Question about Kenmore Washing Machines
I have a Kenmore Front load washing machine made by Samsung. Model # 592491070 What size is it? Thanks
  • 1294 Answers
SOURCE: cold water will not enter washing machine
Turn off the faucet in wall. Unscrew the inlet hose to examine whether there is clogging in the tiny screens. Both ends as well as machine input hose. Clear out properly. Open faucet to check. See that you have a "y" or "F" type adaptor for your hot and cold inputs of the machine. This is if you have only one faucet in wall for your washing machine. If this does not work you have to check your (plug off the wall first) wires to the inlet pump of your machine - this probably has come off or is loose. And if this does not work, your inlet valve could be defective.
Pl rate if helped.......
Posted on Dec 31, 2007
  • 106 Answers
SOURCE: Washing machine won't do final spin.
Remove the front lower panel. Right in front you will see the pump filter. Get some towels and a bucket and unscrew the filter cap and pull the filter out. See if you have a bunch of lint and stuff in there. If you do, clear it out, refit carefully and give the washer another try. The companies dont tell you how to do it, for their techs then won't make any money. A tech to clean your filter!!!?? $$$
You're free to rate me............not that i get anything. Happy laundry!!
Posted on Mar 01, 2009
SOURCE: Our samsung j845 front load washing machine won't
SAME THING HAPPEND TO ME, SORRY BUT YOU NEED A NEW WATERPUMP, THEY GO ON THEM WASHERS ALL TIME. I REPLACED 2 AND HAD MY WASHER JUST OVER A YEAR. NOW ITS THE DOOR
Posted on Sep 29, 2009
milten1
  • 1304 Answers
SOURCE: what does the code 5d mean on my washing machin???
5d is actually SD
it means SUDS
you have suds detected in the pump
Your using too much soap and the machine cannot rinse it
try one load with out any soap
from that load on you should not be using any more that a table spoon per load
Posted on Oct 20, 2009
SOURCE: How to increase the water level of Front loading washing machine
I have used extra weight inside the tub. I have used bottle of water and also a plastic 2 or 5 pound weight.
Posted on May 05, 2010
How do I get the front off my washer so I can check the pump. It does not have a lower panel. Kenmore model 592491070
If it is a top loader, the wraparound cabinet has to be removed to get access to the pump. Go to www.repairclinic.com and enter 92491070 to see a list of common replacement parts such as a pump and perhaps a video showing how to disassemble the machine.
Apr 30, 2016 | Kenmore Washing Machines
A light came on to clean the washer. Is there something special I need to do?
Even a blonde can do it! Quick fix/repair for Kenmore He2 ...
? 4:57
https://www.youtube.com/watch?v=4o9hWHQkOMM
Sep 1, 2013 - Uploaded by And Justice For All
Quick fix/repair for Kenmore He2 front loading washing machine... a Kenmore He2 front loading washing machine when blinkinglights error code occurs ... How to Clean Front Load WasherDrain Filter and Empty the Water ...
Front Load Washer Pump Clean Out - YouTube
? 3:03
https://www.youtube.com/watch?v=f9uS8_0-pWY
Sep 6, 2012 - Uploaded by GE Appliances
If you have a front load washer with a pump filter, your pump filter may become ... pressed start again but it still stops and the cleanpump light still comes back on. .... Samsung Washing Machine cleaning the pump & coin trap
Nov 29, 2015 | Kenmore Washing Machines
A friend wants to know were the model number is and load size
Inside the lid will have the model # and capacity. If not - a tag right where the hoses connect is a likely spot.
Thanks for using FixYa - a 4 THUMBS rating is appreciated for answering your FREE question
Mar 29, 2009 | Kenmore Washing Machines
Front load washing machine wont finish cycle and clothes stay wet
try changing the door switch. Its either that or the speed controller. the door switch is cheaper and that is usually it.
Nov 19, 2008 | Kenmore Washing Machines
Need cu size of my broken washing machine.
it is a 3.0 cubic foot.
  • I would do some research before spending a lot of money on a front loader.
Aug 05, 2008 | Kenmore 24032\24036 Top Load Washer
Size of washer
Size varies between manufactures, the biggest I have seen is the GE which is 3.5 cu ft, base your machine on your standard size load, ours is about 8lbs however I dont overload, I take large items quilts, comforters etc to a laundromat, its not worth breaking my machine over a comforter wash for $3.50 American.
Go to Sears.com and look @ the washers available
Jun 06, 2008 | Kenmore 22422 Top Load Washer
Kenmore 90 washer won't drain
ckd pump traps for debris on kenmore remove front panel on samsung i think a rear approach is best
Jun 03, 2008 | Samsung WF337AA Front Load Washer
Washing Machines Logo
41 people viewed this question
Sal De
fordexpert
Jim Goldsmith
Jim Goldsmith
