Question about Bose Audio Players & Recorders
Bose wave radio model awr1-1w ribbon cable came partially unhooked while reassembling and still powered up. Radio went out will not power up
  • 6 Answers
SOURCE: Bose Wave radio humming noise
Actually the problem was caused by a bad 470uf cap, that was used to filter the powersupply for all the analog amps. Replaced the cap the unit works like new.
Posted on Apr 06, 2008
SOURCE: no power up
Same problem here but I could not find the Q401...do you know where I can find a schematic that could help me locate it?
Posted on Nov 09, 2008
BillB-SA
  • 2761 Answers
SOURCE: My 10 year old Bose wave radio quit working.
There's a line fuse inside the radio, mounted on a PC board. CAUTION: disconnect the set from power before opening the case or poking around inside. The fuse could be bad, but these sets are notorious for losing the power transformer. If the fuse is ok then you are looking at a $100 repair fee from Bose. You might want to check out the new HD radios -- better sound, MUCH lower price.
Bill B.
Posted on May 19, 2009
cjackHD
  • 71 Answers
SOURCE: How can I get the Bose Wave radio to work in Europe??
Yes. The tuner spacing option should do this. If it's a Wave Music System or a Wave Radio II, go into the 'setup menu' and look for 'tuner spacing'. -If it's older, you may want to call Bose for a solution.
Posted on Jun 12, 2009
DigidocTN
  • 22 Answers
SOURCE: Bose wave radio will not power on. used to work
I repaired mine recently. Check transistor Q4 for an e-b short. The replacement costs less than $1.
Posted on Jun 27, 2009
My bose CD player is not working my cd are stuck I don,t why
Good luck this should do it.
If you have a cd or two stuck in your Bose wave radio, here's how to remove it and save yourself $99. This procedure is for the radio (model AWRCC1 or similar) with a single front loading cd slot.
PART I
1. First unplug the power, wait a minute, and then replug power, watching the front display.
2. The display will read "Ejecting". If the cd ejects, then you're done and can skip Part II. If it doesn't eject and/or it displays "Disk error" then you'll need to do the Part II steps.
PART II
1. Unplug the power cord.
2. Turn the radio upside down with the front facing you.
3. Remove the 5 screws from the bottom plate.
4. Hinge the front of the bottom plate up no more than 2". Don't overdo this or you'll damage various ribbon cables inside. Use extra hands or a prop to keep it open this amount.
5. Reach inside and tilt-up the front of cd player's metal housing just enough to access the rims of the cd(s) within the space created in step 4.
6. Pinch the rim(s) of the cd(s) and gently pull it/them out.
7. Reverse these steps to reassemble your radio.
Enjoy your cd player again!
Feb 08, 2015 | Bose Wave Radio
A CD is stuck in my bose system How do I get it out?
From an other web site
PART I
PART II
Oct 09, 2014 | Bose & Wave& Music System
After a power outage, my Bose radio went to military time. I've tried to re-start it by unplugging, re-unplugging, etc. Help!
To switch between 12hr and 24hr format:
1) Turn your Wave Radio off
2) Press and hold "Clock Set"
3) Press "On/Off" to switch between 12hr or 24hr format.
Dec 27, 2010 | Bose Wave Radio
Bose radio will not turn on. I have a Bose Wave radio, model AWR1-1W, D.O.M. 980305, that will not turn on. I've verified that there is power to the radio (checked outlet plug of cord). I've looked...
I have the same issue with the same model. I found an open primary winding in the large transformer inside the unit. Now the problem is finding somewhere to buy the transformer...
Sep 19, 2010 | Bose Wave Radio
Bose Wave Radio pops, loud hum that fades
Power supply capacitors have dried out and need to be replaced.
Sep 03, 2017 | Bose Wave Radio
My bose wave radio wont turn on. It has no power
I have the exact same AWR1-1W model for repair last week. I am assuming you have a meter and you also have soldering skills here.
You might want to check the Q4 transistor (2SC3792) for a short on the two outide pins. With the power disconnected, measure with a multimeter the resistance between the two outside pins of the Q4 transistor. If you measure anything between 0-3 ohms it is shorted. Replace this part with a similar part or you could replace it with the new Bose recommended part - 2SD438F-MP-E but it is very hard to obtain. I have used an 2SC2655 instead and had no problems so far with the radio. This radio also came in totally dead with no display nor the radio working.
Jun 06, 2010 | Bose Wave Radio
My Bose Wave CD Radio has no power. Will not turn on. dead. Checked the power cord and supply, it is good. Is there an internal fuse?
Yes - although Bose doesn't really publicize the fact, there is an internal line fuse in each Wave. Location varies by model and date of manufacture, but the fuse is easy to spot once you open the radio case.
Bill B
Apr 10, 2010 | Bose Wave Radio
Grand kid's spilled pop onunit.bad r222 +c209 mod #awrc-1p bose.
Bose will not release their schematics or parts lists, effectively giving them a monopoly on repair of these sets. There is, however, a line fuse on a circuit board inside the radio. CAUTION: disconnect the set from its power source before you open it up or start poking around inside it. If you're lucky, all you will need is a simple fuse replacement. The sets are, however, notorious for "blowing" power transformers. If the fuse is not the problem, you will likely need to send the set to Bose for repair. On their web site, www.bose.com, they offer to repair most Wave sets for $100 or give $200 credit towards the purchase of a new Wave. Before you spend the big bucks though, you might want to check out the new HD radios. Better sound and MUCH lower prices than the Bose.
Apr 08, 2009 | Bose Wave Radio
Bill B.
Mar 26, 2009 | Bose Wave Radio
Bose wave radio/cd often cd spins but does not play, sometines will correct if I turn unit off and on. HELP tHANKS
I've repaired about 10 type Bose AWRC3x (the radio/cd model with lift up lid and top controls). If the cd won't play or skips, try cleaning the lens VERY carefully with a cotton bud with some isopropyl alcohol. Let it dry then try again. This will help in about 1/3 of cases.
After that, a new laser unit is needed. They cost around 15 pounds,30 dollars, (Type SFP100s with 13 pin connector made by Sanyo). You need to have some electronics experience to take the case to bits to get the laser deck out, change the cd laser and reassemble. Basically, DISCONNECT THE POWER! Remove the 3 screws on top, turn over and carefully prise the front of the base away from the top cover with a table knife or similar. Lift off the top cover - be careful with the lid ribbon! The deck can be disconnected from its ribbon cable and wired connector very carefully. Take the deck to bits and fit the new laser head (take photos if you think it will help). Remember to unsolder the shorting 'blob' of solder which protects the new laser from static till its fitted.
On the bright side, there is no tracking etc to set up, that's all automatic so usually they work like new with a new laser fitted. I have to say this is the weakest feature on the Bose CD radio, the actual electronics rarely gives trouble.
Hope this helps Steve O'Donnell
Nov 27, 2007 | Bose & Wave& Music System
Top Bose Audio Players & Recorders Experts
Invebo
Level 1 Expert
Are you a Bose Audio Player and Recorder Expert? Answer questions, earn points and help others
