Question about Inverter Electronics - Others
I have an AIMS 3000w pure sine inverter. The inverter turns on, but no AC power from the outlets. Any tips to fix/troubleshoot this?
    New Friend:
  • 46 Answers
Hi there !
please get some to open your inverter and check for short in the transformer coiling .and also check the fuse .
good luck
Posted on May 18, 2017
  • 4090 Answers
SOURCE: I had my inverter stored and when I connected it
did you check the fuses there should be two one for AC one for DC ( depends on brand and quality) If not then I would suspect a breakdown of the power transistor.
Posted on Aug 20, 2009
cmcduncand
  • 714 Answers
SOURCE: red fault light comes on after about 10 mins and
Had a similar problem with the same inverter BUT to include a failing cooling fan.
NOTE:
Take it back and get your money back as soon as possible.
Replaced it with a pure sine inverter 1500 watt that is kicking **** 24 seven days a week on my solar / wind power system.
RECOMENDATIONS:
UPGRADE.
Hope this tip helps.
R/
David
Posted on Jan 30, 2010
nitrospawn
  • 290 Answers
SOURCE: I would like to run my Canon i550 printer with a
pure sine wave will be the best option ,but note it is not very possible to get a pure sine wave type
Posted on Feb 25, 2010
  • 436 Answers
SOURCE: manual, for a aims 1500
No luck finding a manual or schematic but they DO have internal blade fuses inside.
Hope this helps
Posted on Jun 05, 2011
  • 1212 Answers
SOURCE: user's manual pure sine inverter
http://www.donrowe.com/user_guides/samlex/ssw_series.pdf
May or may not be identical to what your part number is but the general guidelines are the same.
If you are looking for the schematic, the manufacturers keep a tight lid on those to protect intellectual property as there are several ways to achieve the sinewave synthesis, and some are under patent or are under license.
If you understand the principles of a Class A audio amplifier, you should be able troubleshoot this type of inverter.
Posted on Jan 16, 2012
I have a 24 volt 5000 watt pure sine wave inverter that keeps tripping. It has 28.6 volts going in from the battery and 115 volts going out at 8 to 12 amps any suggestions.
It sounds to me that you have a load that draws too much from time to time. If the inverter will run without a load without a problem, try adding loads one at a time until it starts to trip off. That should give you an idea as to what the problem is. It could be that there is a problem internal to the inverter that causes it to trip prematurely..
Jul 11, 2014 | Inverter Aims Pure Sine Wave Power...
Having issues with my laptops when the AIMS 600W Pure Sine Inverter turned on. As soon as I exit the cab of the vehicle with the laptop the issues resolve themselves.
You will need to either mount the inverter further from where you are using the laptop or shield it enough to get the laptop out of the "arc" of the power generation.
Now the problem: The inverter does produce heat so you can't mount it in an unvented box.
You are dealing with the same problem as the high tension power lines, that has a radiation zone, and you either need to cut back the zone or move it further away.
If it the inverter was modified in any way, then they might not have gotten all the shields back correctly.
Sep 10, 2011 | Inverter Aims Pure Sine Wave Power...
I have a problem with my inverter in that when i load,it cutts off, and at that moment it is only one lighting point that is on,it tells me that their overload and fuse blown,what do i do?
I have an Aims 2500 W inverter that was damaged from an accidental connection of voltage from the grid. i replace all of the IRF260n FET transistors but it is still shutting down as soon as it is turned on.Can some one tell me if those FET must have a drive at the gate. Before it will work
Feb 17, 2011 | Inverter Aims Pure Sine Wave Power...
I have a Aims Inverter PWRINV5000W with all the lights on but no output at plugs.
Hi!!
There is a fuse or thermal device for the AC outlet(s) protection, is either next to the outlet or same place but inside the unit. The cover need to be removed to change/reset it.
Let me know if you found it. Good Luck!!
Dec 08, 2010 | Inverter Aims Pure Sine Wave Power...
Red fault light comes on after about 10 mins and
NOTE:
RECOMENDATIONS:
UPGRADE.
R/
David
Dec 24, 2009 | Inverter AIMS 1000 Pure Sine Wave Power ...
Aims Inverter PWRINV5000W Installation Manual I just went to install it and no manual in the box
Here you go- contact info for Aims. They can provide you with a manual. Good luck....gary
AIMS Power Contact Information:
9736 S. Virginia St. STE A
Reno, NV 89521
Tel: (775) 359-6703
Fax: (775) 359-6753
e-mail:
sales@aimscorp.net
techsupport@aimscorp.net
customerservice@aimscorp.net
Jan 10, 2009 | Inverter Aims Pure Sine Wave Power...
Aims 5000 watt inverter troubleshooting
The amp meter on this unit measures the battery current. So if you have an 8 amp load at 120 vac you will draw more than 80 amps at 12 volts and 40 amps at 24 volts. While this may not explain the 180 amps that you are seeing -- it's possible that the dryer is drawing more than 8 amps.
Dec 10, 2008 | Inverter Aims Pure Sine Wave Power...
Inverters / Microwaves
A pure sine wave inverter will usually allow a microwave to run quieter and cooler and more efficiently all around.
So the oven has 850 watts of cooking power?
That would mean its power consumption could be as high as 1700W while cooking, but it could surge or spike higher when it first turns on due to the inductive load it offers.
I would think a 3000W inverter should handle that, but that also depends on its peak surge wattage.
As long as the microwave works properly in a normal wall outlet, I'd say maybe it's too much for this inverter and I'd check back with the dealer on this for his input.
Bottom line: Make sure the oven works well in a wall outlet, and check your inverter's peak surge rating.
We're happy to help and we appreciate your thoughtful rating of our answer.
Apr 11, 2008 | Microwave Ovens
Electronics - Others Logo
126 people viewed this question
Top Inverter Electronics - Others Experts
mntech1
ray gallant
Tom Chichester
Are you an Inverter Electronics - Other Expert? Answer questions, earn points and help others
