Question about Shredder Office Equipment & Supplies
Shredder won't start - Shredder Office Equipment & Supplies
  • Shredder Master
  • 1,830 Answers
Do you have any paper stuck in it?
Sometimes it will not work because of a little piece of paper stuck between the metal.
Posted on May 12, 2017
Shredder Green light won't come on and won't shredd. won't go in reverse either.
I had the same problem with the same shredder. The unit uses mains voltage which is rectified to DC and eventually feeds two 12V zener diodes wired in series for a 24Vdc supply. These are 1N4742A (Radio Shack 276-0563), 1W parts. They overheat and will short, which you can verify with a VOM. I reassembled the unit, but recall they are away from the relays at the tail end of the large white colored power resistors, side by side in the same direction. I think Z1 and Z5. After replacing these parts, green LED and reverse, etc. will work.
Apr 14, 2013 | Omnitech 18-Sheet Cross-Cut Shredder
Constantly runs when on auto and won't accept paper
Shut off power and turn the shredder upside down. It is highly likely you will find shredded paper jammed in the mechanism, especially near the center where the feed sensor is located. A thorough cleaning should get your shredder operating again
Feb 02, 2013 | Staples SPL638X (CrossCut) Shredder
Won't shut off
You have an optic sensor that is blocked or shorted. If you take it apart you should be able to identify the problem. It is up by where the paper feeds in.
Jan 08, 2013 | Royal 1610X Shredder
My briggs & Stratton won't start. Changed spark plug.
check for spark is there a low oil shut off and the oil level is a little low ?
Jul 01, 2012 | Troy-Bilt Chipper Shredder
Shredder won't stop running
THERE MAY BE SOME PAPER SHREDS BLOCKING THE LASER LIGHT.
UNPLUG SHEDDER AND CLEAN CUTTER HEADS.
Sep 30, 2011 | Office Depot Ativa DQ60M Shredder
As501 shredder. reverse works. Auto won't go.
I was having the same problem with my shredder. I called customer service; I was informed it was the gears on the inside of my shredder. My shredder is no longer under warranty. However, she is mailing me out the part I need for a small fee. Their customer service number is 1-800-327-8508 in the USA and international only 1-310-793-5650. I do hope this help you!
Jun 05, 2011 | Aurora Global AS501X-MS Shredder
My VF 1012mx paper shredder won't feed the paper in order to shred it. Green light is on but nothing happens when I put the paper in.
Does it run in reverse.????
You may just have dirty "eyes" where the paper is inserted, OR they may be defective.
Jun 04, 2011 | Royal VF1012mx Shredder
My royal sc120 shredder will light up but there is no sound will not run. I have cleaned out clogged bits of paper. What could be wrong?
Shredders have a reputation for being very unreliable...they often just quit like that...
You can try also to blow it out with a can of compressed air, but it probably won't help... not much else that you can do...
heatman101
May 27, 2011 | Royal Sc120 Shredder
Have a new electric shredder does not have
Brand new shredder with no owners manuall I plugged it in.it won't start is there a first time procedure t o use it
Jul 10, 2010 | McCulloch Electric Chipper Shredder
32 people viewed this question
Top Shredder Office Equipment & Supplies Experts
Ross Keen
Dave Reilly
Level 1 Expert
gbob59
Are you a Shredder Office Equipment and Supply Expert? Answer questions, earn points and help others
