Showing that it is out of paper but it has a brand new roll
Trying to put in a new paper roll
Turn off the Sharp EL-1801V.
  • 2 Cut the end of the replacement paper roll for a fresh edge and to ensure a smooth feed. Do not tear the paper roll, as feeding a torn paper roll can cause a paper jam.
  • 3 Insert the cut edge into the paper opening on the back of the Sharp EL-1801V. Hold the paper roll so that the edge being fed into the machine is coming from the bottom of the roll. Turn the power on.
  • 4 Press the "Feed" button until the paper is fed through the unit. Lift the metal paper roll holder up. Slide the paper roll onto the paper-roll holder.
  • Read more: Directions for Replacing the Paper Roll on a Sharp EL-1801V ' eHow.com http://www.ehow.com/how_7294657_directions-paper-roll-sharp-el_1801v.html#ixzz1eNqkJA8g
    Nov 21, 2011 | Sharp EL1801V Scientific Calculator
    How can I change the paper. I cannot find the correct slot to install the new paper roll
    Press down on the button located on the side of the terminal to unlatch the
    paper roll cover, then lift the cover up and back
    Remove any partial roll of paper in the printer tray by lifting up
    Loosen the glued leading edge of the paper or remove the protective strip
    from the new roll of paper. Unwind the paper roll past any glue residue.
    Hold the roll so the paper feeds from the bottom of the roll
    Drop the paper roll into the printer tray.
    Close the paper roll cover by gently pressing directly on the cover until it clicks
    shut, allowing a small amount of paper past the glue residue to extend outside
    the printer door.
    To prevent the paper roll cover from damaging the print roller, always gently press
    down on the printer dust cover to close it.
    g+ypssoexzf1qaaaabjru5erkjggg==
    Mar 18, 2011 | VeriFone Omni 3700
    I need to order printing tape or paper for the P1-DH V. What is the item number for that? Thanks.
    There is no specific item number for the printing paper for this model. You can buy any brand of paper rolls, but it must be 2 and 1/4" or 57mm wide. Just go to OfficeMax or Staples and just look for the paper rolls that are 2 and 1/4" wide. If you need a lot of them I would go to Costco, great deal on paper rolls
    If you need a new to replace the ink roller the item number is CP-16
    This should help you out
    Jan 24, 2011 | Canon P1-DHV Calculator
    Ink ribbon or paper roll error. the in ribbon is broken, or the paper roll is jammed. Clear the problem. I put new roll and ink cartridge in and still showing error
    Happend twice to me. What sometimes happens is that the paper roll was not changed at the time the ink was. Therefore the paper roll was allowed to remain in the printer until the very last sheet. On the last sheet there is a sticker that says paper out. (stupid idea) This sticker makes the last sheet of paper too thick to fit through the last paper guide / feed. Because of this, the ink film breaks and that specific error message is displayed until that last piece of 4x6 is pulled from the paper feed. Clear that out, and all is good.. Change the paper every time u change the ink.
    Jan 16, 2011 | Sony SnapLab UP-CR10L Digital Photo...
    Ink levels show emptry.
    Need one plastic plate that you don't care much about, or a plastic disposable plate.
    Tear off one section from a paper towel roll and roll it up into about a 1-inch diameter roll.
    Flatten the roll
    Soak the flattened roll in warm water
    Lay the flattened roll down on the plate
    Place the nozzle area of the ink cartridge directly against the wet paper towel
    Fold the flattened roll as needed to support the ink cartridge so it stands upright.
    The trick here is to make sure the cartridge is supported upright so the nozzles come in full contact with the wet towel surface.
    The wet towel acts as a wick to soften and draw out the ink.
    After awhile, you shoudl see a kaleidoscope of colors on the paper towel. This indicates the nozzles have been opened up and the ink is flowing. Try to print and see what happens.
    Repeat as needed.
    May 21, 2010 | Dell 926 All-In-One InkJet Printer
    Reload Paper constantly shows up
    This printer is very finicky about paper loading. I see this error most commonly when using auto-cut roll paper. If the paper edge is not cut perfectly straight, and it is not inserted into the printer perfectly strait, it will give you an error. When it does this, you can simply load the paper and press "cut" instead of "pause" when it says "press pause" and it will cut the paper straight. You can also set it to "Roll Paper Manual Cut" and load the paper, then set it back to "Roll Paper Auto Cut."
    Jun 30, 2009 | Epson Stylus Pro 10000 InkJet Printer
    Sharp Electric Cash Register XE-A203. I just put a new paper roll into the register because it was out of paper. The register screen is showing all numbers and transactions but when the paper comes...
    Hi whitwall,
    Please make sure that you have the right paper roll.
    Your machine takes a thermal paper roll, which means it actually burns the print into the surface of the paper as opposed to printing with a ribbon or ink roller like other makes.
    The thermal paper will only show a print on one side of the paper, in other words if you do indeed have the right roll and it is in upside down you will get a blank printout.
    An easy way to see if it is the right paper hold the roll in your one hand and scratch a line with the thumb nail of your other hand accross the surface of the roll,if you get a black line on the paper then it is the right one, otherwise you have what we call a "bond" paper roll and it will not work in your machine.
    If you got the "black line" with your thumb nail, then lift the printer head arm (green lever) place the roll in position with the paper rolling out from the bottom of the roll towards the front of the machine, pull the paper out past the catch mechanism and close the printer ****.Tear off the excess paper and replace the printer cover.
    You should be ready to go ahead with sales.
    This should solve the problem .
    Regards
    Gavin.
    Oct 16, 2008 | Sharp Office Equipment & Supplies
    Paper rolls up
    You have a humidity issue with your paper. Buy or open a fresh **** (sealed) and try printing again. If your paper is stored in a cool place move it to a warmer area. Paper tends to pick up moister over time, especially when cold and will curl when printing. The paper is actually steaming when it hits the fusing (heating) section in the back of the printer. The curl is because one side of the page is drying faster than the other.
    If you have a case of paper and open a fresh **** with similar results, buy a new **** and try again. When selecting your paper buy good reliable paper. I recommend "HP Office" branded or better. I say stay with HP Brand paper as it's manufactured to a tight quality standard than most and is a "known good" paper. STAY AWAY FROM STORE BRANDS as they go out on low-cost bids and the quality varies widely on whoever got the contract this time.
    As a more positive note, If you use a good paper in your printer, your drum cartridge (expensive) and toner cartridge (not cheap) will actually last much longer. You'll save more (much more) in the long run.
    Hope that helps you.
    "A little free help from a tech fixing 10 to 15 printers a day for 13.5 years."
    Aug 18, 2008 | Brother HL 5250DN Laser Printer
    Epson u220b printer
    service for that unit - call the manufacturers tech line and they'll give u service center nfo - it it's still under 2 years - repair will be free of charge
    Apr 08, 2008 | Epson TM-U220 Matrix Printer
    12 people viewed this question
    k24674
    jasbo
    jasbo
