Question about Lands Phones
My phone says out of range what do I need to do to get a dial phone back?
Have out of range of base message
does the base unit have a dial tone . if no then you need to contact your land line phone company of course assuming you have it plugged into a phone line coming into the home
Dec 22, 2015 | Vtech Lands Phones
PEOPLE CANNOT DIAL AN EXTENSION
The extension range needs to be allowed in the Auto Attendant. For example, if most all of your extensions are in the 100 series range and you are trying to get to a 200 series extension then you have to have the option in the Auto Attendant (under Menu tree) for button 2 that says "Reserved in Dial plan".
If the extension is in the correct range then you should check to be sure that the extension is Dial Plan, Tables, Internal 3 Digit extensions (click devices using for older software). Make sure that extension is in the list (on the left for older software).
Jun 11, 2014 | 3Com NBX 3102 IP Phone
How do I reset my phone to reset to get back in range it says out of range anyone have instructions ?
Unfortunately, I do not have a manual for the GH-4102. However, most cordless phones get out of range messages at a few points: low handset battery, no power at the base or no dial tone at the base. Other possibilities are the phone base and handset lost the registration or one or the other isn't transmitting/receiving properly.
Things to try: unlpug the base power (from both the wall outlet and the phone) and phone line cord and remove the battery from each handset. Wait a few minutes and then reconnect the batteries and plug in the power and data connections. (Check when you unplug the base power adapter if it was warm; that indicates the unit was at least getting power at that point.) Recharge the handset batteries and then re-register the handsets, if needed.
Consider replacing the handset batteries if they are more than a year old (this includes the time that the phone may have been on a shelf after manufacturing). Try a new phone data cable (RJ11).
Next test your phone line and make sure that you have a dial tone. I like to use an old corded phone with the new phone cord for testing. If there is no dial tone, test the line at another jack. If there is still no dial tone, find your incoming phone line and open the service box. If you have a relatively new service, you will be able to plug your test phone into the service box and test there. If you can't test the line or there is no dial tone at the service box, contact your telephone company. They will test and fix outside problems for free.
If the problem is inside, look at all accessible wiring and make sure that the lines aren't damaged. If only one jack is bad, open the faceplate and fix any loose wires. There are two types of connections. The first holds the conductors under screws and the wire must be stripped back and secured. The other uses a keystone jack. The conductor wires are not stripped but a special tool punches the wires into place. You can find the punch-down tool at many hardware/home improvement stores in the wiring section. See http://www.lanshack.com/wire_phone_jack.aspx for a picture of the correct wiring for the jack.
If your phone line has a dial tone and the above fixes didn't work, contact the company and get the phone repaired if it is under warranty (usually 1 year). If it is out of warranty, then decide if it is worth repairing or if you should replace the unit.
I hope this helps.
Jan 09, 2012 | Southwestern Bell GH-4102 Twin Cordless...
My first line will not work anymore, it just dials and then the person dialing it gets a dial tone. So, I had to forward it to one of my other lines. How do I fix this?
What do you want to change? What feature is programmed on the button?
"EACH OF THESE CODES ARE PRECEEDED WITH THE ""FEATURE" " KEY"
**CONFIG NORSTAR CONFIGURATION PROGRAMMING (INSTALLER)
**SCPLUS NORSTAR SYSTEM COORDINATOR PLUS PROGRAMMING
(CICS AND ICS 2.0+)
**ADMIN NORSTAR ADMINISTRATIVE PROGRAMMING (SYS Coordinator)
**BASIC NORSTAR BASIC PROGRAMMING (CICS & ICS S.0+)
**SET NORSTAR SET PROFILE
**LINE NORSTAR LINE PROFILE
**USER NORSTAR USER PREFERENCES (CICS & ISC 2.0+)
**TIME NORSTAR TIME AND DATE (CICS & ICS 2.0+)
*0 BUTTON INQUIRY
*1 FEATURE KEY EXTERNAL AUTODIAL
*2 FEATURE KEY INTERNAL AUTODIAL
*3 FEATURE KEY PROGRAMMING
*4 PERSONNEL SPEED DIAL
*501 SELECT ENGLISH
*502 SELECT FRENCH
*503 SELECT SPANISH
*6 RING TYPE
*7 DISPLAY CONTRAST ADJUST
*80 RING VOLUME ADJUST
*81 MOVE LINE KEYS
*82 DIAL MODES
*831 AA ON/OFF (CICS)
*832 CCR ON/OFF (CICS)
*833 AA/CCR RECORDING MAINTENANCE (CICS)
*84 AUTO LOG OPTIONS
*85 CALL LOG PASSWORD
*89 PROGRAMMED RELEASE
*9 RUN/STOP
0 SYSTEM SPEED DIAL
1 SEND MESSAGE
#1 SEND MESSAGE CANCEL
2 RING AGAIN
#2 RING AGAIN CANCEL
3 CONFERENCE / TRANSFER
#3 CONFERENCE SPLIT
4 CALL FORWARD
#4 CALL FORWARD CANCEL
5 LAST NUMBER REDIAL
60 PAGE GENERAL
61X PAGE INTERNAL ZONE (1-6)
62 PAGE EXTERNAL
63X PAGE INTERNAL ZONE (1-6) PLUS EXTERNAL
64 LINE POOLS
65 MESSAGE REPLY
#65 MESSAGE REPLY CANCEL
66 VOICE CALL
67 SAVED NUMBER
68 RESTRICTION /COS OVERRIDE
69 PRIORITY CALL
70 CALL TRANSFER (BLIND)
71 LINK (HOOK FLASH)
72 TIMED RELEASE
74 CALL PARK
75 GROUP CALL PICKUP
76 DIRECTED CALL PICKUP
77 CALL DURATION TIMER
78 PAUSE
79 EXCLUSIVE HOLD
800 TRUNK ANSWER
801 CALL QUEUING
802 GROUP LISTENING
803 SHOW TIME
804 WAIT FOR DIAL TONE
805 TEST SETS (2.0)
806 HIDE DISPLAY
808 LONG TONES
810 MAKE BUSY
811 CALL INFORMATION
812 ENTER CALL LOG
813 LOG IT
815 AUTO BUMPING
817 IRAD TRANSFER (CICS ONLY)
819 OUTGOING NAME AND NUMBER BLOCKING (4.1)
#819 CANCEL OUTGOING NAME AND NUMBER BLOCKING
82 CAMP ON
83 PRIVACY CONTROL
84 LINE REDIRECTON
#84 CANCEL LINE REDIRECTION
85 DO NOT DISTURB
#85 CANCEL DO NOT DISTURB
86 BACK GROUND MUSIC
#86 CANCEL BACKGROUND MUSIC
87 "SERVICE MODES (DR-3,4,5)"
#87 CANCEL SERVICE MODES
870 SHOW SERVICE MODES (CICS)
871 EXTENDED RINGING (ICS)
#871 CANCEL EXTENDED RINGING
872 ALTERNATIVE RESTRICTIONS
#872 CANCEL ALTERNATIVE RESTRICTIONS
873 ALTERNATIVE ROUTING
#873 CANCEL ALTERNATIVE ROUTING
88 VOICE CALL DENY
#88 CANCEL VOICE CALL DENY
FEATURE 900 CODES ARE USED FOR OPTIONAL EQUIPMENT SUCH AS:
"VOICE MAIL, ACD, DIAL BY NAME, DOOR PHONE, ETC."
THE FOLLOWING ARE SOME COMMON USAGES:
9** "RAD PROGRAMMING (RAD 2, FASTRAD)"
9*0 RAD TRANSFER (ALL BUT CICS IRAD'S)
9*1 CHECK FEATURE CODES FOR VOICE MAIL
9*2 SMDR Admin
9*3 LOGGER TIME STAMP
9*3 VMI Codes(this was on an 8x24, came up on this code rather than F9*9)
9*4 NORSTAR DOOR PHONE PROGRAMMING
9*5 FLASH LOW RANGE CHECK FEATURE CODES
9*7 ACD ADMIN MAINTENANCE SESSION
9*9 VOICE MAIL INTERFACE (VMI) CODES
900 SMDR,enter an account number to be logged with the call
901 ACD LOGIN
901 VMI Admin
902 ACD UNAVAILABLE
903 VOICE MAIL HIGH/LOW RANGE SELECTION (DISABLED AFTER USE)
903 ACD CANCEL WRAP
904 ACD HELP
904 FLASH ACD LOW RANGE LOGIN/OUT
905 ACD CATEGORIZE
905 FLASH LOW RANGE DN IDENTIFIER
906 ACD RECORD CALL
906 FLASH LOW RANGE VM TRANSFER
907 FLASH LOW RANGE VM INTERRUPT
908 STAR TEXT (OBSOLETE)
908 FLASH ACD LOW RANGE BUSY MODE
909 ACD ANN. MAINTENANCE
909 FLASH ACD LOW RANGE QUEUE STATUS
910 FLASH LOW RANGE LEAVE MESSAGE
911 FLASH LOW RANGE OPEN MAILBOX
912 FLASH LOW RANGE OPERATOR CONTROL
913 ACD CALLS QUEUED
913 FLASH LOW RANGE SYSTEM ADMIN LOGIN
915 NORSTAR VOICE MAIL 2ND LEVEL ACCESS (PSWD=ACCESS2)
920 ACD ADMIN SESSION
921 ACD ROUTING SESSION DAY/NIGHT
922 ACD ADMIN STATISTICS SESSION
923 ACD GROUP STATISTICS SESSION
960 DIAL BY NAME (CINTECH NSVM OPTION)
961 DIAL BY NAME ADMIN (PSWD=1234)
980 VM SEND MSG TO ANOTHER MAILBOX
981 VM LOG INT MAILBOX
982 VM OPERATOR STATUS(PSWD=OPERATOR(67372867))
983 VM ADMIN PROGRAMMING (PSWD=1020000)
983 VM SOFTWARE LEVEL(LOGIN THEN OPTION 9)
984 VM TIME AND DATE(STARTALK Pswd=1020000)
984 AUTO FOREWARD TO VMAIL(NSVM4.0)
984 FLASH ACD LOGIN/OUT
985 "VOICE MAIL DN INQUIRY(RESET VM ADMIN PSWD 9,73738767793)"
986 VOICE MAIL TRANSFER
987 VOICE MAIL INTERRUPT
988 VOICE ACTIVATED NAME DIALING (NSVM 4.0)
988 FLASH ACD BUSY MODE
989 RECORD CALL (NSVM 4.0)
989 FLASH ACD QUEUE STATUS
Jun 23, 2011 | NorStar M7310 Corded Phone
Can't access missed calls, lost my instruction book, need one. Also I get missed calls when I'm sitting right beside the phone. It never rang.Could I talk to someone?
If this is a Panasonic phone connected to a phone system as in an office setting, sounds like the ringer has been turned off. Get someone to call your phone and while they are calling turn the jog dial to turn the ringer back on or use the LCD intertactive keys to turn the ringer back on.
Dec 08, 2010 | Panasonic Lands Phones
Dropped calls, and no dial tone on Panasonic Dect 6.0 phone
I am sure that is a service related issue and no the phone itself.
Apr 26, 2017 | Panasonic KX-TG1033S Cordless Phone
TReset for GE Pro Series Model 29451A
Remove the plastic speed dial card covering and the speed dial card. Press "program" with a pen tip. Press the intercom button. The lcd display says "address-xx" (probably out of range). Type in a new 2-digit address within range (the number of phones you have), probably 01, 02, 03 or 04. Then press the # key. The intercom light should turn green, and there you have it.
Sep 10, 2007 | GE 25413RE3 Corded Phone
Lands Phones Logo
14 people viewed this question
Top Lands Phones Experts
Computer Repairing
Computer Repairing
Are you a Lands Phone Expert? Answer questions, earn points and help others
