Question about Sewing Machines
My girlfriend's name
Rejouis Emilie
It was a gift but, came without a manual. I have try different web site without any luck
Please provide the manufacturer's name and full model name / number of the sewing machine for help.
Jul 24, 2015 | Sewing Machines
Hello, I have a Shark euro-pro sewing machine. I am sewing denim on denim using singer needles that were suggested for denim. The numbers on the package are 2020 110/18 808 R 130/705H 05 un I...
The size of needle is fine for sewing on denim so unless the needle is bent (and even so) I doubt that is the problem. Breaking upper thread typically has more to do with the threading, ie wrapped around some place along the way or misthreaded somehow, of even if you somehow got knots or that it has somehow got thread around the spindle for the spool. So first recheck the threading. Best to do by simply totally unthreading it, looking closely at the spool and winding and then rethreading it again. Make sure your upper tension hasn't been accidentally tightened too.
Next check the bobbin and bobbin thread. First pull on the thread. Is it pulling real tightly or does it flow out readily? Take the bobbin out and look at it. Check the tension also. Is it too tight? That too can cause the upper thread to break.
Is the needle penitrating the material smoothly? Again examine the needle closely to see if it's developed a burr. Better yet just swap the needle with a new needle and try it.
The majority of the time it is one of these things that will cause the top thread to break.
May 18, 2011 | Euro-Pro Shark 80 - 7133
Machine sounds like a freight train. I cleaned the bobbin area. It is also not sewing a pretty stitch very uneven.
Take off the throat plate under the presser foot with a screw driver and really clean out your machine. You will probably be amazed at the lint and thread there. It almost resembles felt. I was shocked when my girlfriend showed me. Then lubricate as per your manual. PS I put my machine on a bath towel so that it is quieter.
Jan 01, 2011 | White Sewing Sewing Machines
My daughter's girlfriend bought this singer 2250 and I can't get the bobber threaded correctly
Go online and download a free manual at www.singerco.com and you can enlarge the diagrams to see it. You can also print it if you want. Good luck
Oct 08, 2010 | Singer 2250 Tradition
I have a Singer Futura CE-100 and everytime I try to wind thread on the bobbin, the machine stops and beeps. I have tried redoing every step and there is no change. Any help or suggestion to resolve this...
Go to singerco.com and see if their under their frequently asked questions may have your answer. You can also order a manual for your machine, for $15. They have a great customer service staff, try calling them at 1-800-4singer. Good luck, hope you get sewing again with your machine. One time my girlfriend found out the beep meant all was good, so hopefully you are going to have a good laugh over the problem, she did.
Sep 16, 2010 | Singer CE-100 Futura Computerized Sewing...
What is my name?
What is your boyfriends name His name is What.
Feb 11, 2010 | Husqvarna Viking 1
Husqvarna 2000 sl no zig zag movement
You might try oiling where the needlebar slides side to side (and everywhere else). More than likely it needs to be freed up somewhere.  Also there is a small piece called the cam follower that can pop off. Look inside near the cams and the piece with a finger that follows the cams may need to be reattached. They do come loose sometimes. Good luck.
Oct 17, 2007 | Sewing Machines
Sewing Machines Logo
12 people viewed this question
Top Sewing Machines Experts
Tally Girl
Tally Girl
Chris Wetmore
Are you a Sewing Machine Expert? Answer questions, earn points and help others
