Question about Home
Water found around the base of the toilet on the floor
  • 2,374 Answers
Or tighten bolts between tank and bowl. Make sure it's not a failed wax seal.
Posted on May 13, 2017
    Top Expert:
  • Home Master
  • 51,307 Answers
Run your fingers around the pipe from the cistern (tank) to where it goes into the pan( bowl)
there is arubber gasket( fitting there that perishes and leaks water every time the system is flushed
lfush the system and feel fro water leaks
new gaskets are available from any hardware /plumber shop
Posted on May 12, 2017
Leaking water at bottom centre both sides atbottom of base
call a good plumber your wax seal has gone the trip
Apr 13, 2015 | Home
It leaks water on the floor around the base when flushed. Only leaks when flushed Godfrey
The wax ring seal on the bottom of the toilet has let go. It isn't tough to fix. Two nuts hold the toilet down. Shut the water line in back off, take the 2 nuts off, and move the toilet aside. You;ll need a new wax ring, so you'll have to scrape the old one off. It will show you how to set it in and set the seat on. It only looks tough, but it's actually simple. Good luck!
Mar 18, 2015 | Home
Toilet flushed then dripping sound at floor level
If you;re sure its under the toilet, look for a crack in the base, especially around the retianing bolts, or the wax bowl seal is gone, needs replacing.
Apr 25, 2014 | American Standard Home
Caroma toilet 12years old, concealed cistern. Water leaking around base when toilet is flushed. water level maintained when not flushing, so the leak must be between the cistern and the bowl. Had a plumber...
Fixing a leaky toilet is actually rather simple, requiring few tools and just a little time and effort. In looking at Caroma toilets on Google, they appear to be just a standard type of unit, and should present few if any problems for yourself or any handyman of modest skill.
If it is leaking around the base of the toilet - where the toilet sits on the floor, the repair item is a simple wax seal. Here is a tutorial to effect this repair: Replace Toilet Wax Ring. The wax ring is very inexpensive, usually $5 to $10 USD.
If the water is leaking from between the tank (cistern) and the toilet bowl, the job is even easier, as it does not require lifting and moving the entire toilet. A good tutorial for that repair is here: How to Replace Tank to Bowl Gasket . The gaskets, new nuts, bolts and rubber seals come in a kit and also cost only $5 to $10 USD.
I am sorry to hear your Plumber insisted you buy an entire new toilet, but do remember he is in the business of making money!
Jan 28, 2014 | Home
How to change toilet bowl
Shut off water to tank and drain tank by flushing , then use a sponge to soak up any left. Disconnect water line, then 2 of 1/2" nuts at base of toilet ( floor ) . Lift toilet off, clean old wax off toilet and flange at floor, and install new wax gasket. Set toilet down straight and aligned with gasket and flange as well as studs. Make sure toilet is all way down on new wax gasket ( sit on it and move around a bit until toilet feels steady on floor ) then put nuts washers etc back on and snug it up. Don't tighten too much and snap base, just good and snug.
Aug 03, 2012 | Home
Leaking at base after flushing
are you sure its the floor connection as it could be the tank one, also if the floor section is there a insert sealed and fitted to the existing floor pipe and then the wax seal around this. similar model video. https://youtu.be/LebANJC2rx4
Jan 11, 2018 | American Standard Cadet 3 Right Height...
Toilet is unstable with respect to the floor. it rocks when you get on and off it.
It needs to be shimed,either floor uneven or casting is not uniform.It is a problum most people don't understand.Toilets when set need to be leveled if not you can break bowl.Go to home depot and in plumbing dept. ask for plastic shims-come in little bag,tap under toilet and then snug down bolts,(don't reef on bolts)when shes tight take flat head screwdriver and hammer and chop off shim flush.You should take dap tub and tile caulk (water soulible) and dap around bottom-keep wiping sponge with clean water around till it looks nice let set up for 12-24 hours,toilet should be rock solid.If by chance its leaking around base you'll have to reset with new wax Richie
Jan 27, 2011 | Kohler - Toilet - Two-piece - Highline -...
Our V&B Toilet is leaking water from the base of the unit (i.e. where it is concreted to the floor). The plumber who came to look at it seems to think that he has to break the toilet to get into it to...
yes it is a wax seal under the toilet, There is just 2 screws holding it down to the floor. Anybody could take it up and fix it.
The bolts are on the two sides down on the base. Prob has small square covers over them
Jun 02, 2010 | Villeroy & Boch 5C06 01 P8 Twist One Piece...
How to Install Toilet
It's not terribly complicated, assuming that by "install a new toilet" you mean where there was alredy an existing toilet. First, remove the old toilet. Shut off the water supply valve, and flush the toilet. Then use a spone to get rid of the water that remains in the tank. Remove the nuts on the two bolts at the base of the toilet where the toilet meets the floor. These are usually hidden under two plastic caps. Now gently rock the toilet until it comes away from the floor. Get help to carry it out. Clean up the old wax that's around the flange where the pipe disappears into the floor. Don't be a wuss, it's only wax. Now you'll need the new toilet, a new supply line, new mounting bolts (don't reuse the old ones) and a two wax rings. Yes, I said two wax rings. You'll see why in a minute. Assemble the new toilet according to the instructions provided. Now here's a warning: Do NOT overtighten the bolts the hod the tank to the bowl. You're dealing with ceramics here, don't break them. Now, put the new hold-down bolts in place on the flange. Read the insturctions that came with the toilet, but you have to do this NOW. Now you'll need a helper. With the toilet upsided down, unwrap a wax ring. Make sure it's room temprature or it won't seal. Press the wax ring around the outlet flange on the base of the toilet. Now you and your helper carefully turn the toilet over without crushing the wax ring. Lift the toilet and slowly lowe it so the wax ring is centered over the "flange" which is where the sewer pipe goes into the foor. Then press the toilet firmly in place. Now if you're like most people, you screwed up here and crushed the wax ring without being centered on the flange. That's why I told you to buy two. Now you know what not to do, scrape off the first one and start again. When you've got the toilet sealed on the flange, connect and tighten the nuts on the bolts. Now you may have to use a hacksaw to cut off the remaining ends of the bolts so you can get the neat little plastic caps to fit. Now connect the water supply line. Now's where you start praying. Turn on the water and let the tank fill. Check the supply line for leaks. Fix as necessary. Now flush. Is water running out from around the base of the toilet? No? Good, you got a good seal. Yes? Very bad. Time to go back to the home center for yet another wax ring. Repeat the sealing process and get a good seal this time.
Aug 27, 2008 | Kohler Santa Rosa K-3323-0 White Compact...
Home Logo
Top Home Experts
john h
Tom Chichester
Are you a Home Expert? Answer questions, earn points and help others
