Question about Samsung Refrigerators
Samsung ice maker tube stocked with ice - Samsung Refrigerators
mikedurland
  • 481 Answers
SOURCE: ice maker tube freezing up
  • change the water valve on the back of the machine.
  •  the water valve is slowly leaking water up to the icemaker where it freezes and builds up ice, blocking the water flow.
Posted on Jul 05, 2008
vanni7
  • 163 Answers
SOURCE: no water coming down tube in kenmore ice maker
Hi!!! make sure your icemaker filling tube is not blocked with ice.its where the water comes into the icemaker .it can freez on you.put a hair dryer on to the filling tube and icemaker for 30 minutes. Also you can jump start the icemaker by putting a jumper wire show in this picture .If no ice then go to the back your frig and change your water valve ..
Posted on Jan 04, 2009
  • 351 Answers
SOURCE: Water supply tube keeps freezing off water supply.
its hard to tell but most likely the valve is not closing all the way. but it could be the ice maker calling for too much.... www.whirlpoolpartssurplus.com
Posted on Jun 23, 2009
kdgrayson
  • 195 Answers
SOURCE: MY MODEL 3211RFD sub zero ice maker quit. Got
timer
Posted on Aug 23, 2009
  • 358 Answers
SOURCE: frigidaire refrigerator, ice maker
If the ice maker is doing the normal cycle and when calls for water doesn't get any,probably the fill tube to the ice maker is clogh with ice because the dual valve (solenoid) is leaking and this water freezes up clogging the fill tube , or the solenoid doesn't work ,in both cases it has to be replaced(it's located in the back of the refrigerator attached to the water supply line).
Posted on Aug 29, 2009
My Samsung fridge has two ice makers. The top one is working, the freezer ice maker is not making ice. What can I check?
First make sure the icemaker is not turned off from the inside. Second.,There might be a blockage in the water tube that goes to that ice maker. Clean water tube that supplies the icemaker
Nov 20, 2017 | Samsung Refrigerators
Samsung rt323ted has 33. E flashing on door after power outage and I forgot how to get rid of it. Can you help?
Samsung refrigerator giving error code 33E means the water fill tube heater for the ice maker is loose or faulty.
Pull the ice maker out and check it.
Jan 03, 2017 | Samsung Refrigerators
Samsung side by side ice maker not working
You have 2 separate valves, 1 for the water dispenser and 1 for the ice maker. (otherwise your ice maker would overflow every time you got water from the dispenser and your dispenser would flow every time the ice maker went to refill.) They are fed from the same tubing.
The cube/crushed ice motor is completely separate from the ice maker itself and should have absolutely no bearing on the water flow.
You have narrowed down the problem quite nicely to the ice maker water valve. There is one more thing to check though, the connector. There should be a multi-contact connector from the ice maker to the back wall of the freezer, usually 6-9 wires. Pull that apart and check the cord side (ice maker side) for any corrosion. BE CAREFUL NOT TO TOUCH THE OTHER SIDE AS THERE IS LIVE 110V!!! If you don't see any corrosion, still try try disconnecting and reconnecting 5-10 times and see if that solves your problem. If you see corrosion, unplug the refrigerator before working on the back wall part of the connector. [This connector besides powering the ice maker also allows the ice maker to control the water valve which can't be inside the freezer]
Sep 03, 2016 | Samsung Refrigerators
How to remove DA97-12317A ice maker from samsung RF263BEAESR? I've unplugged the harness, and depressed the clip but it won't pull forwards. Do you have to pull hard?
The instructions above are wrong. The ice maker will not come out as instructed. There is a tube coming out of the back of the refregerator that passes in and around the bottom of the ice maker that won't let it slide out. If you could take the bottom panel off the ice maker, you will see the tube. To replace the ice maker, the entire enclosure may have to be removed.
May 03, 2014 | Samsung RF265AA Bottom Freezer French Door...
Samsung RS265TD Ice maker does not fill with water. After I press test button and the ice maker cycles I manually fill the tray with water and it will eject on next cycle etc. Good water supply on thru...
Hello
Either the fill solinoid is bad or the inlet tube at the ice maker is frozen.
Try running a hair dryer to remove any ice that may be blocking the water from coming into the ice maker tray.
Jul 28, 2011 | Samsung RS265TD
Samsung Ice Maker on Mdl RB215LASH
It is quite possible the water line near the ice-maker is frozen. I would try a warm hair drier to thaw it out.
Apr 21, 2008 | Samsung RB215LASH
Ice Maker not dumping
Sailor, Samsung put out a service flash on your model regarding the ice maker fill tube. What is happening is that ice is forming on both ends of the fill tube. When the ice tray twists in the harvest it is hitting on the fill tube and pulling it from it's mount. Could this be why the drive motor seems to weak. The flash number is ASC20060525001. They redesigned the fill tube, part number DA63-02928A. Just trying to help you find an answer...Catriver..post back.
Nov 15, 2006 | Samsung RS2534 Side by Side Refrigerator
RS2556SH Side by Side - Icemaker not filling; fill tube not iced over!?
press the reset button (black) on the bottom of the icemaker, the system will go through a cycle, and water will pour into the tray.
Oct 23, 2006 | Samsung RS2630SH Side by Side Refrigerator
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
