Question about Whirlpool Ovens
LOOKING FOR OLD MANUAL FOR DOUBLE WALL OVEN WHIRLPOOL MODEL RB170PXBB1
  • 4 Answers
SOURCE: installing a whirlpool wall oven
You could call whirlpool and they can email you the instructions. Or your can go on whirlpool.com and enter your model number under the upper customer support tab.
Posted on Nov 21, 2007
  • 833 Answers
SOURCE: Whirlpool Double oven - control panel stopped working
Atlanta...sounds like you may have a power supply problem or the panel is bad. Cut the power, open the unit up and see if there is a fuse in there or a reset. No good? Then replace the circuit board. They just, well, die sometime. Happened to my microwave. Some units may be available remanufactured. Look around on the web.
Posted on Dec 07, 2007
SOURCE: CDA double electric double oven user manual
https://portal.bsh-partner.com/portal(bD1kZSZjPTAwOQ==)/PORTALFRAME.HTM
Posted on Nov 07, 2008
SOURCE: whirlpool rbd275pdb double wall oven died during self clean
The first time we used our Whirlpool oven the same thing happened - no power and yet the circuit breaker was not blown. I called Whirlpool, and they sent out a technician to check it out as it was still under warranty. He said the temperature was off (too hot) by 20F - he adjusted. He also replaced the blower. What he did not tell me was that the thermal fuse had blown, and he replaced it - this was the REAL cause for the failure. I got the impression that he did not want to let me in on the secret. He did not note on the paperwork that he replaced the thermal fuse. Last week I decided to run the oven through the self-cleaning cycle (the oven is now 8-1/2 yrs old) - I don't believe that we cleaned the oven but a couple of times since the first time that it was "repaired." I used the default 3-1/2 hour setting. Everything appeared to be fine - the oven went through the cleaning cycle with no apparent problems. The display now read "cool down" - I went to bed thinking everything was okay. I got up the next morning only to find out that the power was out. I called Whirlpool and demanded that they repair the unit again as they clearly never fixed it correctly in the first place. They offered me 15% off on a new oven - WHOOPEE! I asked to speak with the supervisor - he did not budge either. I was upset, and I told him that I would NEVER purchase a Whirlpool appliance again! I decided to tear into the oven to see if I could detect anything wrong. I pulled out the front panel - everything looked okay. I then noticed the "thermal fuse" - I did not know what it was called at the time, but it looked familiar. I checked voltage on either side of the fuse and found the voltage to be zero on the downstream side of the fuse. I pulled it out and read the information on the device: Microtemp 110C. I called a local appliance repair shop - they told me that it would cost $50 to purchase a new fuse! I told them that seemed very high. I ended up stopping at Radio Shack. They have thermal fuses in various temperature and voltage ranges. I got a 144C 10A fuse and carefully soldered the connectors to it and replaced the protective plastic sleeve. I actually bypassed the thermal fuse in order to use the oven before I found the replacement fuse. While it is a good idea to have a protection device for the slim chance that an oven may malfunction by overheating, it is not a necessity for the functionality of the oven. Hopefully, the thermal fuse will not fail during my next attempt to self-clean the oven. I do have a concern about the 10 amp rating, but I'm sure that it will work fine.
Posted on Apr 15, 2009
  • 25 Answers
SOURCE: Whirlpool wall oven stopped working after power outage
Ouch...sounds like the control module is blown. Thats the electronic timer. I've known this happen on several occasions. Bad luck!
Posted on Jun 25, 2009
How do i set the clock on Whirlpool built in double oven? Can't find a model number. 5 buttons from left to right. Alarm bell, clock with hand at 12, clock with hand at 3, + and - signs. Pleas
The model number is usually located on the side of the door or on side of the oven cavity area near the door opening. Sometimes if you have a drawer or warmer the model number is located on the oven side of the drawer or warmer (sometimes not directly facing you but on the side of that area. If the oven is electronic you press a clock button or you hold one of those buttons for a couple of seconds like a start or set button. The model number though will help you find a user manual and it for sure should be clear. I hope this helps you.
Nov 16, 2014 | Whirlpool 24" Double Electric Built-In...
Whirpool Electric Double Oven
1-800-269-2609 call them and they can www.repairclinic.com
Dec 23, 2007 | Ovens
Need User Manual Kuppersbusch Okotherm Double Oven
The age of the oven may make it difficult or impossible to find the information you are looking for.
Jul 08, 2014 | Kuppersbusch Ovens
I have a very old Whirlpool small wall oven and would like to replace the door
Contact a local appliance store which handles Whirlpool and they would be able to tell you if one would be available.
Mar 03, 2014 | Whirlpool GBD307PDS Electric Double Oven
I have a Whirlpool electric acubake wall mounted double oven which is 15 yrs old. Most of the time the digital controls work fine. Twice now the digital display has gone totally dark. An hour or so...
Anonymous, we're sorry to learn that your Oven isn't heating. We will be glad to further review your concerns. Please email us at Whirlpool_Reviews@Whirlpool.com with your name, contact number, address, model and serial number.
Oct 23, 2017 | Whirlpool Ovens
Looking for a user manual for a Maytag double wall oven model MEW6627BAB
go online to maytag .com and download your manual. you can also print it if you want
Nov 13, 2012 | Maytag MEW6627B Electric Double Oven
Double oven no model number Whirlpool 14 years old Door is locked after self clean and display is blank
Your oven has resetable high limit thermostat that tripped off on the self clean cycle,im not sure if you have free standing,or a wall oven if freestanding the t-stat is on back panel if wall oven its behind control panel on upper oven and for lower oven its behind the grill between bottom of upper oven and top of lower oven. In either case it has a small red button that can be pushed in to reset it
Hope this helps and if it does please give me 4 thumbs up
Gene
Jul 28, 2011 | Whirlpool Ovens
No response to touch pad. No display or lighting. Check breaker and replaced circuit breaker.
Inside the control panel is a bullet fuse. This thing melts when temp inside control exceeds safe levels to keep from harming electronics.
I have a Whirlpool double oven service manual with
repair photos that shows how to get into the controls:
Whirlpool Double Oven Service Manual and more
Dec 26, 2010 | Whirlpool RBD276PD Electric Double Oven
Whirlpool Gold double oven - started beeping then all lights on the control panel went out. Reset the circuit breaker which makes the oven beep but still have no lights. Oven will not operate.
I was just looking over a manual for a late model double oven. Their is a thermal limit going into the controls that will open if the temp rises enough to harm the controls. They look like this one.2605a73.jpg That kills all power to the control and you will see nothing on the display.
This manual will give an idea where to look:
Late model double oven
Sep 27, 2010 | Whirlpool GBD307PDS Electric Double Oven
F-4 error
This indicates an oven temperature sensor problem. Here is a link that should help http://appliancehelponline.com/oventempprobe.html
Jul 21, 2010 | Whirlpool RBD305PDS Electric Double Oven
Open Questions:
Ovens Logo
43 people viewed this question
Top Whirlpool Ovens Experts
Dan Webster
Dan Webster
ashburton
Sal DeAngelo
Are you a Whirlpool Oven Expert? Answer questions, earn points and help others
