Question about Philips Magnavox 9P6034C 60" Rear Projection Television
IC's What are ic's and where are they located in the rear projection 60 inch
Re: IC's
In general it is Integrated Circuitry, if you are talking about the convergence IC's then they will have about 20 pins sticking into the board and be about 2 inches long with aluminum heat syncs on them. If need be call the tv repair guy to diagnose the problem and then replace the parts yourself but if you pay for an hour don't let him leave 10 minutes after he gets there. I repaired a 65" RPTV with a bad high voltage transistor causing a dead short in the flyback. The guy came out and said "yep you have a dead short" and tried to leave, but I sat and talked to him for the remainder of the hour and was able to fix it myself for $100, not the $450 they wanted to pick it up and fix...
Posted on Dec 03, 2007
0 characters
3 Points
The colors in my tv are overlapping and picture is wavy that cannot be solved with adjusting the manual converge function and got worse when I tried restore manufacture settings
Bad STK392-120 convergence IC. You need to replace 2 both and also check feedback/return resistors. Convergence IC is located on large signal board with a big heatsink. :)
Mar 31, 2010 | Philips 60PP9363 60" Rear Projection...
60 inch has no red
Hi, you`ll need a tv tech for that one, either no red out from rgb chip, bad driver ic, etc. none of these repairs can be done without special tools, video-tek
Jun 29, 2009 | Philips 60P8342 60" Rear Projection...
Phillips 60pp9202/17f projection convergence
what about blue? this is an indication that maybe one of the convergence ic have failed. generally you replace both. falure of the ic can also be sympton of other problems.. The oputput ic resistors. the covergence power fuses. but the first step is to replace the ics
Nov 03, 2008 | Philips 60PP9202 60" Rear Projection...
Convergence IC
Andrews Electronics have an ETA of 9-6-8 on the part or you can contact I would either replace both IC`s or get a tech to do it, you can get them by calling this number 800-575-9833, they only sell the good ones,
Aug 19, 2008 | Philips 60PP9202 60" Rear Projection...
Your Ics are bad and you prob have a resistor or two that have gone out too. If you are good with a soldering iron and have an hour to give up you can fix it. They are at location 7044 and 7045 on your board. They are STK 392-120's and the part number is 932212344682 good luck with you repair.
Feb 06, 2008 | Philips 60PP9352 60" Rear Projection...
Convergance adjustment
convergance amp ic bad
Dec 15, 2007 | Philips Magnavox 9P6034C 60" Rear...
Location of IC's
if you do not know what IC is i do not think you should be in a high voltage TV. IC is integrated circuit "CHIPS" and are all through the TV. What IC's are you looking for?
Nov 21, 2007 | Philips Magnavox 9P6034C 60" Rear...
Philips Magnavox 9P6034C 60" Rear Projection Television Logo
42 people viewed this question
Top Philips Projection Televisions Experts
matt martin
matt martin
Jaime Hernandez
Are you a Philips Projection Television Expert? Answer questions, earn points and help others
