posted on Sep 20, 2012
Speed increases dramatically when trying to increase slowly on CardioZone Fast Track Elite II
This could be cused by the the display cover you touch to control the functions pressing on the touch switch array just under it. Carefully remove this. it is held on by adhesive and see if the symptom goes away. If it does, look for any dents on the cover. I have worked with these type of switches for nearly 20 years and they can be problematic. The other possibility is the mechanical switches you use to increase/decrease speed or tilt. They plug in seperately and you can disconnect them to see if they are causing the problem.
Nov 14, 2013 | Cardiozone Exercise & Fitness
BH fitness pioneer start treadmill- flashing E7
see this error has 2 alternatives. proceed according. God bless you
E7- 1) Alternative Elevation Motor
1)Cause: Elevation Motor not moving Solution:Check Elevation Motor connection
2)Cause: Elevation Elevation Motor screw binding Solution: Clean screw and lubricate
3)Cause: Elevation Motor Motor out of Range Solution: Check motor out of elevation
4)Cause: E-Motor Potentiometer: Solution: Replace Elevation Motor
2)Alternative:
Display Doesn't Light Up: a)Cause: On/Off switch Solution: Test unit is turned on b)Cause: Insufficient Power Source Solution: Plug dedicated120V, 20Amp Outlet
c) Cause: Line Cord Damaged Solution: Replace Line Cord
d)Cause: Fuse Solution: Check Fuse on MCB
Jul 15, 2013 | Exercise & Fitness
CardioZone SuperSportHR Club Fold-Away II ERROR 1
see the video and proceed according. God bless you
2) LUBE the rollers bearings too
3) test the drive belt motor, and replace it
4) Test the input voltage motor, if there are the motor need repair, see my personal TIPS for help
5) Test the output voltage board, for input voltage motor, if there are NOT THE board is faulty. see the block d.
God bless you
Nov 29, 2012 | Cardiozone Supersport Hr Club Commercial...
Treadmill KETTLER PACER have error E7 when starting run. How to eliminate it?
see the following indications and fix it. God bless you
ERROR CODE # 7
2)Alternative:
Nov 28, 2012 | Kettler treadmill Pacer
I have an E1 error on my Cardiozone Light commercial fast track elite 2 treadmill
God blesss you
Sep 19, 2012 | Exercise & Fitness
Error Code E7
To fix the error you have to put the safety key in start it it and wait for it to say E7. Now press stop and incline( up) together and hold for 20 seconds. Your treadmill will start to incline up. Take out your safety key. You just restarted your treadmill and can now put the safety key back and your problem will be fixed.
Apr 22, 2012 | Exercise & Fitness
My cardiozone supersport HR club II started elevating by itself to highest level then stopped running but stay elevated. Could not get it to return to lowest level, just stuck there. I got an E7 code on...
Sounds like the motor control board went wacko.....ran the incline motor all the way up and shut down the treadmill motor for no reason....sounds like a control board problem...
heatman101
Dec 15, 2010 | Sport & Outdoor - Others
I have a Proform 860, I moved it to another room in the house and now I am not getting anything...won't come on
Hello. Check these items:
1. The outlet - plug something else into that same outlet to be sure you don't have a blown fuse or a kicked circuit breaker. 2. The treadmill key. Remember that your treadmill will not turn on with out the little magnetic key in place. 3. The switch on the treadmill near where the power cord goes into the machine.
Hopefully one of these will solve your problem. Regards, Joe
PS Kindly rate my answer as helpful. Thank you.
Feb 09, 2010 | Cardiozone 5 Hp 325 Lb Limit Breeze Elite...
Exercise & Fitness Logo
Top Cardiozone Exercise & Fitness Experts
Electro Med Services...
Sportsmith LLC
Sportsmith LLC
Tom Chichester
Are you a Cardiozone Exercise and Fitnes Expert? Answer questions, earn points and help others
