Trying to figure out how to get free tv stations to work antenna not working will convert box work
nickstorm
  • 93 Answers
SOURCE: GE Spacemaker TV/Radio combination Model #7-7650
Yes, you will need an external antenna to pull in the digital signals. It will not work with the built-in antenna on the GE. Alternately, you can use an external antenna (ie, rabbit ears), connect them to the converter box, then connect the converter box to the antenna jack on the back of the TV (I think it has one). Granted, not an elegant solution for a kitchen TV, but it beats not using it anymore.
Cheers
Posted on Nov 11, 2008
SOURCE: How do I connect an analog VCR + converter box to a digital TV?
first of all does your television and/or vcr have a cable connector and/or a set of rca outlets? if they have a cable connection in the back all you have to do is hook the cable from the antenna to the "in from antenna" on your cable box and then connect a cable from "out to tv" to "in from antenna" on the vcr and a cable from "out to tv" on the vcr to "in from antenna" on the tv. then you need to make sure on the converter box and the vcr and look for a channel selector and see what channel they are on. most vcr's have a selector for either channel 3 or 4, look at what channel it is set to and if your converter box has the same thing then match it with the vcr. then tune your tv to that channel and you should be able to work your vcr as long as the vcr/tv button shows that you are on the vcr. now if your tv and/or vcr have rca outlets and your converter box has the same then just hook the cable from the antenna to the cable box and substitute the rca cable for the regular cable and tune your tv to video or line input.
Posted on Jan 01, 2009
  • 362 Answers
SOURCE: Not picking up Digital signal from box but can receive it analog
So many factors could be affecting your reception. Keep in mind that the digital signal is all or nothing, either you have a signal or you don't, with the regular signal you can pull in weak signals but you can't with digital. Your converter box when turned on will probably not pick up the standard signal. The distance from the digital signal and the direction the antenna is facing also will affect your signal.
Ok with that said you will have to clear the path between the broadcast signal and your antenna, I know this will be a chore but take your antanna out of the attic and put it outside as a test only, this dosnt mean you cant have it in the attic it will just be a signal test.
Once the antenna is moved, from the menu scan for channels and see what you get. Let me know and I can help further.
lone99star
Btw, I’m available to help over the phone in case u need at https://www.6ya.com/expert/jason_77a19afa8d604dee
Posted on Jan 09, 2009
SOURCE: insignia digital tv converter/indoor antenna no signal
I had the same problem but realized that when it said NO SIGNAL,,,,it just ment for that station,,,,,switch channels and they will start to come in,,,
Good Luck,
charh20
Posted on Feb 22, 2009
joboo1
  • 257 Answers
SOURCE: Does my Trutech PLV16190 require a digital converter box?
Hi, Please don't shoot the messenger, you asked but unfortunately the answer is yes. Your tv has an NTSC tuner which is an analog tuner, Sorry. But this should answer your question.
Posted on Mar 25, 2009
How to get analog channels on my Toshiba?
The problem is probably that your antenna can't pick up any of the remaining analog stations in your area. Only low-power stations are still broadcasting an analog signal. If you are using an indoor antenna, you might the signal with an outside antenna with an amplifier. (Check a site like tvfool.com to get the direction to any nearby analog station and make sure that your antenna is oriented correctly. This site or antennaweb.org will also help you orient your antenna for the digital stations in your area.)
You need a set-top digital tuner or a converter box to translate the OTA digital signals (ATSC) and translate them to the analog NTSC format. Low end converter models with only SD output are harder to find but still available. However, there are some converter boxes that have HD output as well. This one, http://www.solidsignal.com/pview.asp?mc=03&p=3500STB&d=iView-HD-DVR-ReceiverConverter-Box-for-TV-Antenna-QAM-(3500STB)&c=Digital%20Converter%20Boxes&sku= , lets you attach an external drive (USB flash drive or hard drive) . It connects via component video or HDMI. (We've had good luck with our model with a portable (2.5") external hard drive. It replaces the SD converter box and DVD recorder.)
I hope this helps.
(In my area, there is only one low-power station still broadcasting. Its transmitter is nearly 40 miles and can only be picked up with the external antenna and amplifier. If the weather is bad, we will lose that signal. Beware: an amplifier can become damaged and block the signal. The usual check for this removing the amplifier and attaching the antenna directly to the TV. For low-power stations, this test doesn't often help.)
Dec 21, 2014 | Toshiba 50H82 50" Rear Projection...
I have an older Sharp Aquos TV - model # LC-32G4U. I am trying to connect a digital antenna but it doesn't work. Anyone know if I need a separate digital tuner for this TV? Or what else might be t
There is no difference between a "digital" and analog antenna. Either antenna will capture the signal. What you need is a digital converter box to convert the over air digital signal to the older analog type signal your TV needs. You connect the antenna to the digital converter box, and the digital converter box to the TV.
Several years ago, the US government forced peopel to buy digital converter boxes or newer TVs that could pick up the digital signal. Either get a digital converter box or a new TV.
Oct 29, 2012 | Televison & Video
I cant figure out how to make this antenna work with my tv
Antennas are a thing of the past. Everything has gone digital including television stations. Get yourself a digital converter box.
Mar 24, 2011 | Televison & Video
Yes hello, i'm trying to hook up my Coby 12'1 digital tv to a converter box is that possible or do i need a cable box for it to connect?
You should be able to connect the tv to a converter box. This is good for OTA signals to a TV with an NTSC tuner (coax) or composite video input. http://www.cobyusa.com/?p=prod&prod_num_id=205&pcat_id=2007#features-tab has the manual for the DTV102. Put the antenna coax cable to the converter box ANT In and then either the antenna out to the TV or the A/V (composite) out to the TV's composite in. If you use the RF connection, you will need to set the TV to channel 3 or 4 and set the switch on the converter box appropriately. For a composite video connection, you will need to change the input to AV1 (if there are several inputs). Depending on the TV, there may be a source or input button on the TV. For other models this is only on the remote. If you have the original remote, no problem. If you have a universal remote, make sure that you have a key that corresponds to the feature and that you found the code that lets the key work for your TV. (Not all universal remotes have the feature.)
However, you should get the best antenna that you can and have it pointed correctly to receive the stations. Digital signal doesn't have borderline reception. Try antennaweb.org or tvfool.com to check the stations and directions in your area. Antennaweb assumes an outdoor antenna but is very conservative in the channel list that it will indicate you can receive. Tvfool lists the channel reception depending on the antenna type. Tall trees and buildings can block the signal.
I hope this helps.
(please note that surges from the antenna can damage converter boxes and kill the tuner.)
Feb 08, 2011 | Coby DTV102 ATSC STANDARDDEFINITION TV...
Cannot get TV to work on antenna...In menu I set cable to off, then initiate autoprogram but tv says "no signal". My antenna has a bulit in digital to analog converter. Suggestions?
Must buy a Digital converter box and to install it seperatly to devert back to tv anlogue tv signal to make the tv to work.Tv antena inverter alone can't convert analogue signal to digital signal only can give basic tv antena for better antena reception.Tries websites like Ebay.com,Amazon.com to buy a stand alone digital converter box to install and that didigal antena install and auto scan again u should able to get all the free DTV air stations.
Feb 01, 2011 | Sony FD Trinitron WEGA KV-32FS120 32" TV
My EmersonEwf2006 was connected and programmed to a cable box. Trying to use this same tv now with an indoor antenna for local channels. Lost my guide book therefore I have no directions. can't get it...
Here is a link to a site where you can download the manual at no charge: http://tv.manualsonline.com/manuals/mfg/emerson/ewf2006.html. You will need a digital TV converter for that set. The US is now all digital for over-the-air (OTA) TV signals. If you have a digital TV converter, and have followed the instructions in the manual installing your indoor antenna and get no stations, you need a better antenna.
Jan 06, 2011 | Televison & Video
Trying to hook up converter box to Westinghouse flat screen the converter is magnavox sdtv. I get autoscan but no channels are found. I do not have an antennae. Do I need one? Help!
If ur tv a LCD tv it is a digital tv.U do not require a Digital converter box to get the new DTV free air signal broadcasting tv channels stations.But u do require a good digital antenna for it to recieve a long an strong signals to recieve a DTV free air broadcasting tv channels stations.
Dec 07, 2010 | Philips Magnavox 50ML8105D 50" HDTV DLP TV
Want to continue to record on my VCR after digital hookup
You have to use the RCA plugs on the back of the converter box and the tv (red,yellow and white). Or you can attach the antenna wire to box and then attach the wire that comes with the converter that is listed as to the tv and instead attach it to the antenna in on the vcr. The converter box will determine which channel your vcr will get a singal to record from. Your VCR for every program will be set to channel 3 or 4 (depending on what your converter box is set to broadcast on). Make sure the power saver on the converter box is turned off as if you want to record a program in say 4 hours, if the converter box turns off in 2, your vcr will have nothing to record.
I ran seperate coaxible cable to the tv from vcr and unplug the tv converter box everytime I want to watch the vcr. You can also use the RCA cord to send the signal from the vcr to the tv and use the input signal to watch your recorded programs. I had static showing up everytime I played it through the second converter box thus I solved it by running a seperate coax line. I don't know if you will have this problem, just wanted you to be aware.
Jan 12, 2009 | Insignia Digital-to-Analog Converter for...
Insignia digital tv converter/indoor antenna no signal
Ok first I can save you some money. Take your "HDTV" antenna back. There is nothing different about the antennas needed receive analog and digital signals. If you got reception without your converter box, use the same antenna with your converter box.
Next let's see if there is a problem with the box. Hook up a television with the antenna. How many stations do you get? Now hook up the same television & antenna, but this time put the converter box between the antenna & the TV. Do not turn on the box. Now how many stations do you get? If the number is different, the box is not allowing the antenna signal to pass through. That is bad. You want your signal to pass through the box so you can still pick up stations that don't broadcast digitally. Some areas of the country will not be covered by digital stations from all major broadcasters when the changeover happens in Feb.
My suspicion is either you did not have the antenna hooked up to the converter box when you searched for channels OR you are in an area that is not yet broadcasting digitally.
I hope this helps you solve your problem. Thank you for using FixYa and feel free to add more questions here by using comments.
Jan 09, 2009 | Insignia Digital-to-Analog Converter for...
Hooking up converter box when i have a dvd player and direct tv
Hook your Insignia box between your antenna and your television. You still need the antenna.
Jan 01, 2009 | Insignia Digital-to-Analog Converter for...
Televison & Video Logo
18 people viewed this question
Top Televison & Video Experts
