Question about The Computers & Internet
Hello the plastic at the back of my card has ripped of the bit with the barcode can I get it replaced
    Top Expert:
  • The Master
  • 77,202 Answers
Yes the issuer of the card will replace it.
Posted on May 18, 2017
Can you replace the plastic cover on touch pad? One button is worn out.
The touch pad is not avail separatley, the conplete Facade/Escutcheon needs to be replaced. Part# 61005386 approx $160.00. In some cases the original clear plastic protective film might still be left on the front of the facade. Pleazer Appliance...
May 14, 2014 | Maytag MZD2766GES Side by Side...
Tip
How to print barcodes on plastic sheet
<p>Bar codes are symbols used by companies for the machines to read information about the products. Bar codes are typically used for identification and tracking purposes. When making your own products, and bar codes, you can print barcodes on plastic, but it is more difficult due to the plastic - cannot hold the ink. So it is important to follow these instructions to print barcodes on plastic. <br /> <p><br /> <p>1. Buy online card sheets or plastic from a local store office supply. This sheet is treated to work with most printers. <br /> <p><br /> <p>2. Create your bar code on the computer. Insert the sheet of plastic card printer and bar code on the plastic sheet. <br /> <p><br /> <p>3. Cut the UPC or shape and cut the plastic into the desired shape. <br />
on Jun 26, 2011 | Computers & Internet
Barcode wont scan
Hello Nicole,
Sorry for the delay in replying.
Are you still having a problem? If so, could you give some more details?
Which Magicard printer model do you have?
Is this a barcode the printer has printed onto the card which won't scan? Is it possible for you to attach a card scan or photo showing the printed barcode?
Regards,
MC.
Oct 30, 2012 | Magicard Office Equipment & Supplies
Hello. My eMachines computer will not boot up. Once I press the power button on the tower it beeps 3 times and nothing happens. I don't have the model number right now.
Try to clean your memory card and place it back to it's proper place. If cleaning does'nt work, replace it with a new or a working memory card then boot up your computer . Have a nice day.
Sep 14, 2011 | Computers & Internet
For some reason my computer keeps on either not wanting to show anything or it forces itself down to 4 bit grafics and cant turn it back. why is it doing this?
It sounds like your video card/chip might be going bad.
I can try updating the video drivers via the manufacturer's website.
I wish a had better news.
Good luck!!
Mar 07, 2011 | Computers & Internet
What is the best type of wrench to remove an EGR valve from 1995 Honda Odyssey? The housing of the valve hangs over the bolts a bit so my regular sockets doesn't fit well.
what about a nice ring spanner ?? i would not use open ended in case they slip as i value my hands even anything plastic i break or cut off then glue back on again nothing worse than ripping skin open on a protruding plastic tie clip or a plastic support thingy
Mar 04, 2011 | 1995 Honda Odyssey
How do I remove and replace my MC9060 exit lens?
The lens is made of glass so be very careful. There are no replacement glass lenses available. We manufacture our own plastic replacement lenses from a template and a sheet of clear plastic.
The easiest option would be to buy a complete lower shell and replace that.
Sorry I can’t be more help than that.
If you need any more help then please do not hesitate to contact us:-
helpdesk@biastechnology.com or TEL +44(0)1202 620955
http://www.biastechnology.com/
Mar 25, 2010 | Symbol MC9060
900 Service RIP Software
Are there any memory or Barcode SIMM's in the printer? If so, remove them (power off first!) and turn the printer back on and see if it acts normally. I have had 1 instance where the Barcode SIMM has caused that error. The Barcode SIMM had to be replaced. Most other times the 900 RIP error occured, a simple turn off/on "fixed" it (sometimes only temporarily). If all that doesn't help, flash the engine code with the latest from Lexmark support. If that doesn't do it, then engine and/or controller card need replacing.
Jul 07, 2009 | Lexmark T520 Laser Printer
Which Jl Audio 12 Has No Writing On The BAck
http://www.simplyspeakers.com/speakerrepairinstructions.htm
go with the repair .those r good subs,very expensive. i repaired a pokl 12" sub cone and surround foam. never had a problem. save me 300 bucks.the cone you can fix by using the same material that it is made off.if paper use rubbeer glue. if plastic ,i used a 2 part epoxy,airplane glue.didn't look pretty but did the job.rating please
Feb 03, 2008 | Kicker Solo-Baric L5 Car Subwoofer
Computers & Internet Logo
100 people viewed this question
Top The Computers & Internet Experts
Pieter Vleeshouwers
Pieter Vleeshouwers
thetraveler
Level 1 Expert
Are you a The Computer and Internet Expert? Answer questions, earn points and help others
