Question about Samsung Dryers
How do you reset a samsung gas dryer dv42h5000gw computer
Samsung gas dryer gas valve coils
Go to www.repairclinic.com and enter the model of your Samsung gas dryer. You will be presented with a list of common repair parts and may be able to view a video showing disassembly of a typical Samsung dryer. You also can get a straight answer regarding replacement.
Jul 14, 2016 | Whirlpool Dryers
Samsung dv42h5000 door switch problem
Door switch wiring may be loose. Carefully disconnect the power plug of dryer and make sure the gas circuits are shut before you attempt any work on the dryer.
Go to page 7 of this technical manual to check door switch condition.
http://files2.appliancesconnection.com/attachments/D1401803361.pdf
Sep 01, 2014 | Samsung White Front-Load Gas Dryer -...
Is there a reset on a Samsung dryer model number DV220AEW/XAA
normally if u unplug it for a couple minutes then plug back in , may reset . also try putting it on the on position then open and close the lid slightly 6 times withing 12 seconds, it may reset it
Jun 03, 2014 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Can this samsung gas dryer convert in electric dryer too
While it is possible to convert your dryer from electric to gas or vice versa, you will find the cost to be excessive and not worth consideration. A gas dryer will have3 a gas burner and ignitor circuit system while the electric dryer will have a heating element and controls. This is NOT a practical conversion nor would it be cost effective. If you need a gas dryer for your new home, purchase a new dryer or save a few $$$ and check your local Craig's List for a good deal on a used gas dryer. Just beware that you don't buy someone elses problem. There are legitimate sales caused by moving or upgrading appliances that will allow you to find a great bargain. Drop any notion of converting your dryer!
Apr 01, 2014 | Samsung DV419AE Dryer
Gas smell inside samsung dryer when off
Very seriuse must repair gas valve may need to change
Dec 06, 2013 | Samsung DV456GWHDWR 7.3 cu. ft. King-Size...
Samsung as dryer will power up but wont tumble
If it powers up but the motor doesn't work then one of the 2 power wires works. Find the 30 amp double breaker and shut it off and back on to reset it
Oct 14, 2013 | Samsung DV218AG Gas Dryer
How di i reset my samsung dryer
Did you give it plenty of time to cool down before you moved it? If not, you heating element could have opened - if everything else seems to work except heat, but you should also check the thermal switch.
Jan 18, 2012 | Samsung 7.3 Cu. Ft. 9-Cycle Super Capacity...
Dryer runs but there is no heat, is there a reset button? model dv218aeb
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check outthis electric no heat tip...
heatman101;';'
Jul 31, 2011 | Samsung DV218AEW Electric Dryer
Dryer was working fine. Still runs, tumbles, etc, but all of a sudden, no heat. Only 2 yrs old. Cleaned vent and lint filter. Is it likely a hi limit switch (if so, can it be reset or does it need to...
Hi, If you are having problems with your gas dryer not heatingthe most common problem is that the ignitor goes bad. Even though it glowssometimes it is still not working properly. if you dryer is gas check out this gas no heat tip.... If you have an electric dryer, you can have many differentthings that can go wrong causing the dryer not to heat. check out this electric no heat tip...
heatman101
Oct 13, 2010 | Samsung DV218AEW Electric Dryer
Samsung gas dryer convert to propane
I purchased a Samsung steam gas dryer and found that no one in our area knew anything about them, Fortunately I am a gas tech. but have never worked on this brand. The first thing is you should always use a gas technician before doing this. Secondly turn off the gas and electricity. You must remove the two screws from the back that hold on the top of the appliance and set this aside. Then lift up the front electronics and disconnect the wiring harness, once you've done this there are 5 screws along the top of the silver strip or door area. This will alow you to lift up the front and disconnect the wiring harness and set aside. now you can follow the instructions on converting your dryer. PLEASE check for LEAKS and proper gas flow. Follow the same steps in reverse to put the dryer back together and happy drying.
Mar 18, 2009 | Samsung DV448AGE Gas Dryer
Dryers Logo
49 people viewed this question
Top Samsung Dryers Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Samsung Dryer Expert? Answer questions, earn points and help others
