Question about Bosch Washing Machines
Bosch maxx 900 washer won't spin - Bosch Washing Machines
  • 142 Answers
SOURCE: maxx 1000 wo;nt spin
check brushes in motor 6 years quite good.
Posted on Sep 14, 2009
  • 662 Answers
SOURCE: my bosch classix 1200 fl wont spin or drain
Normal 0 false false false MicrosoftInternetExplorer4 /* Style Definitions */ table.MsoNormalTable {mso-style-name:"Table Normal"; mso-tstyle-rowband-size:0; mso-tstyle-colband-size:0; mso-style-noshow:yes; mso-style-parent:""; mso-padding-alt:0in 5.4pt 0in 5.4pt; mso-para-margin:0in; mso-para-margin-bottom:.0001pt; mso-pagination:widow-orphan; font-size:10.0pt; font-family:"Times New Roman"; mso-ansi-language:#0400; mso-fareast-language:#0400; mso-bidi-language:#0400;} Plug off the wall first. Remove the front lower panel, screws underneath. Be prepared for water, drain out from drain hose. Check filter for clogging, clean out. Sometimes when the load is unbalanced & the machine cannot adjust the load it stops. To avoid this make sure your wash is mixed with big and small clothes.
If this does not work remove the rear panel & check belt, should have half inch ‘give’. Still not good, remove belt, unscrew 2 bolts that hold the motor, unplug the motor connector, lever the motor back with a screwdriver. Check the motor brushes (at terminal end of motor), if they are any shorter than 1 cm replace brushes.
Try these sites for spares:
RepairClinic.com
espares.co.uk
AppliancePartsPros.com
mcminone.com
Posted on Jun 16, 2010
  • 662 Answers
SOURCE: Bosch Maxx 2260 washer won't drain or spin.
RepairClinic.com
espares.co.uk
mcminone.com
Pl click 'very helpful' for the free help, thnks.
Macmarkus
  • 2605 Answers
SOURCE: My Bosch maxx 900 front loader won't drain water
Hello David,
Welcome to FixYa.
Based on your description you likely have a clogged drain pump/filter.
Here`s how to check since that would be the first logical place to start.
1) **Turn off the power or unplug the cord from the dryer or wall...ehichever applies to your set-up...safety first**
2) Water removal...remove toe panel. There you will find a small hose with a plug in the end for draining the pump.
3) Now bleed pump drain...A shallow pan is handy for this step.
3) remove pump filter, but be careful if you don't have a shop-vac or a shallow pan and towels you may get wet...
*Once you`ve reached this point you may have trouble removing the filter if it is really plugged up with debris. You might have to wiggle it back and forth as you twist and pull.
4) When you get the filter out, visually inspect inside the pump thoroughly with a flashlight and clean it out really well. It won`t take much to prevent these from draining. i.e. a penny, hair pin, buttons etc.
Let me know if you found anything in the pump and how you make out after that.
If you removed any obstruction, simply reassemble the unit making sure the filter is screwed in tight, run a quick rinse cycle to test for leaks before putting the toe panel back on and you should be good to go...save for any leaks.
There are other possible factors that can prevent the unit from draining or spinning out items properly, but we`ll cross that bridge when and if we get there.
Thank you for choosing FixYa, keep me posted on your situation.
macmarkus :)
Posted on Sep 02, 2010
  • 867 Answers
SOURCE: Hi, my Bosch maxx 900 front loader washer was in
If you rotate the pulley on the back of the drum does it rotate the drum? i have seen these snap the back of the drum off. also they can have issues with the controller board for the motors which would require a technician to determine.
Posted on Oct 25, 2010
WHY IS my bosch maxx 6 CANT SPIN THE CLOTHES OR DRAIN THE WATER ?
Hey there, welcome to Fixya! The above answers were pretty helpful, did you fix your problem with them? Did you check the manual for further instructions? You can find a PDF copy here: Bosch Classixx 5 Manual
Jul 11, 2014 | Bosch Maxx 6 WAB28260GB White 600 mm...
Hi, my Bosch maxx 900 front loader washer was in the process of doing a load when a really loud bang happened..now it won't spin..makes all the right noises, but barrel won't move. Took off back panel and...
Oct 24, 2010 | Bosch Washing Machines
I have a bosch maxx 1000 (wfl2000au/30) machine will not spin. pupm impeller was jammed by a bobby pin. i removed the bobby pin. when machine is on spin cycle only the pump opperates. does not spin at all....
If there is no water in washer, and it will not spin, I suggest you remove the motor, and check the brushes.
If they are less than 3 or 4mm long, they need replacing.
Hope this helps.
Dec 05, 2009 | Bosch Classixx WFL 2066 Front Load Washer
My bosch classix 1200 fl wont spin or drain
RepairClinic.com
espares.co.uk
mcminone.com
Oct 15, 2009 | Bosch Classixx WFL 2066 Front Load Washer
Maxx 1000 wo;nt spin
Sep 14, 2009 | Bosch Washing Machines
Washing Machines Logo
16 people viewed this question
Top Bosch Washing Machines Experts
Tim Whalen
Dan Webster
Dan Webster
Are you a Bosch Washing Machine Expert? Answer questions, earn points and help others
