Question about Singer Sewing Machines
How to place the bobbin case in a 9240 singer
dupina
  • 110 Answers
SOURCE: Bobbin case
If your machine is older than 18 months, it needs a free upgrade from your dealer. The plastic see through needle plate needs to be replaced by a newer version that will keep the bobbin down. Further more a bobbin case position finger needs to be installed.
Posted on Nov 13, 2007
SOURCE: Bobbin Case
I'm having a similar problem today. I took out the bobbin case and when I went to put it back in, the whole system locks up. I've tired cleaning, changing needle taking the metal plate and piece that holds bobbin case out and put it all back in after cleaning. Nothing. My symptom is I can't get a complete stitch, the needle goes down, the whole deal acts like it will work and as soon as the arm of the bobbin case gets to 8 o' clock on the gears, It jams and won't hardly move. I cannot pull the bobbin case out easily after this. Perhaps there is someone out there that can help us!
Posted on Jun 23, 2008
kent581
  • 87 Answers
SOURCE: bobbin case retainer popping out on Singer Touch & Sew 625
Take the bobbin case out. Then when you go to put it in, realize there are 2 ways to get it. You have found one way. The other way is first look in the the slot with a flashlight before you insert it. There is a flat piece of metal the bracket needs to be slid under as it is inserted. This acts like a spring making it tight
Posted on Mar 18, 2009
Mongo32
  • 111 Answers
SOURCE: Sewing machine will not pick up bobbin thread.
needle's in backwards
Posted on Jun 11, 2009
  • 51 Answers
SOURCE: bobbin case futura singer sewing machine came out
The opening fits on the right side, toward back. There is the silver ring with the slot in it for the bobbin. That slot is facing the sewer.
Posted on Sep 06, 2009
Singer 457 thread hanging on bobbin case between bobbin case and clamp that holds it in place
hi larry.
not sure if this link will help,but go to this link and scroll down the page and you should see a service manual.plus you might see something on the page that might help you out.
Singer 457 thread hanging on bobbin case between bobbin case and clamp...
Oct 30, 2017 | Singer Sewing Machines
I have a singer 600E. When I put the bobbin case back in place and returned the black metal position piece to the left. Now it will not hold bobbin case in place. Please help.
Please download the user's manual for your machine free at the Singer site, under support. On page 50, it shows you how to remove and replace the bobbin case. I have a feeling that it's not quite in place, and that's easy to do. Ask me how I know.
Mar 16, 2017 | Singer Sewing Machines
How do you get the bobbin thread to work on the singer quantum 9240.
Difficult to determine since we don't really know what exactly is happening with the machine.
You might try downloading a manual. Your particular model manual is not available, but the 9224 is probably very similar (at least, in how the bobbin works).
Product Manual Results
Jan 23, 2017 | Singer Sewing Machines
Simplicity sewing machine SL 9240 was giving to me and when I try to sew the needle keeping hitting the bobbin holderr.
On the right side you have two knobs to make adjustments. The lower knob will move the needle left or right so it won't hit the bobbin holder.
May 31, 2014 | Singer 7442 Mechanical Sewing Machine
I recently acquired a Singer Zig Zag model 457. The machine was not picking up the cotton from the bobbin so I took out the bobbin and the bobbin casing. Now I cannot get the casing to fit back ptoperly so...
there are little tips on the 'backside' side of the bobbin casing you just have to wiggle the casing around keepingin mind that the back side needs to fit into place for the rest to drop on in. then you have to get just a little forceful with the the little black brace that should snug the bobbin casngback into place and keep it secure
Apr 01, 2011 | Singer Sewing Machines
The bobbin tension too tight on my Singer Quantum 9240. I believe there is a tension adjustment I can make on the bobbin case, but I have not been able to find my manual since we moved 2 months ago.
I am having this problem also; the thread catches in the **** in the bobbin. I am thinking maybe I am not threading the machine correctly--the bobbin area, not the top thread. I will try this & see if it fixes the problem. You may be doing the same as I am.
Jul 15, 2010 | Singer Quantum 9920 Computerized Sewing...
Can't get the bobbin case back in on my singer hd 110. It came out on it's own. The manual is not very helpful.
If this is a vertical/metal bobbin case; raise the needle to it's highest position. This will position the shuttle to accept the bobbin case.
If the bobbin case has a lever on the back, lift it and hold it open as you place the bobbin case back into the shuttle. It should click into place.
Mar 14, 2010 | Singer HD-110 Mechanical Sewing Machine
Can't put back the bobbin case in a singer 7442, it get sotck
Put the bobbin into the case so the thread is feeding clock wise and through the guide on the case.
Lift the lever to hold the bobbin in place.
Insert the bobbin case into the race/shuttle, still holding the lever out.
Align the finger on the bobbin case with the opening in the race/shuttle.
You may have to turn the bobbin case a bit to the left or right for it to line up.
Once it clicks into place it should work without any further problems.
Feb 19, 2010 | Singer 7442 Mechanical Sewing Machine
Need a tutorial for replacing the bobbin into the vertical case on a Model 1120 Singer. The bobbin always wants to fall out before I can get the rest of it put together, and locked.
Replacing the bobbin into a vertical bobbin case on a Singer model 1120 sewing machine.
I kept messing with it, and after a few hours it finally slipped into place.
Sep 19, 2009 | Singer Sewing Machines
Sewing Machines Logo
27 people viewed this question
Top Singer Sewing Machines Experts
Tally Girl
Tally Girl
mystery_soul
Are you a Singer Sewing Machine Expert? Answer questions, earn points and help others
