Question about Coffee Makers & Espresso Machines
T20 doesn't make coffee - also leaking water and therefore can't descale
  • 2039 Answers
SOURCE: water leaks during the descaling
it started to leak after the descaling and the water that leak is the water very hot you might have a leaky boiller in the descaling process calcium in the boiller melt and if you have bad seal =leak in the boiller. if you use a descaler product and if you use vinegar that might be y you have no steam vinegar remove calcium in little pieces and sometime those pieces block the machine descaler product melt the calcium thanks for using fixya pierre
Posted on Feb 08, 2008
  • 143 Answers
SOURCE: Describe your DeLonghi Caffe Nabucco BCO70
requires replacement group seal and or coffee ground too fine
Posted on Sep 14, 2009
  • 60 Answers
SOURCE: Partial cup of coffee brewed
Call keurig customer service 1800 cup brew
Posted on Mar 26, 2010
heatman101
  • 43501 Answers
SOURCE: wont brew coffee. runs water through fine.
Here is a tip that I wrote that will give you some things to try that will helpyou get your Keurig coffee brewer workingagain.
Keurig CoffeeBrewer not making a full cup of Coffee
heatman101
Posted on Aug 07, 2011
heatman101
  • 43501 Answers
SOURCE: My coffee maker is only filling a 1/2 cup of
heatman101
,./,./l;
Posted on Aug 15, 2011
Siemens EQ.5 coffee machine displays message "Check Water Tank"
Sound like the float in the coffee maker need to either be replaceed or cleanned.
Oct 22, 2014 | Coffee Makers & Espresso Machines
Descale T20 Bosch Tassimo
you need to use the cleaner disk (tucked into the back of the machine) and run through some of the cleaner solution. Then run though just water. Don't forget to store the cleaner disk back in the machine.
Sep 09, 2014 | Bosch Tassimo T20 Single Serve Brewer,...
Can't drip even after descaling
If you just used the liquid commercial type descaling solution, Unplug it and look underneath the arm where the hot water comes out onto the coffee grounds. Take a toothpick or even a pin and make sure all those teeny holes are not plugged up with hard water and other debris. If this doesn't work, maybe the pump is bad?
Jun 21, 2012 | Coffee Makers & Espresso Machines
Keurig special edition leaking water underneath
Reset and Descale with mix of soulutions Page 18 Manual.
May 15, 2012 | Keurig Special Edition B60 Coffee Maker
My coffee maker is not brewing and it is indicating descale what does that mean?
hi, Descale means to run a solution through your machine to clean out any lime and calcium that may have built up in the water lines. If its not brewing then it must have build up in the boiler. Buy some descale solution or powder and add to water resevior add per directions on bottle. Run a descale cycle in machines program. If this doesn't clean out your blockage, then you'll have to remove the boiler and drill out the water inlet. Dazza REPAIRER
Sep 23, 2011 | Keurig B60 Coffee Maker
Decalcify constantly appears on screen and water leakes from bottom of machine only when u press to make a coffee
HI
Decalcifying your boiler: Your boiler uses water that has dissolved minerals in it. Even if it is filtered, there are minerals. Your boiler needs to be decalcified to prevent mineral deposits from damaging it. Why can this damage your boiler? The boilers within these machines are small and narrow and therefore they heat up quickly. They hold a small amount of water (250 ml). Their heating element is in the boiler housing itself. So when you start to accumulate mineral deposit, you take up space. This lowers efficiency for heating. Also the mineral starts to attack the silicone gasket that seals the boiler and soon you have a leaking boiler. Water hardness is measured in numbers from 1 to 4. Number 1 indicates soft water having a few minerals while Number 4 describes water containing the most minerals. Set your water hardness to 4 is my recommendation to keep your boiler in good working order. Descale more often than not enough!
To program the water hardness into your machine, press the scoop coffee button and hold until you get the menu. Scroll through the menu until you come to water hardness. Set your water hardness to the level that your test strip says. Press enter (scoop button). Use the arrows to select the hardness and then press enter. You have programmed your hardness and now the machine will tell you when to descale.
Auto descale: To automatically descale your machine, press the scoop button and hold it down until you enter the menu. Use the arrows on the left to scroll down until you come to Descale. Press enter and the machine will enter the mode to descale your machine. The process takes about 45 minutes. You don’t have to do a thing except mix a full water tank with descaling solution and have a container under the steam wand when your start. If you have a cappuccinonatori on your machine you will need two containers. To start the descaling process, simply turn the steam knob. When the process is over your machine will say “Descale finished”. Remove your water tank and rinse it out. Refill it with fresh water. Replace on the machine and start the descaling process over again to rinse your machine. Go back into your menu and scroll up or down 1 to signal descale and enter. Choose “Yes” and push enter so the machine will tell you when you need to descale again.
On your machine, the leakage is the seals on one of your 2 boilers. One can be fixed the other will have to be replaced depending on which one is leaking.
Nov 13, 2009 | Saeco Stratos Coffee Maker, Espresso...
When i try to brew coffee hot water pouring from under the machine cover and no coffee comes out
Hi
Leaking under the machine usually means 1 of 2 things. You have a ruptured hose or your boiler is leaking. Both are repairable. There are 2 types of boilers in the Saeco machines depending on its age. The newer machines have a stainless coiled tube in an aluminum heater. This would probably be a hose. The older boilers were a 2 piece with a gasket that will leak if not taken care of by descaling on a regular basis and done correctly. No excessive heat when descaling. Turn the machine on, then run descaler through the wand by opening the knob for water. Run 8 nozs through the wand then turn the machine off and let it set. Do this until the descaler is gone. The rinse with a tank of fresh water.
Jul 10, 2009 | Saeco Vienna Espresso Machine
Water leaks during the descaling
Feb 07, 2008 | Miele CVA615 Espresso Machine
Coffee Makers & Espresso Machines Logo
Top Coffee Makers & Espresso Machines Experts
Colin Stickland
Colin Stickland
Kolbrun...
Are you a Coffee Maker and Espresso Machine Expert? Answer questions, earn points and help others
