Question about Toro Garden
I have toro 195cc tec carb. Mower runs one.minute then cuts out. Have good spark. Replaced carb. Removing fuel cap doesnt help. Carb jet is clean. Swapped plugs with another toro. What am i missing?
  • Toro Master
  • 1,885 Answers
Tankfilter (sludge problem) Gasoline faucetfilter the fuel hose connections , fill up your oil level if in doubt of it after know the right level try to unconnec for only a short time the Oil monitoring cable
Posted on Jun 18, 2017
2 Suggested Answers
kel1guy2002
  • 3740 Answers
SOURCE: toro mower quick running after
Hi and welcome to FixYa. First off having worked in lawn mower shops personally you should take your mower back to the shop you had it repaired in. What you have is what we in the biz call a repeat disrepancy. Most likely there is a fuel supply problem if the jects have been cleaned. The problem can be:
1. Debris in the bottom of the fuel tank.
2. Clogged fuel filter
3. Float needle and seat is not opening fully or there is debris in the needle seat.
4. Clogged or pinched fuel supply line.
That is about it but I am telling you the repair shop owes you a free labor fix for this. You may have to purchase a needle and seat for around $5 - $6.00 and or the cost of a new fuel filter but, they certainly should eat the labor.
Thanks for choosing FixYa.
Kelly
Posted on Sep 18, 2010
6.5 toro self propel.....new plug and new gas,,,turns over but then shuts down...replaced both neoprene hoses
Carburetor Cleaning TUNE UP of Toro 6 5HP Lawnmower with Tecumseh Engine
The above link will provide a video on how to clean the carb on the 6.5 hp mower. Before you go to that length, try putting some carb cleaner in the fuel tank and see if that corrects the problem. Also, as the video shows, make sure the spark plug is getting a good spark. If the spark is weak , the fly wheel may be rusted, ot the magneto is bad.
May 09, 2014 | Garden
Toro Timecutter 14.38Z Model 74301 Briggs & Stratton Engine Model 280H07-0166-E1 Has NIKKI carb Starts & runs for ~ 15 minutes then stops. Will restart after 5 minutes rest and run...
Recheck spark when the unit cuts out. I am gonna guess you spent a lto of money chasing a bad coil! When a coil starts to go bad they become temperature sensitive. Time does the rest!
Dec 27, 2012 | Garden
Why wouldn't fuel be getting to the spark plug?; could primer bulb have crack in it if its an old mower (Model #20017)?
If your purge bulb has a crack then gas will leak from it. The Toros are famous for one thing. That little brass 1/2" main jet bolt on the bottom of the carb has a tiny hole right at the top of the threads that gets plugged up because it's so tiny (and ethanol gas sucks) you can't even see it (with my eyes). That needs to be cleaned with a needle or very very very thin piece of wire. My guess is that your whole carb needs a good cleaning and if you're not familiar with carbs, then have a pro do it for about $35 USD. Most of the Toro / Tecumseh's I work on run like new after I go thru the carb on them and it'll be worth your while to have a good carb cleaning done on it. Hope this helps and best of luck to you.
James
Aug 20, 2011 | Toro Power Lawn Mower
Toro recycler model number SR-21 S lawn mower wont start changed plug, filter, new gas. Mower ran for two lawn cuttings but seemed to overheat and choke out frequintly in high grass now it wont start at...
check your oil is it up to full, then I would check to see if you have compresson, pull your plug and roll over and feel with finger ,but don't touch spark plug wire or you will light up! next I would check for spark, then for fuel, make sure the carb is getting fuel,,,check your hoses and fuel cap and clean your carb and needle/seat and make sure gas will run through the fuel line. Also you could have sheared a flywheel key
the choke out you are talking about could of been a lean condition and smoked the eng rings
Good Luck compresson test should tell all 2StrokeJim
May 17, 2011 | Toro Lawn Mower With Toro Power Tools
Toro mower quick running after 5 minutes - repair shop said cleaned carb jets, air filter, plug - same thing next time I ran it - repair shop then said it was probably the fuel cap vent. Just run it for...
Kelly
Sep 18, 2010 | Toro Lawn Mower With Toro Power Tools
Lawnmower starts when pushing primer button but cuts out right after
1).You need to remove the fuel bowl from the bottom of the carb. and clean it. There is prob. some dried up crusty fuel in the bottom and it will stop up the jets in the carb. 2). If you can remove the carb. and run small wire in the jets.
Apr 19, 2010 | Toro Lawn Mower With Toro Power Tools
My toro self propelled only runs for a few minutes. I replaced air filter and spark plug, and cleaned out carb. Any ideas?
Have you tried replacing the gas cap? I had the same problem with my mower and did everything you have done, changed gas cap no problem since
Jul 25, 2009 | Toro Lawn Mower With Toro Power Tools
Toro 6.5 Tecumseh Recycler won't stay running
I have the same mower and problem. Found out the issue was the carburetor. Pull the Carb and do a quick cleaning. Order the replacement kit prior to working on. My bowl o-ring was shot and I couldn't get a seal after cleaning it out.
Jul 01, 2009 | Toro Lawn Mower With Toro Power Tools
Mower will not stay running
You have a problem in the fuel system. First start by checking fuel lines,filter,vacum fuel pump.If this checks out,remove carb. and clean. Check for water and trash in bowl of carb. or tank. This sould solve your problem.
May 14, 2009 | Toro Lawn Mower With Toro Power Tools
Toro personal pace mower 5 yrs old only runs 10-15 seconds.
Was gasoline left in the tank during off season? Sometimes gas will break down and clog the jets in the carb. The priming bypasses the carb so when you put fuel in by pumping the bulb it runs, but dies becasue no additional fuel is coming through the carb after the primed fuel is burned off. Sounds like you need to clean the jets in the carb and in the future, use Stabil in gasoline to keep it from breaking down.
May 04, 2009 | Toro Lawn Mower With Toro Power Tools
Garden Logo
64 people viewed this question
Top Toro Garden Experts
Jim Parker
Jim Parker
Joseph Mueller
Joseph Mueller
lnbn1975
Are you a Toro Garden Expert? Answer questions, earn points and help others
