How to get tv started after being unplugged for a few monhs
Generac GP5000 will turn over but will not start, If I spray start spray it turns over for a few seconds and stops. someone told me to use sea foam because it had been un-used for about 6 monhs. Ccould...
FRIST O FALL CHECK TO SEE IF THERE IS A SHUT OFF VAULVE UNDER THE GAS TANK SEE IF THIS IS OPEN ALSO HOW OLD IS THE GAS , DONT LEAVE GAS IN THE GAS TANK THE GAS TODAY DOES NOT HAVE BUT A MONTH OF SHELF LIFE. YOU MAY HAVE TO PULL THE CARB DOWN AND CLEAN THE BOWL AND THE JETS IN THE CARB ALSO START BY PUTTING FRESH GAS IN THE TANK
Aug 04, 2013 | Generac 5724 GP Series GP3250 Portable Gas...
Hi,i have peugeot 407 2005,some time car start jerking while driving and start smoking if i stop car some where rpm meter continucly up and down and car realease black smoke but after switch it off and...
Hi I think you need to take car on a 20min long drive over 2000rpm try and keep revs high to clear filter. If that don't work you may need the fap filter changed hope this helps. Peter,
Dec 23, 2012 | 2005 Peugeot 407 2.0
On Transmansmission, when it shifts from 2nd to third, it acts like it is trying to find a gear to go into. What can be wrong
thats because it is ... its can alsobe called SLUGGISH.NO MATTER WHAT ITS CALLED..it can b as simple as fluid to a bad shift pattern that ur computer has programed during the last few monhs
Nov 21, 2012 | 1999 Chevrolet Silverado 1500
LG 42 LCD no sound or picture
Did anyone find out the solution for this??????? I have the exact same problem with my LG 32 LCD. I only had it for a year and a half, and the green light blinks a few times and it shows no picture. Not even a red light when the tv is off. The same thing happened a couple weeks ago and by some miracle it started working again.
Jan 28, 2009 | Televison & Video
Cant see anything
Probably you turned hdtv on change it back to tv
Oct 03, 2008 | Microsoft Xbox 360 Console
DVD not reading but spinning
Are you using +R discs(not the -R)? Use Sony brand +R or try using a few +RW's and see if that corrects the problem.
Feb 23, 2008 | iLO DVD Recorder DVDR05
Mr ilo dvd R04 recorder is locked at the hello screen!!!!
The unit is not finishing the start up diagnostic. This could be forseveral reasons. The most common problem with the Ilo04 is power supply. On the power supply board check the two big capacitors to see if they are swollen or leaking. If so then change them and try that.
Jul 13, 2007 | iLO DVDRH04 DVD Recorder
Power light flashing/ no picture
I have the same problem. The only way to get the TV to come on is to unplug it, but once you get it back on it turns itself off again in a few minutes.
Jul 11, 2007 | Toshiba 56H80 56" Rear Projection...
Tsonic 610 not powering on
Hi , I am also having a Tsonic 610 2Gb Player . I just bought it in April 2007....it's just 2 months old...whenever I start it,it's gettting swithc off..so I am not able to use MP3 player now...
Dec 10, 2006 | Transcend T.sonic 610 MP3 Player
Televison & Video Logo
Top Televison & Video Experts
