Question about Stihl Garden
My stihl ms-180-c chain saw will not keep chain tight. you tighten chain rev. engine chain will just about come okk -tighten chain rev. engine same thing.
    Top Expert:
  • Stihl Master
  • 48,384 Answers
You have to use the tension screw to move the cutter bar to tighten the chain then you do up the bar mounting nut to keep it tight
Posted on May 12, 2017
How to change chain tensioner on stihl ms 290 farmboss chainsaw
sthil ms 290 chain saw 9-10-12 - YouTube
? 11:18
Sep 10, 2012 - Uploaded by skidoo849
sthil chain saw 9-10-12. ... my 2012 STIHL MS 290 FARM BOSS CHAIN SAW WITH A 16'IN BAR. - Duration: 34:11. MRJOHNDEERE3720.
How To Adjust Your STIHL Saw Chain - YouTube
? 7:21
Dec 4, 2012 - Uploaded by STIHL USA
Learn the differences in adjusting a cold chain vs.a recently used chai. ... Also learn about the STIHL Quick Chain Adjustment feature found on certain STIHL chain saw models. ... Stihl MS290 Farmboss Discussion - Duration: 5:37. ... How to Replace the Bar & Chain Oil Pump Worm Gear on a Stihl MS 029 ...
[PDF]STIHL MS 290, 310, 390
StihlInstruction Manual - improper use can cause serious or fatal injury. MS 290. Warning! .... engineering changes and improvements ... When using a chain saw for.
Chain Tensioner Adjuster for Stihl Chainsaw MS290 MS39
Jan 30, 2016 | Stihl 029 039 Ms 290 310 390 Chain...
I have a Stihl MS 290, runs great, but the chain keeps tightening it's self on it's own
That's an unusual problem, usually the opposite happens. After making sure the chain brake is off, loosen the two nuts that hold the bar. Be sure to hold the bar up when adjusting the tensioner screw and adjust until the chain is just snug, but not too tight. While still holding the bar up, tighten the two nuts firmly. Check to see that the chain can move freely by hand. Then start the saw and run the chain at speed with something in front of the nose to check for adequate lubrication. You should note a slight fine spray of oil on the object in front of the nose of the bar. Inadequate lubrication, a chain that is binding on the bar, or an overly tight chain can cause the bar to heat up and expand, further tightening the chain. A properly adjusted Stihl saw will use almost all of the chain oil in the reservoir for every tank of gas. Too much oil is better than too little. The oil feed may have to be adjusted for operating in temperature extremes. If operating in very hot conditions, be sure that the saw has not run out of chain oil. The oil feeds faster when hot.
Sep 19, 2014 | Stihl MS 290 Chain Saw include 20" 50cm...
Chain keeps comming off my stihl 044
Download manual at:
Go to page 26. Remember to pull front of chain bar up before you tighten nuts. Make sure you really tighten nuts so they do not allow bar to move when finished.
Nov 20, 2013 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
Chaisaw wont keep consistant tension. 1st it goes really tight then after retension it goes really slack. any ideas?
Most chain tention issues are due to inadiqate oil to the bar and chain, or the wrong type of oil, there may also be issues if this is a tooless system to lock the bar.
Dec 22, 2012 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
16" chain, 16" bar it
You're not tightening the nut tight enough.
Apr 17, 2011 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
I have a Stihl 16" 012 AVT chainsaw. I cannot get
First thing I would try is wash out the oil tank with a little bit of diesel fuel then run some thinner oil thru it to see if it gets better . I usually leave bar and chain off when I do this.. or if it is oiling but not going down the bar check the bar oil holes.
May 10, 2017 | Stihl 16" Chainsaw Bar Chain Saw 018 025...
New Stihl ms 180 idles but will not accelerate
sounds like you may have a broken throttle cable. take the top cover off and inspect to see if this is the problem. let me know if this is it or if you need more assistance with this.
Mar 01, 2009 | Poulan Wild Thing 2375 18" Gas Chain Saw...
Stihl chainsaw
I have a stihl ms 180 that leaks bar oil all the time
Aug 31, 2008 | Makita DCS6401 20 20",64cc Chainsaw 2...
Garden Logo
46 people viewed this question
Top Stihl Garden Experts
Joseph Mueller
Joseph Mueller
Level 1 Expert
ray gallant
Are you a Stihl Garden Expert? Answer questions, earn points and help others
