Question about Samsung Cell Phones
Samsung back lite 2013svs40 and its equivalent strip
Samsung un32eh4003fxza no backlight is it power supply
The only problem we seen the most on this model, the problem is some open or shorted LED diode on the 3 LED back light strips.
Oct 27, 2017 | Samsung Televison & Video
01 vw beetle ck engine oil lite beepflash said to much oil stripped oil plug new oil pan7days lite on engine warms up if i stop goes offthen back on again
If your oil is at the correct level, then the oil level sensor is not working correctly. If your oil level is low, then you need to fill it to the correct level
Feb 17, 2017 | Volkswagen Beetle Cars & Trucks
I have a Samsung 40" LED tv that has sound but no picture. You can see an image if you shine a flashlight on the screen. I see no backlights when I take off the back.
Hi!
Check the backlight circuit, but first, check the power supply of the blacklight circuit, does it feed the backlight circuit or not. If not, it's the power supply circuit, if yes, check the backlight circuit itself, and if it works, check the backlight themselves, the led. Good luck,
Serge.
Nov 01, 2016 | Samsung Televison & Video
When my flymo lite 250 engine is running the end does not turn to cut the grass
Could be anything from a stripped drive shaft to a loose or stripped trimmer head. You'll probably need to take it to a repair shop to have them diagnose the problem and locate the replacement parts if it's anything other than a stripped trimmer head bolt.
Nov 01, 2011 | Homelite Mighty Lite Lawn Trimmer
What is the Sony part No. of the flexible ribbon conector between the screen and the camera?.. Are there other equivalent connectors from other sony cameras?
You can mention the model of the set -- DCR-SR42 to get the strip connection as it is only available from Sony.
Equivalent one if availabe may not last as the original ....but this is a manufacturing fault of Sony to design the strip that moves through the mechanism and fails often.
Sep 30, 2010 | Sony Handycam DCR-SR42 Camcorder
Rust on exhaust of 6 month old yrb 125cc
The only way to get it back tonew is to have the chrome stripped off in an acid bath & have it re-plated. Many chroming companies will not strip used exhausts as they ruin the acid, but some will.
Otherwise clean with an abrasive metal cleaner, not too much as it wears the chrome away, & spray often with WD40 or equivalent.
Good Luck
Hope this helps.
(If it does then please mark this as 'useful')
Ride Safe
Bike-Doc
Jan 29, 2010 | Yamaha Ybr 125 Motorcycles
The only way to get it back to new is to have the chrome stripped off in an acid bath & have it re-plated. Many chroming companies will not strip used exhausts as they ruin the acid, but some will.
Good Luck
Hope this helps.
Ride Safe
Bike-Doc
Jan 29, 2010 | 2007 Yamaha Ybr 125
Nintendo ds
There is a little (usually black) strip that holds the ribbon cable in the connector. This strip is hinged and needs to be "folded" open (like a book) from the front of the connector (where the ribbon is inserted) towards the back. Then the ribbon will be free. When re-assembling, you need to fold this strip back. Make sure you insert the ribbon all the way (make note of the depth before you start).
You must have something thin enough to get under the strip to fold it open. BE CAREFUL or it will break.
Apr 07, 2008 | Nintendo DS Lite Console
Gas furnace wont stay lite
I'm a little confused by your terminology. You are saying you have a pilot lite and electric heat strips? Are you possibly meaning burners? Is the heater running for 2 hours straight without shutting off? how cold is it there? Lastly what temperature do you have the thermostat set at and how close does it get to the temp. before it shuts off?
Dec 16, 2007 | Heating & Cooling
Cell Phones Logo
27 people viewed this question
Top Samsung Cell Phones Experts
Computer Repairing
Computer Repairing
Ronny Bennett Sr.
Ronny Bennett Sr.
Are you a Samsung Cell Phone Expert? Answer questions, earn points and help others
