Although balanced, washing machine vibrates excessively during spin cycles. Model WF361BVBEWR/A2 Serial Y10A5AED202036N
    Top Expert:
  • Washing Mach... Master
  • 48,191 Answers
You need to state make and type ( top or front loader ) if top loader , it is most likely that suspension rods for the tub have broken and failed
( indicated by unbalance starting with few or no clothes)
at the bottom of the rods under the tub tabs there is an air and piston type damper around the springs
the top breaks out and the damper action is lost ( cost around $90.00 AUd for set of 4
check the tub level by removing the lint filter assembly and placing a level across the agitator center
front loader is a different failure
Posted on May 13, 2017
Maytag Washing Machine Out of Balance Even When Empty
the machine is not level... put a level across front back sides to check adjust legs leveling bolts as needed.... also is the machine installed on a carpet floor??? if yes put a sheet of plywood under machine so it wont "bounce" on floor.
May 15, 2017 | Maytag Centennial 3.2 cu. ft. SuperSize...
Kenmore 90 tub spins excessively clockwise during wash cycle.
there should be 2 or 3 springs that hold it, they mite have broke, take off back panel an check.
Jan 04, 2010 | Kenmore 24032\24036 Top Load Washer
Need to balance washing machine drum
The drum should not need balancing, but the washer should be level in all directions. If the washer is level, but vibrates excessively during spin cycle, you may need to replace the springs. There is a set of suspension springs which act as shock absorbers. When these wear out the washer will bounce across the floor unless the clothes are 100% balanced in the washer.
Jul 29, 2009 | GE Washing Machines
Excessive vibration on spin cycle
Check the Vibration damper rods to be sure that...
1. They are there and mount is solid.
2. If they are broken in 1/2.
3. The plastic knuckle mounts are not missing/broken.
4. There is oil in the shock absorber/spring section of the rods.
Also - there are suspension springs on the bottom of the tub that could be broken and/or missing.
Replace/repair as necessary.
IF THIS IS A BRAND NEW INSTALLATION - be sure you hav removed the basket shipping pins (4) that secure the tub during shipping.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question.
Apr 05, 2009 | Washing Machines
Excessive vibration during spin cycle
Chck to see that all (6) suspension springs are still attached. Check the plastic snubber ring below the mechanism and above the base plate for cracks or contamination.
Mar 07, 2009 | Maytag Performa PAV2200
Excessive shaking
your suspension dampers is damaged on washing machine causing bad balance on spin cycle..
Mar 03, 2009 | LG WM2277HSW XL Front Load Stackable...
Washing machine
check to make sure the machine is properly balanced. an off balance machine will vibrate causing that sound.
Aug 16, 2007 | Kenmore 9387x Top Load Stacked Washer /...
Machine vibrates excessively during spin cycle
Open washer's cover and look for a released or a malfunction shock absorber. Good luck!
Nov 08, 2006 | Maytag MAV4755A Top Load Washer
Washing Machines Logo
Top Washing Machines Experts
