Question about Cell Phones
How do I change storage from phone to sd card on my k-touch touch 2
SOURCE: Option to use SD card as usb not available
Ignore the manual..It directs you to drill down into the settings for the sd card and set it as mass storage..no such option exists in the menu.
Follow this:
plug in usb
go to NOTIFICATIONS
touch the notification in the list that refers to the usb having been connected..you will receive a prompt to "mount" the sd card.
now you can access it.
viola.
bada bing
Posted on Nov 27, 2008
pmf1977
  • 12 Answers
SOURCE: Setup for mass storage on phone wont work
plug in your usb lead
when the phone makes its noise to comfirm lead is plugged in
a usb icon should appear on the top menu bar
hold the bar and drag it down
you should see a notification USB connected
select it
select MOUNT
there ya go you should now be able to see it
Posted on Jan 08, 2009
SOURCE: how to activate the memory card of samsung
i have samsungSGH-D900 i, i don,t know how to activite its memory card.
Posted on Jun 12, 2009
kanav_bond7
  • 89 Answers
SOURCE: "Storage Device Unreadable. Format Now.?"
yes there is a possible solution to your problem....there seems to be a problem with your card....and it doesn`t look like you can get your data back from it ...so you will have to format your memory card....connect your card to a computer through a memory card reader by also using your micro card`s adaptor and then format it from your computer......hope this helps.....please vote ...help us to help you better
Posted on Aug 07, 2009
SOURCE: i have a htc touch
my htc touch p3450 memory expansion slot is shown in use but when i see in setting>system>memory>storagecard .. here it shows not installed
Posted on Oct 05, 2009
How do you move internal storage to the sd card to free up internal space
touch the "Settings" icon, go down to the "Device" area, touch the "Storage" icon : go to the bottom of the screen, and select "Transfer data to SD card", then select the items you want to move.
You should also move some apps from internal storage to the SD card : "Settings", "Device", and touch "Applications" : then touch each and every application : for most of them, the button "Move to SD card" will be active, just proceed.
Dec 18, 2015 | RCA RCT6077W2 7" 4 GB Black Wi-Fi Tablet...
How do I change storage settings from internal to sd card
The ZTE Zinger sets default memory storage automatically. If an SD card is inserted, then the SD card is the default storage. If not, the internal storage is used.You cant change the default storage location.
SD card ZTE Zinger
May 29, 2015 | ZTE Cell Phones
How do I change the download settings from phone storage to sd card and transfer my music to my sd card on an android Alcatel one touch pop icon
Phone setting (the gear)
storage device settings
change primary storage from device to SD card
most files can be move by clicking option in top corner
really hope this helps?
Mar 01, 2015 | Alcatel Cell Phones
How to fix space problems on alcatel one touch pixi I have 8gig memory card and when I download it says not enough space please help me
Dear friend by default android installs all the apps at the internal phone storage and not the external sd card. So basically you have two options:
1 - delete some applications you don't use (old games and programs you don't use regularly )
2 - try to search google play store for app to sd (i am not recommending that option because 1 - you might need root ; 2 - some applications wont work if installed at the external storage )
Oct 31, 2014 | Cell Phones
Can't move things to sd card
One question. Were you able to move apps to the sd card before?
When you go to settings, storage, does it show the external sd card? I want to explain something first. The sd card is an expandable storage card, but it won't store your apps. If you want to check it out just insert the old memory card in a computer and look for any apps. Smartphones usually comes equip with 2 types of storage:
1. Internal phone memory: which could range from 500mb. to 2gb. of storage. This will be by default the location where the apps would be saved.
2. Internal SD Card: this is an expand storage that is already in the smartphone. Notice that when you see an ad for the phone it usually advertise whether it is 4, 8 or 16gb. That is the internal SD storage.
The third option is the external micro sd card, which is the one you are having problem with.
In storage under settings, see if you have an option to mount the sd card, maybe it's not mounted. You can also clon or copy everything from the old sd card to the new sd card using a computer, and then try it again.
Mar 12, 2014 | ZTE Merit 990G Net10
How do i remove SD card? From ZTE N861
If you need to remove the microSD card while the phone is on,
you must unmount it first.
1. Touch the Home Key > Menu Key > System settings >
Storage.
2. Scroll down and touch Unmout SD card > OK.
3. The icon appears in the status bar and then you can
safely remove the microSD card from the phone.
Hope this helps.
Dec 18, 2013 | Cell Phones
Cannot find where to put the SD card for Motorola Droid
Your phone supports microsd you can check here how to assembly your card
http://rapidshare.com/files/333706186/droid.jpg
To see the available memory on your memory
card, touch Menu > Settings > SD card & phone
storage.
Jan 08, 2010 | Motorola Mobility Droid (2 GB) Cell Phone
HTC P3400i PDA window moble have write protected SD Storage card
Hi. there may be two issues.
1. the storage card may be write protected. u need to remove storage card, eneble it for writing by moving the knob.
2. Storage card may be full.
Mar 26, 2009 | HTC Touch P3450 Smartphone
I have a htc touch phone and i put all my pics on the storage card, and than one day all pics where gone and nowi cant even save my pics to the storage card.. and now there is storage card , and storage...
Why this happens:
If for any reason your phone cannot find the SD card on boot it will create a folder on your Phone's Memory called 'Storage Card' to put the Temp Files, Pictures, Music, etc into. Now as soon as the SD card becomes available, since there is already a folder called 'Storage Card', it is forced to name the "Real" SD Card 'Storage Card 2'.
Solution: Delete the "Storage Card" folder and soft reset. If the phone finds the "Real" SD Card, it will be named 'Storage Card' again. If for some reason it is not found, you might have a corrupt SD Card that needs to be reformatted. This would of course loose all the information on the card, so hopefully this is not the case. Warning: If you have pictures or other files in the 'Storage Card' directory, you will want to move them to 'Storage Card 2' before deleting 'Storage Card'. Use the 'File Explorer' found in your 'Programs' to do this. Good luck!
Aug 27, 2008 | HTC Touch P3450 Smartphone
Cell Phones Logo
41 people viewed this question
Top Cell Phones Experts
Computer Repairing
Computer Repairing
William Alequin
Are you a Cell Phone Expert? Answer questions, earn points and help others
