Question about Brother Office Equipment & Supplies
Brother HL 2040 printing not aligned since changing toner and drum unit.
I've changed the toner/drum unit (as one) multiple times and never had a problem. This time I bought it online but it turned out to be only the toner; I then bought the drum unit, inserted them together and into the printer, and now, no matter what I do (reset the printer, reset the page settings as per Brother's support page, a variety of button pushing exercises as per youtube print "experts", turning the printer off for 20min etc), it still prints skewed. I've checked the paper aligning slides and they're straight. I'm at my wit's end; please help!
  • 4 Answers
SOURCE: BROTHER HL-2040
I think the previous post applies to resetting the drum light after replacing the drum.
You need to reset the toner end-of-life condition.
  1. Open the Front cover
  2. Press and hold the GO button
  3. Power ON the printer while continuing to hold the GO button
  4. All 4 LED's will light up and then 3. Once the 3 LED's are lit, release the GO button
  5. Press the GO button 2 times. This will cause the
    LED's to light solid
  6. With the LED's lit solid, press the GO button 5 times
  7. At this point the Paper light should be blinking. Toner end-of-life has been reset
  8. Close the front cover.
Posted on Mar 21, 2008
  • 3 Answers
SOURCE: brother 2040 all lights keep blinking
Just got the following solution that worked for me:
1. Power Unit off
2. Open front cover
3. Press and hold GO and turn power on
4. When all 3 lights lit release and press GO twice
5. All lights turn solid
6. With all solid, press GO 5 times
7. Ready light GOes red
8. Close door and you're all set
Got it from here:  http://www.fixya.com/support/t612015-print
Posted on Jun 10, 2008
SOURCE: Brother Printer HL 1240
OK figured out the sequence to resolve this error:
power off unit
unplug power cable for 1 minute
reset the power cable
open front door
press and hold the reset button under the lights
turn the power on
printer should then be reset
Posted on Aug 16, 2008
SOURCE: Printer won't stop printing alignment sheet, following changing of ink cart.
my printer only printed 1 page out of 3 so now it wont stop. it pulls the paper in and comes out blank. this will keep going unless i turn it off. how do i reset my printer?
Posted on Jan 11, 2009
Patzky
  • 240 Answers
SOURCE: toner light is flashing and printing has stopped
Hello ,
This problem is a common issue and easily fixed.
When putting in a new toner cartridge, the printer usually automatically resets the toner count.
In a situation like this, the printer did not automatically do the reset and so we must manually reset the printer.
To manually reset the printer, first, remove the toner from the printer and separate it from the drum unit.
With the toner cartridge in hand and the brother writing facing you, look to the left side of the cartridge. You should see an arc shaped opening with a white tab in it.
The tab is set at the right position and must be pushed back to the left side of the opening.
To push the tab back, you must turn the grey gear attached to the front roller upwards as you push the tab.
Once the tab has been placed to the left position, the printer will accept it as a new toner cartridge.
Thanks,
Pat
Posted on Apr 01, 2010
Testimonial: "Thank you so much Pat, such a simple fix and I was about ready to buy another printer. Very helpful."
How do i change the toner on m my HL 2040 brother printer
How to Change a Toner Cart in a Brother HL 2040
The Brother HL 2040 laser printer has a toner cartridge that supplies toner to the drum assembly so that the printer can print properly. When the LED on the front of the printer indicates you are low on toner, you will need to replace the toner cartridge to maintain good print quality. Fortunately, the toner cartridge can be replaced without any special tools.
Instructions
Things You'll Need:
* Replacement toner cartridge (part number TN350 or TN360)
* Paper towel or scrap paper
Grasp the front cover of the printer and pull it toward you to open the toner door. Reach into the printer and grab the combined toner cartridge/drum assembly. Lift up slightly and pull it out of the front of the printer.
Place the cartridge and drum on a paper towel, spare sheet of paper, rag or other surface that can get dirty. Loose toner particles may spill from the cartridge.
Press the blue locking lever on the cartridge/drum unit to unlock the toner cartridge from the drum. Lift the toner cartridge up and away from the drum unit. Dispose of the old toner cartridge in accordance with your local regulations. Seal it in a plastic bag to keep loose toner from spilling.
Gently shake your new toner cartridge back and forth a few times to distribute the toner evenly across the width of the cartridge. Remove the plastic protective cover from the bottom of the cartridge.
Place the new toner cartridge onto the drum unit and press it down gently until it locks into place. The blue locking lever will automatically click into place. Verify that the toner cartridge is securely connected to the drum.
Locate the corona wire cleaner tab at the front of the drum unit. Slide it back and forth several times to improve the print quality of the drum. Set the tab back in the home position when finished.
Slide the combined toner cartridge/drum unit back into the printer and close the front cover.
Hope it helps...
Dec 02, 2010 | Brother HL-2040 Laser Printer
Brother HL 2040 prints extremely light and seems to smudge? Just changed out the tone cartridge and no change.
I'm not sure if the drum is going out or not. How many toners have you used? The drum is rated at 12,000 pages and the toner is supposed to yeild 2500 pages, so 4 or 5 toners ought to finish the drum. Did you clean the area around the drum? I don't think you're supposed to touch it, but I've never had to touch my 7240 in 4 years, except to change the toner.
The good news is the toner will fit in more than one Brother machine and the printers are inexpensive. It almost makes buying a new machine more economical than a drum :-}
The HL printer is Manufacturer Discontinued, the new ones use a 360 series drum and toner, and the MFC's (7220 etc.) are about $200 vs. $116 for the drum. Hmmm.
Might be time to upgrade.
Carl
Jan 08, 2010 | Brother HL-2040 Laser Printer
Drum light HL-2040 Brother
  1. Open the front cover.
  2. Locate the control panel button under the LED lights on the left side.
  3. Press the control panel button until all lights are lit, then release it.
    The Drum counter is now reset.
On older models
  2. Remove the drum and toner
  3. Press the Go buttom button until all lights are lit, (they come on one at a time) then release it.
Oct 14, 2008 | Brother HL-2040 Laser Printer
Brother HL2040 PRINTING DOTS
1- change the drum unit
2- check the fuser unit
Sep 06, 2008 | Brother HL-2040 Laser Printer
Changing the toner on a brother HL-2040 in my office
It should be one unit??? look at the toner cartridge and look for a shiny cylinder that is the drum.
you can google brother hl2040 drum and click on images on the top right of google to see what it looks like
Aug 21, 2008 | Brother HL-2040 Laser Printer
HL 2070n
Copier tech here. :P I just had to look this up. looked to the internet first, before going to find a manual.
open front door (the door for toner and drum units)
hold Go untill all four lights are on.
Release Go
Shut door
good to go.
Have a good night ya all.
Mar 28, 2008 | Brother HL-2070N Laser Printer
Dark line down printed page
problem in your fuser assy call to hardware service provider
Feb 28, 2008 | Brother HL-2040 Laser Printer
HL-2040 CHANGE TONER
I just had the same problem and fixed it. Hold down the blue "go" and red "job cancel" buttons at the same time for a few seconds. The printer churns into action and the green status light goes on. I was able then to print.
Dec 30, 2007 | Brother HL 5040 Laser Printer
Reset the drum counter by opening the front panel, then hold down the power button for about 5seconds until ALL the leds are on. Then realease the button and close the front panel. Your coutner will be resetted.
Dec 22, 2007 | Brother HL-2040 Laser Printer
James Cagle
James Cagle
Samyfam
Samyfam
Jim Keysor
