Question about Frigidaire Refrigerators
What is the cubic ft of the frigidaire dryer model gleq642as2? Also, is it a stackable dryer or regular size dryer? Thanks! Carolyn
aborcass
  • 2651 Answers
SOURCE: STACKABLE WASHER/DRYER DISASSEMBLY
FLSE72GCS6 this model number is showin as a complete laundry center, not 2 seperate peices. in which casse there is no seperating them
Posted on Dec 09, 2008
  • 7 Answers
SOURCE: What is Cubic Ft Capacity of Washer?
It's in the model number, and it's 4.4 cft. Which is one of the largest capacity washers available.
Posted on May 27, 2009
  • 512 Answers
SOURCE: I have a Frigidaire Gallery Stackable that has a screechy dryer
Sounds like it is worn out. Get a parts diagram and take it apart and see what parts are missing or worn out. The belt is probably coming apart and that is the black stuff. There are several plastic wear plates and a bearing/bushing for the drum, plus the belt idler and all these can wear out. The motor could also have a bad bushing in it but more than likely that will require a new motor as they don't usually sell just the bushing or end caps.
Posted on Sep 03, 2009
  • 239 Answers
Sounds like the bearing is gone, call a repiar man or buy new as repairman 100 per call
hunter19_46m
  • 7482 Answers
SOURCE: how do I remove the
I will include the instructions for replacing the belt, it will include the top removal and also a link that you can click on the see the belt routing.
http://www.applianceaid.com/images/belt-config.JPG
First, unplug the dryer. Lift the lint-screen cover and pull out the lint screen
If your dryer has a lint screen on the inside of the door, skip this step.
Then remove the two screws that are under the cover. To unlatch the dryer top,
insert a thin-blade putty knife between the top and front panel,
about 2 1/2 in. in from one corner. Push in on the knife to release the locking
clip, lift the corner, then release the clip on the other side. Swing the top
up and lean it against the wall.
Next, move to the lower toe panel. Slip the putty knife between the lower panel
and the door panel at one side and twist the knife to release the clip
Then release the opposite clip and lift the panel up and off the hinge springs.
To support the dryer drum while the belt is being replaced, place scrap wood
under the front of the drum.
Loosen the two screws at each side of the bottom of the front panel.
Move to the top of the panel and remove the screws from the inside of the
cabinet that hold the front panel to the sides.
Slide the old belt off the drum.
Installing the belt
Lean the front panel out slightly and allow the drum to rest on the scrap wood
support. Drop the new dryer belt between the front panel and the drum, and
loop it over the drum. Then, lift the drum slightly while pushing the front
panel back into position.
Replace the screws at the top inside of the front panel, tighten the lower panel
screws and remove the scrap wood from under the drum. Check to make sure that
the rear drum seal fits properly over the lip on the rear bulkhead.
Position the new belt where the old belt was, with the grooved side of the belt
facing down.
Now, move to the motor area and pull out the old belt. To route the new belt
around the idler and drive pulley, first pass the entire belt, doubled up,
under the idler pulley. Then, push the idler belt toward the motor, slip the
belt around the motor pulley and release the tension on the idler pulley.
Open the dryer door and rotate the drum counterclockwise a few times to make
sure the belt is tracking properly. Lower the top and press down at each
corner to engage the clips. Lift the lint-screen cover, replace the two screws
and reinstall the lint screen. Finally, secure the lower front panel and turn
on the dryer for a test.
This is a FREE answer
Please RATE me
Posted on Jan 02, 2011
What is the cubic feet of Kenmore refrigarator model #253.562824on and also need mearsurements of outside.
You seem to be missing a few digits in the model number. Sears Parts Direct lists 11 refrigerator models that start 253.562824. (The full models numbers have 2 extra characters, including 253.56282400 and 253.5628240N.) See http://www.searspartsdirect.com/model/search.html?q=253.562824 for the list of models.
Kenmore uses the 3rd digit after the decimal point to indicate the cubic footage of their refrigerators. With a 2 in that position, this model has a 22 cubic feet capacity (probably 21.6 or 22.1 cubic feet before rounding). Using the size of other models, the external dimensions will be between 30" W x 31-3/4" D x 69" H (the size of a 21 cu. ft. model) and 35-5/8" W x 28-1/4" D x 69-3/8" H (23 cu. ft. model). One current Frigidaire 22 cubic foot side by side model has the external dimensions: 33" W x 32" D x 69-7/8" H. (Note: the 253 in the model number indicates a product made by Frigidaire for the Kenmore line.) Unfortunately, I can't find the dimensions for any of 253.562824 models.
I hope this helps.
Aug 30, 2016 | Kenmore Refrigerators
How many cubic feet is the frigidaire FSE447GHS0 front load washing machine
Good Afternoon friend, thank you for your post!
From the information you have provided you need to know the cubic footage of your Frigidaire washer, FSE447GHS0. I have researched your model and it appears to be 4.4 cubic ft. I hope this information is helpful to some degree. -Matt
Feb 25, 2015 | Frigidaire Refrigerators
What is the cu ft of model ler331dso
Hello friend, thank you for your inquiry!
I see that you would like to know the cubic footage of your Frigidaire dryer. It appears that your dryer is a 5.7 cubic foot dryer. I hope this information is helpful. -Matt
Feb 10, 2015 | Frigidaire Dryers
What cu ft does model number atfb7000es0 have
Good Morning Friend,
I understand that you want to know how many cubic feet your dryer, model# ATFB7000ES0, is. I was able to locate the specifications of your dryer, and it looks as though it is 3.0 cubic feet. I hope this is helpful.
-Best Regards-
WP
Jun 06, 2014 | Frigidaire Dryers
Stackable frigidaire dryer
The motor winding won't have a large resistance but should have some. Be sure and unhook wires and set your meter to the lowest setting and 0 it. Be sure you are checking the correct connections.
May 18, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
What's the resistance value in stackable dryer motor model fex831fs2?
There should be some for both the motor and the heater coil. Don't know how much don't have schematic. Hope this helps
Low heat in stackable dryer
get a dryer vent brush--clean out the dryer and vent--allow the unit to breathe--
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/david_2f6e03df6c124197
May 17, 2014 | Frigidaire 7 Cu. Ft. Stackable Electric...
Sep 03, 2009 | Frigidaire Gallery Series GLHS269ZDB 36"...
Dryer not heating up
it sounds like your thermostat located near the heater check with multimeter
Jun 24, 2009 | Frigidaire FullFGX831C Size Stack Gas...
May 27, 2009 | Frigidaire Washing Machines
Refrigerators Logo
46 people viewed this question
Top Frigidaire Refrigerators Experts
Charles T Nevin
Charles T Nevin
John Tripp
John Tripp
Are you a Frigidaire Refrigerator Expert? Answer questions, earn points and help others
