Question about Samsung Refrigerators
How to check a samsung refrigerator icemaker - Samsung Refrigerators
Where is the reset button on my samsung refrigerator ice maker?
There is a test button on them if icemaker is in botton draw freezer section button is located on the bottom front on the icemaker its a small square button. If its the icemaker in frig section button on the right side on icemaker it is rectangular rubber coated hold about 10sec
Feb 14, 2017 | Samsung Refrigerators
My Samsung freezer is making a loud knocking noise every 40 minutes in the ice maker area.What do you think?
Is your water connected? If not then turn icemaker off so the water valve will not energize for water supply to icemaker. Otherwise it could be the refrigerant lines knocking when compressor comes on. No real fix for that unless you want to check the sealed system pressures
Feb 25, 2015 | Samsung Refrigerators
We recently replaced the icemaker in our samsung french door refrigerator,the icemaker worked fine for a few days and now no water goes into it,, we replaced the filter as well
Hi my name is Sean, you will need to check water pressure going into refrigerator, If you have adequate pressure, you either have a bad main board, or bad valve, depending on the year the boards were a problem in this unit affecting the icemaker especially. Let me know if you need further assistance.
Mar 26, 2011 | Samsung RF265AA Bottom Freezer French Door...
My Samsung Space Icemaker makes ice very slowly. I keep hearing a click-click-click and maybe a few cubes come out. I have taken the white box inside the icemaker loose but not disconnected it. I think...
Yes, this is a "known" issue with the Samsung's refrigerators. You need to order a new icemaker. The icemaker will come with a brand new control board with new firmware. Replace both of them and this will fix problem. The control board should be located at the back of refrigerator under back panel
Sep 26, 2010 | Samsung RFG297AA (285 cu ft) Bottom...
Model #10657051791 Icemaker just stopped
Aug 19, 2009 | Samsung 18.8 Cu. Ft. Bottom-Mount...
Samsung RS2545SH refrigerator just stopped making ice. any advice?
Samsung Fridge  RS2545SH stopped cooling. The fridge section is about 50/55 and freezer is around 45. It wont go below. At one point, there was rumbling rattling sound from the compressor. Icemaker also stopped woprking.
Jul 18, 2009 | Samsung RS2630SH Side by Side Refrigerator
Samsung refrigerator RS267LABP icemaker
it could that your thermostat is set too cold making the ice crack and brittle
Mar 18, 2009 | Samsung 26.0 Cu. Ft. Side-by-Side...
The icemaker in my Samsung RS255BASB refrigerator is not making ice fast enough. Although the tray does empty automatically on its own, it seems that it is taking way too long to do so. I usually have to...
If you called Samsung, the first questions they would ask is, "Is your freezer door closing properly? Can you feel cold around the freezer door?"
If the icemaker has its own door, the same questions apply.
I've an LG p.o.s. fridge and have had the icemaker serviced several times on warranty. There was a very logical other explanation for this, but I'll be stoned if I can remember it.
Seriously, the "unclosed door" is the most obvious reason.
good luck.
Oct 26, 2017 | Samsung Refrigerators
check the valve connections at the entrance of water supply. Sometime that will get lose. And check if you have water on it and not having a line kinked
Apr 26, 2008 | Samsung RB2155 Bottom Freezer Refrigerator
Samsung rs2555sl icemaker
replaced circuit board. Problem solved
Oct 17, 2007 | Samsung 24.8 Cu. Ft. Side-by-Side...
Refrigerators Logo
Top Samsung Refrigerators Experts
John Tripp
John Tripp
Charles T Nevin
Charles T Nevin
Are you a Samsung Refrigerator Expert? Answer questions, earn points and help others
