Question about Saws
I have an old 34-580 table saw. I lost the guard/splitter mounting bracket and so can't attach it to the saw mounting bolts. Any idea where I can find one. Thanks
4 Suggested Answers
  • 59 Answers
SOURCE: old craftsman table saw parts?
most sears stores have a dept. that refurbishes and sells these tools. if it can be had, they can help.
Posted on Apr 25, 2009
  • 127 Answers
SOURCE: Where can I find a splitter and guard for an older
If you give me the model number I can do some digging for you.
Thanks
Posted on Dec 29, 2010
  • 520 Answers
SOURCE: Have an older Sears Craftsman 10" Table Saw, model
you should be able to order one from sears. another place to look is ebay. the round plastic thing is to mark with pencil the cut of the blade. put in your sliding miter Gage set at 90 deg. put a piece of wood on it, push forward and cut the wood then slide back and mark the wood position on the plastic. that's the point where your blade cuts
Posted on Jan 03, 2011
Testimonial: "Thank you very much, I'll try Sears first and see if they can help. Since it's an older saw, they haven't been much help up to now."
RK7136 locked in safe position . How do I unlock
I am guessing you got an answer by now, but I saw on Amazon someone asked this recently. I remember this problem when I got mine. I assume you mean the arm that lowers and raises the saw, not the locking mechanism for the table. As you face the saw, look at the guard. There is a slightly curved arm that goes from the guard toward the back of the saw. On the piece the guard arm attaches to at the back of the saw on the left side, there is a "pin" that sticks out on the left side. It looks like a bolt that is longer than the others near it. Gently push down on the top of the front of the saw to take pressure off the arm pin, and then just pull the pin to your left, like you were trying to remove it. It doesn't come out all the way, but releases the lock. If you have kids around, best to lock it when not using it...safety first. Oh...and their manual sucks!
Dec 13, 2013 | Rockwell Rk7136 1 Shop Series Miter Saw...
I cannot attach the anti kickback device to my dewalt 10 inch table saw.
If you lost the instruction manual go to dewaltservicenet.com and you can download them, but in the meantime there is a lever that removes the guard lift up on it and then towards the back is a slot for the pawls, depress the button on them and insert into the slot making sure they lock replace the guard and make sure everything moving freely up and down movement of the saw and free movement of the other safety devices. Let me know if you need more assistance.
Aug 23, 2011 | Dewalt DW744S 10" Portable Table Saw with...
1999 mitsubishi eclipse..4 cyclinder (non-turbo) engine pulleys faced toward right passe.nger..i have front right jacked and braced with tire and inner plastic guards off..have main belts off..seems only...
I agree....I have done the same thing...Some vehicles have portholes with rubber plugs for that type bolt removal...but very few....It should be done to all ft wheel drives...
However first be sure that you have all mounts loose...there my be another lower mount...I have seen up to 4 different type mount brackets on some engines...Also it seems that you have to jack all of them up way too much and very unsafe looking but that is just the way it is..Some times it is a good idea to loosen the trans mounts to give you another couple inches but cutting the hole is a great idea because you will need it for future use.....Start out with a drill pilot hole and use a hole saw bit for your holes...very simple...Hope this helps..........cert.tech..level2....Metalpoet............
May 30, 2011 | 1999 Mitsubishi Eclipse
Where can I find a splitter and guard for an older Sears 10" Table Saw?
Thanks
Dec 29, 2010 | Craftsman Saws
Can't find my owners manual. How do I change the blade. Bolt hits on a guard that covers the arbor. On a DW713 combination saw.
Removing the Blade
1. Unplug the saw.
2. Raise the arm to the upper position and raise the lower guard as far as possible.
3. Loosen, but do not remove guard bracket screw until the bracket can be raised far
enough to access the blade screw. Lower guard will remain raised due to the position
of the guard bracket screw.
4. Depress the spindle lock button (Fig. 3) while carefully rotating the saw blade by hand
until the lock engages
5. Keeping the button depressed, use the other hand and
the wrench provided to loosen the blade screw. (Turn
clockwise, left-hand threads.)
6. Remove the blade screw, outer blade clamp, and
blade. The inner blade clamp may be left on the
spindle.
Installing a Blade
1. Unplug the saw.
2. With the arm raised, the lower guard held open and the
guard bracket, place the blade on the spindle against
the inner blade clamp with the teeth at the bottom of
the blade pointing toward the back of the saw.
3. Assemble the outer blade clamp onto the spindle.
4. Install the blade screw and, engaging the spindle lock,
tighten the screw firmly with wrench provided. (Turn
counterclockwise, left-hand threads.)
5. Return the guard bracket to its original position and
firmly tighten the guard bracket screw to hold bracket
in place.
WARNING:
• The guard bracket must be returned
to its original position and the
screw tightened before activating
the saw.
• Failure to do so may allow the guard
to contact the spinning saw blade
resulting in damage to the saw and
severe personal injury
you can download a manual at: http://www.dewalt.com/tools/machinery-miter-saws-dw713.aspx
Jul 20, 2010 | Garden
Removal of front right axle from a jaguar 2002 x-type
Loosen the wheel hub nut.
Remove the front road wheel and tire.
Remove the tie rod end retaining nut.
Using the special tool 204-192 Ball joint Splitter
detach the tie rod end.
Remove the subframe reinforcement plate retaining bolts.
Loosen the subframe rear mount bolt.
Loosen the subframe front mount bolt.
Remove and discard the wheel hub nut.
using spcial tools 204-269Forcing Screw,205-491-01 adapter nuts,205-491 wheel hub puller
Detach the wheel knuckle.
Remove the lower arm ball joint retaining bolt.
Reposition the lower arm.
using special tools 307-443 RH Halfshaft splitter ,307-442 RH Halfshaft splitter handle
detach the halfshaft.
Remove the exhaust muffler inlet pipe.
Remove the halfshaft seal.
Remove the transfer case Y bracket retaining bolt.
To prevent damage to the transfer box internal seal,
make sure that the link shaft is not retracted further than
200 mm from the transfer box casing.
remove the halfshaft.
Attach special tools to the halfshaft.
Lever the special tools to displace the halfshaft.
Install the transfer case Y bracket retaining bolt.
Remove the halfshaft.
Use suitable protective covers to protect the barshaft.
Remove the halfshaft snap ring.
Install a new snap ring to the halfshaft.
Install a new halfshaft seal.
Remove the special tool.
Make sure the CV joint splines are located fully.
Do not use excessive force when engaging the CV joint into the link shaft.
Install the halfshaft.
Tighten to 25 Nm.
Attach the wheel knuckle.
Install the lower arm ball joint retaining bolt.
Tighten to 83 Nm.
Install the exhaust muffler inlet pipe.
Tighten the subframe front mount retaining bolt.
Tighten to 142 Nm.
Loosely install the subframe rear mount retaining bolt.
Install the subframe reinforcement plate retaining bolts.
Tighten to 35 Nm. Tighten to 142 Nm.
Install the tie rod end.
Tighten to 35 Nm.
Loosely install a new wheel hub nut.
Install the front road wheel and tire.
Tighten the wheel hub nut.
Tighten to 330 Nm.
Check the subframe alignment.
May 20, 2010 | 2002 Jaguar X-Type
Pulley on motor tilted to left and belt keeps coming off
jim, Yes. The motor should be mounted to a bracket with 4 bolts. Loosen these, align the pulleys, then tighten the bolts. You can see the four elongated holes in the base of the motor at the following page. Scroll down until you see the 9 product diagrams. The one labeled "Motor" shows the four holes in the base of the motor.
http://www.searspartsdirect.com/partsdirect/getModel!retrieve.pd?modelNumber=315.228390&pathTaken=partSearch
Mar 22, 2010 | Craftsman 10" Table Saw
Adjusting Blade/Miter Groove Alignment on 1950's Craftsman Table
Try using a 1/16 thick flat washer as a shim where the mounting bolts/trunions mate with table. 1/16 shim on front mounting bolt will shift front of blade over 1/16 or 1 on the back mounting bolt will shift back of blade over
Oct 28, 2009 | Craftsman 10" Table Saw
Attaching Blade Gaurd
As long as you line it up properly, it should work. Just make sure the CENTER if the blade is lined ip with the center of the blade guard mount. Use folded paper to match the kerf on one side of the blade and use the fence as a guide. Tighten the screws underneath the back of the table, that hold the guard in place.
Sep 27, 2009 | Skil 10" Table Saw 3400
I need some fitting instructions for a rear window guard on a landrover freelander
as simple as i can put it here goes , you will need to remove rear door panel using a flat blade tool, start at top and work your way round to hinge side,peel back the weather sheild about six inches down all along the top edge , this will reveal the mounting points on the back of the rear panel, leave the removable ends attached to the window guard and line up against rear panel, check which hole's need to be used and attach brackets to these points using bolts supplied in kit or what ever you have to hand. once mounted you can pull guard from brackets and put to one side , next is the rear panel if you place panel face down revealing back it will show two ovalish shape's highlighted by faint outline , this is where you will need to cut and file . when that is finished you can reinstall rear panel on to door, install rear guard and locking bolts. it always handy to have spare clips for door panels as the become brittle with age.
Aug 28, 2009 | 2004 Land Rover FreeLander
Saws Logo
50 people viewed this question
Top Saws Experts
Tom Chichester
ray gallant
Are you a Saw Expert? Answer questions, earn points and help others
