What voltage is reqired to open it - Computers & Internet
  • Brett Duxbury
    Brett Duxbury May 12, 2017
    Hi angelo , we want to help you with your question, but we need more information from you. Can you please add details in the comment box?
    what does open it mean ??????
    What is it ??? make and model number ???
    details ??????????
    Open it do you mean with a jack hammer or power saw ?
  • Computers & ... Master
  • 1,830 Answers
To open exactly what?
Posted on May 12, 2017
How long should it take for my dewalt batteries to charge
In order to to give an accurate answer, the model and voltage of your drill would be reqired
Apr 10, 2017 | Dewalt Drills
Heater check out list for heater failures
Almost all furnaces built after 1978 have intermittant type pilots.
Ca banned them requiring electronic spark or hot surface ignitors, followed by induced draft motors, pressure switches or centrifigal switches that "prove" a induced draft exists, allowing the pilot sequence to commence.
electronic spark type units have a high voltage low amperage spark that is AC. Fire rectifies electricity that passes through it meaning AC becomes DC ! Fire is a terrible conducter however as a result , the DC signal is only milliamps/volts signal strength. the DC prescence is proof a flame exists for pilot, and safe to commence to mainburners.
As long as pressure switches stay closed, safeties and limits stay closed
and the DC signal to the ignition module is not broken, the furnace will run.
The normal sequence of operation is upon a call for heat from the thermostat a 24 volt signal is sent to W white (heat circuit) at the low voltage terminal board on furnace.
from there depending on unit and age the heat circuit may include a circuit board, but it still has the typical limits and safetys reqired for operation
its just not using electromechanical relays to control fan and induced draft motor etc.
for the induced draft to begin ,all limits, safetys in heat circuit must be closed.
induced draft begins and a proving switch, either pressure or centrifigal close allowung the pilot to begin, a spark or hot surface ignitor is energized and a pilot flame established,modern types use flame rectification to prove a flame, older Carrier, Payne,types have a 3 wire switch in the piloyt assembly that is a bi metal that expands and contracts clicking open and shut, allowing pilot or main burners, depending if cold or hot.
pressure switches are attached with tubing to the induced draft wheel housing and sense pressure differential and close upon induced draft running, the orifices that the tube attaches to on induced draft housing often plugs or is restricted causing pressure switch to fail to close, or waver on open and close , open , close, .
if you can run the fan in the on postion , you have both high and low voltage to the furnace.
if you dont have fan control check power, breaker , fuses.
on Dec 04, 2009 | Heating & Cooling
Power cord with correct voltage
Most power cords for TV, will meet this reqirement.
Jan 22, 2014 | Samsung SP-R4232 42 in. Plasma HDTV
Installed system mechanic professional when i try to open ti i get this error lolsystemservice reqired to run
Check the iolo service in the services.msc
to go windows logo key and r key at the same the run type services.msc.
now look for the iolo service..if it is stopped..start the serive.
you call also call the iolo support team..they will help you free of cost.
Aug 20, 2011 | Computers & Internet
Whener i connect it i get a blinking box with message "non optimum mode- reqired 1280X1024" the service centre guys says the board is damaged (of the monitor) and requires replacement what to do??
That is the recommended native resolution for this monitor, do you have your PC video resolution setting to this number? If you do and it stills get this pop up then you may have problem in the logic board, I would also check the DC voltage to make sure it has clean DC feeding the logic board, it may be due to bad caps.
Failed TV and Monitors:
Please post back what you find.
Aug 30, 2010 | Samsung SyncMaster 710N 17 in. Flat Panel...
Installed cook'n with betty Crocker on new Gateway lap top with vista bur now it won't open.Tried to reinstall,but that won't work either. computer say's can't install because being used bu another program
go to control panel and remove program and uninstall it then reinstall it if dont work then your computer memory not enough,check on back boxs what are the reqirments are to install succesfully ,if my info was of any help to you please leave me a comment ,thankyou.
Sep 02, 2009 | DVO Enterprises Cook'n with Betty Crocker...
Computer cannot locate scanner microtek 9800xl
change your adapter is has not proepr voltage which are reqired for scanner.
Mar 27, 2009 | Microtek ScanMaker 3630 Flatbed Scanner
Computers & Internet Logo
47 people viewed this question
David Payne
David Payne
